Results 1 to 10 of 10
Reload Thread: 1992 Eclipse..can Anyone Answer My ?
    Sep 2007
    chicago,il
    187
    Can U Swap A 1.8 Engine With A 2.0 Turbo Engine Is The Bolt Pattern Any Different And Will I Need A New Transmission???
    Lunchbocks's Avatar
    Lunchbocks is offline Senior VIP Member
    Nov 2005
    south chi burbs, IL
    32
    330
    Re: 1992 Eclipse..can Anyone Answer My ?
    Besides different motor mounts, you also have to consider different wiring harnesses, fuel system and exhaust routing. Not to mention plumbing for the intercooler and different intake setup.
    '06 Chrysler 300 - work in progress
    Orion H2
    eD NINe.1
    KnuKonceptz Kolossus
    p3fosgate-impal's Avatar
    p3fosgate-impal is offline Banned
    Sep 2007
    chicago,il
    187
    thanx a lot..
    Skip01's Avatar
    Skip01 is offline Diggy
    Apr 2006
    Marrero,LA
    7,189
    20 Post(s)
    Yehhh i think u may could get the 2.0 FWD Turbo in...but as said its gonna need wirin harness and mounts and all
    YOUTUBE VIDZ:
    http://www.youtube.com/user/Skip01
    19psi's Avatar
    19psi is offline Bippu
    Sep 2007
    Lousiville KY
    182
    check out www.vfaq.com and www.dsmtalk.com for detailed info.
    dB-SPL's Avatar
    dB-SPL is offline CarAudio.com Elite
    Aug 2007
    Canandaigua, NY
    863
    17 Post(s)
    Quote Originally Posted by p3fosgate-impal View Post
    Honestly.. It's going to be cheaper + soooo much easier to just start with a Turbo DSM to begin with. You'll have to find a 6-bolt 4G63T with the FULL harness. You can use a 7-bolt, but I'd stay clear of them as they tend to crankwalk quite often( and it's just more work). Then you'll need to route a new exhaust system and find a sufficient fuel supply. You can use the same tranny.
    -Bill-
    '11 Jeep Patriot
    Head Unit - Pioneer AVH-P3200DVD
    Front - Massive Audio CK69X
    Front Amp - Massive Audio NX2
    Rear - Infinity Kappa's
    Subs - 8 Sundown SA-8 v2's
    Sub Amp - AB VFL 450.1
    147.6 @ 37Hz
    19psi's Avatar
    Sep 2007
    Lousiville KY
    182
    that's true, there's a good clean awd 91 shell sitting here, nice paint, intact harness and everything, just needs engine and trans, $500. they're everywhere if you look. people can't keep them running for some reason. dumb kids....
    dB-SPL's Avatar
    Aug 2007
    Canandaigua, NY
    863
    17 Post(s)
    They can't keep them running because they do this.. Almost any idiot with a turbocharged vehicle hears that they produce these things called 'boost controllers'. They figure.. "More boost, more power" without even considering the fact that tuning and more fuel is also needed. Hook it up, "Lets see what 30psi will do with nothing but a CAI"... Dun dun dun.. Another one bites the dust..
    -Bill-
    '11 Jeep Patriot
    147.6 @ 37Hz
  9. #9
    Sep 2007
    chicago,il
    187
    Quote Originally Posted by dB-SPL View Post
    -Bill-
    SO YOU SUGGEST FINDING A ECLIPSE WITH A 2.0 AND BUILDING OFF THAT INSTEAD OF SWAPING ENGINES?
  10. #10
    Ferendon's Avatar
    Ferendon is offline Proabbly drukn
    Jul 2007
    Fort Worth, TX
    950
    No... the 420a is a 2.0. The 4g63 is a 2.0. And they are worlds apart.
    He's suggesting find an already-turbo DSM. And as far as they "reliability issues" go with DSMs. They're self-perpetuating myths. As stated above, people think they can simply pump the boost to 30 psi, and do 6k clutch drops cause "it's AWD, it's made to launch". Any DSM you find is gonna be
    1)babied --- very rare... VERY.
    2)built --- expensive, and never buy someone's project
    3)busted --- typical, and very cheap. The perfect project.
