Results 1 to 15 of 15
Reload Thread: 95 Sable Wagon Stalling
    DonCorleone's Avatar
    DonCorleone is offline Member
    Oct 2007
    Pulask, Wi
    43
    I have a 95 Mercury Sable Wagon with the 3.8L that I bought used with over 200k miles on it. The car starts and then stalls once it reaches operating temperature. After the car stalls it wont start again until it cools down. After it stalls there is no spark. It has all new plugs and plug wires. Also, when it is running and you close the hood the engine sputters and sounds like it is going to die. Can anyone shed some light on what my problem may be? Thanks.
    87linkin's Avatar
    87linkin is offline CarAudio.com Elite
    Sep 2008
    alabama
    576
    Re: 95 Sable Wagon Stalling
    iac sensor
    Oct 2007
    Pulask, Wi
    43
    As in Idler Air Control? The sensor or the actual valve itself?
    Jul 2006
    Georgia
    12,847
    1 Post(s)
    1170 Post(s)
    you better hope thats what it is, and not lack of compression....
    REFS:
    Squeak9798, Kumbos310w6, BigBangTheory, Jmanpc, MillzThaYungin, WLDock, -Leister-, ThomasG, J31Rob (and a few more I have forgotten)
    Quote Originally Posted by BassAndBeer View Post
    sorry man but ford will always be a ford. ford is the sony xplod of cars and trucks. you had bad experiences with chevy because your a ford guy. its what seperates the men from the boys. friend billy use to drive a ford. he drives a chevy now. they call him billy no more. hes known as bill now..
    Oct 2007
    Pulask, Wi
    43
    Well, the IAC was replaced before I bought the car about 3 months ago. Whatever it is, when it happens it shuts down the ignition system because after it stalls there wont be any spark.
    Oct 2007
    Pulask, Wi
    43
    Replaced the ignition coil and the ignition control module, no luck. Any help would be greatly appreciated.
    jdawg's Avatar
    jdawg is offline CarAudio.com Veteran
    Jun 2006
    Maryland, United States
    8,582
    61 Post(s)
    take it to autostone and get codes checked? Its a sable, what do you expect?
    refs
    woc47, nigro013, defconx3, louisiana_crx, bld 25, supa_c, lancer1978, sxkicker89, 310w6, more, i forget
    Oct 2007
    Pulask, Wi
    43
    Quote Originally Posted by jdawg View Post
    The check engine light doesnt come on, thus the computer wont store and error code if it doesnt know that
    something is wrong. My next guess is the crank position sensor.
  9. #9
    jdawg's Avatar
    Jun 2006
    8,582
    61 Post(s)
    Quote Originally Posted by DonCorleone View Post
    just because the light isnt on doesnt mean there aernt codes, you really ned to get it scanned. Just throwing parts at it you will spend a bunch of money. It could be anything. Usaully when a crank sensor goes bad the car wont start at all.
    edit- the check engine light moreso reflects emissions problems anyways
    refs
  10. #10
    jdawg's Avatar
    Jun 2006
    8,582
    61 Post(s)
    how do you know it doesnt have spark after its warm? What diagnostics did you do? Do you have the orgional cat on it?
    refs
  11. #11
    Oct 2007
    Pulask, Wi
    43
    After the car stalls I put a spark tester on and tried turning it over, nothing. The spark tester is confirmed working. The original cat is on it.
  12. #12
    95BlackGA's Avatar
    95BlackGA is offline CarAudio.com Veteran
    May 2007
    Missouri
    4,836
    7 Post(s)
    Get a compression test done. You can sometimes borrow(or rent) the test kits from O'Reillys' or Autozone's. It's an older car, so a vacuum leak is likely, especially if you shut the hood, and it sputters. There are several methods to checking for vacuum leaks. Check the EGR Valve, and PCV valve. The EGR valve you can get for around $50-$70, and the PCV valve will only cost around $5.
    Sold To - Ku-Sama - Benilson09 X2 - Vitveet - Max_Power X2 - xfeat - DaveT - uglydimple12 - pickup1 - EnvEe 02 - blackbonnie - lightningbolt44 - Louisiana_CRX X2 - audiobahnuser18 - NoPh33rRaCiNg - profoundwill - Scoobydoo - joe98chevy - theMessenja44
    Traded With - Rich00 - fwb_1234 - SPL140.2 - Six501 - Scoobydoo
    Bought From - RoLLaxPhile - SPL140.2 X2 - Randy Savage - Johnny Law.Lulz
    R.I.P Uncle Scot, you'll be missed. 8/22/08 We love you, bud.
  13. #13
    Oct 2007
    Pulask, Wi
    43
    Quote Originally Posted by 95BlackGA View Post
    If there was a vacuum leak there would still be spark after the car stalled, after the car stalls there is NO SPARK.
  14. #14
    audioatg's Avatar
    audioatg is offline CarAudio.com Elite
    Aug 2006
    NJ 08080
    1,741
    8 Post(s)
    Check to see If you have injector pulse as well. No Spark NO injector pulse. Do you have a rpm gauge if so. Is that moving like going up in rpms when you are trying to crank it. Possible crank sensor bad. If no signal from that you wont get any spark. Possible computer went on it. Seen alot of computers good in fords.... Also Yes you can have codes with out a check engine light on. Your ford has. Key on engine off codes. Key on engine running codes. Pending codes. Memory codes. Some codes just dont set a MIL request. SO yes you can have codes. And Im sure you do have codes. Another things. Back probe the 5 volt reference wire on anything really MAF senor. IAC they all have the 5 volt reference wire to them. Check and see that you DO have this voltage.
    Uggg what else. Check them out see what happens still take it to a shop get the codes checked out. My guess a bad crank sensor or pcm.
    Edit I think Im off on what Codes like KOER KOEO. But Im sure you still have codes. Some codes need the ignition cycles drive cycle to even set. You cant get vehicle to run so you might not have yet got to that point for them to set the MIL light on but you still have the codes.
  15. #15
    Oct 2007
    Pulask, Wi
    43
    I got it figured out, bad distributor. Car runs fine now. Thanks for everyones help.
