Re: How Much Should A Limited Slip Clunk?
well, from the factory its not normal. Now, depending on the aftermarket one you installed, they make minimal noises....nothing real noticeable though. Sounds like somethings off. I have a full locking detroit locker, which bangs, clunks, and chirps going around corners, etc, but a limited slip is supposed to be stock-like.
silver02alty, AgEnT, chaarlieee, shynegrynd07,QtrHorse, Dumple, Mike Dressure, southstylestang, j3bus2k3, dkmesa, RipDaJacka, audiobahnuser18, BAD_MAYHEM, Famous_78,nismos14, shallowfu, CRAZYCORNUTS18, jmanpc, Supergumby5000, Apoc, pioneer pimp, JLa Obsessed, urlost, Hustler904, cha0, fattony911,
David706, EnvEe 02, 93 saturn sl2, jblanford, pickup1, tez4life, blackbonnie, oxsign, sxkicker89, revots, robertspangler
Kenwood flip out 7" t.s HU . Sirius + sony XE744 dancing EQ, mb quart "Q" series 6.5"comps,
kicker kx350.4 amp, optima yellowtop
autotek mm3000.1, 0 ga wire
1 RE Audio XXX 15 in 4.5 cu ported box I BUILT
big 3 (1/0 wire)...deadener
148 db on new tl
Bookmarks
