Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Reload Thread: 97 Ranger exhause problem HELP
    kizzo's Avatar
    kizzo is offline CarAudio.com Elite
    May 2006
    All over
    533
    So I bought a ranger the other day and i realized that the exhaust is a corroded. It leaks pretty bad, when i put my hand by it it feels like a blow dryer.
    Heres what it looks like:
    to the left is where the CAT and the tailpipe are and to the right is where the engine is.
    I've never even touched an exhaust before but im guessing i only need to replace it from the left back (part with the CAT on it).
    How much do to get that shiz done?
    Refs: angrytrucker78, mike dressure, 2000LaDe, BassAce
    eBay: nomoredan33 - 43 pos feedback
    Front: Cadence CWM-6 6.5 Comps
    Comp Amp: Profile CA600 150w x2 @4ohm
    Rear: empty
    Subs: (2) Diamond Audio D6 12's
    Box: Custom small ported enclosure
    Sub Amp: Modded MTX1501d 2000w RMS @1ohm
    Optima D34 Yellow Top in Trunk
    Knu Konceptz 1/0awg Wiring
    dman4486's Avatar
    dman4486 is offline Paid to Post
    Jan 2008
    Central, SC
    9,333
    Re: 97 Ranger exhause problem HELP
    advance auto carries all the factory exhaust parts pre-bent and with all the hardware. you should be able to do the entire thing yourself and save on the labor
    Auto: 96 honda passport 3.2L v6 4X4 5sp
    Big 3 pics--THE MAV--THE RSD's--MY VLX
    Rices Creek Pics
    Refs: Sold to; lilmaniac2, alexdbest2000, jshak07 Bought from; CJL
    dman4486's Avatar
    Jan 2008
    Central, SC
    9,333
    you will also need to replace the pipe on the right and the flange gasket
    Rices Creek Pics
    kizzo's Avatar
    May 2006
    All over
    533
    how much am i looking to spend here a couple hundred?
    Rear: empty
    dman4486's Avatar
    Jan 2008
    Central, SC
    9,333
    Quote Originally Posted by kizzo View Post
    if you replace the cat, yes...if just pipe then you can do the entire system for ~$100 or less and bolt on
    Rices Creek Pics
    kizzo's Avatar
    May 2006
    All over
    533
    could you show me what parts i need? I live right by an advanced auto and my zip code is 60123.
    Rear: empty
    dman4486's Avatar
    Jan 2008
    Central, SC
    9,333
    what motor?
    Rices Creek Pics
    kizzo's Avatar
    May 2006
    All over
    533
    4 cyl 2.3l
    Rear: empty
  9. #9
    dman4486's Avatar
    Jan 2008
    Central, SC
    9,333
    the front pipe should be one of these
    http://www.partsamerica.com/ProductL...r=Exhaust+Pipe
    and the extension pipe should be one of these
    http://www.partsamerica.com/ProductL...Extension+Pipe
    If you go to advance, tell the guy you want to see his exhaust diagram book, look up your truck and write down the numbers next to the pipes you need and the gaskets...then the guy behind the counter can plug them into the computer and get them ordered
    Rices Creek Pics
  10. #10
    kizzo's Avatar
    May 2006
    All over
    533
    and those are all bolt on right no welds
    Rear: empty
  11. #11
    dman4486's Avatar
    Jan 2008
    Central, SC
    9,333
    you may need a clamp, but for the most part they are bolt on with the exact flanges you already see under the truck
    Rices Creek Pics
  12. #12
    kizzo's Avatar
    May 2006
    All over
    533
    how can i even get those bolts off
    Rear: empty
  13. #13
    explorer2's Avatar
    explorer2 is offline CarAudio.com Elite
    Sep 2006
    usa
    529
    cut them
  14. #14
    dman4486's Avatar
    Jan 2008
    Central, SC
    9,333
    Quote Originally Posted by explorer2 View Post
    cut them
    ^^^^exactly
    Rices Creek Pics
  15. #15
    kizzo's Avatar
    May 2006
    All over
    533
    what if i were to cut that section out. like a foot of pipe including the coupling and found a pipe at advanced that would slip over the 2 halves and then just clamped it. would that work?
    Rear: empty
