Results 1 to 10 of 10
Reload Thread: 99 saturn sc1
    bannock's Avatar
    bannock is offline CarAudio.com Elite
    Jul 2005
    winnipeg,mb
    685
    12 Post(s)
    99 saturn sc1
    Hey guys,
    Ive noticed my saturn has been really loud lately. It was loud before but i replaced the tensioner and that seemed to quiet it, but now its back to being noisy again, is that just the belt?
    Also, when im braking it sounds like something is rubbing together (sounds comming from my tires) i just had my tires replaced and the mechanic never said that anything was wrong. brake pads or sumthing?
    Thanks
    Bought From: poundindak69, ribeiro953, cmiller8006, aaronmj, DUMPED
    2002XLT's Avatar
    2002XLT is offline Thats right bishes...
    Jun 2007
    H-Town, TX
    7,005
    12 Post(s)
    Re: 99 saturn sc1
    spray wd-40 on your belt and see if the noise goes away, if so, thats your problem..
    grinding like metal? probably pads. My brakes make a noise, but its more of a swish-swish-swish really fast, but its due to the slots....
    Refs-
    http://forums.explorerx.com/index.php?showtopic=11984
    http://www.caraudio.com/forum/showthread.php?t=245865 http://www.caraudio.com/forum/showth...59#post3482859
    Ebay Feedback- http://myworld.ebay.com/lilchard1969/
    Vehicle-
    2002 Explorer XLT
    R1 Concepts Cross drilled/slotted rotors w/ performance pads, K&N FIPK Intake, Removed roof racks, Debadged, Tinted tails, Clear Corners, Upper and lower Billet Grilles,5% Tint all the way around
    Stereo- All stock.
    bannock's Avatar
    Jul 2005
    winnipeg,mb
    685
    12 Post(s)
    Re: 99 saturn sc1
    yeah mine is kinda like your swish swish. thanks for the wd-40 idea
    2002XLT's Avatar
    Jun 2007
    H-Town, TX
    7,005
    12 Post(s)
    Re: 99 saturn sc1
    id check to see if you might have a slightly warped rotor, or if its wearing unevenly, maybe even something that is rubbing against your rotor. Best thing to do is take off your tire and see what you can find.
    Refs-
    Vehicle-
    2002 Explorer XLT
    Stereo- All stock.
    Ferendon's Avatar
    Ferendon is offline Proabbly drukn
    Jul 2007
    Fort Worth, TX
    950
    Re: 99 saturn sc1
    WD-40 is a horrible idea. It will only make the belt worse in the long run, and by long run I mean about 2 days. There's a reason that STP makes belt dressing.
    2002XLT's Avatar
    Jun 2007
    H-Town, TX
    7,005
    12 Post(s)
    Re: 99 saturn sc1
    ive used it a few times with no ill result.
    Refs-
    Vehicle-
    2002 Explorer XLT
    Stereo- All stock.
    Ferendon's Avatar
    Jul 2007
    Fort Worth, TX
    950
    Re: 99 saturn sc1
    Congrats. Negative results are not always apparent. And WD-40 is only a cleaner, it has no lubricating or adhesive qualities, beyond it's wet life.
    bannock's Avatar
    Jul 2005
    winnipeg,mb
    685
    12 Post(s)
    Re: 99 saturn sc1
    what would you recomend then?
  9. #9
    Ferendon's Avatar
    Jul 2007
    Fort Worth, TX
    950
    Re: 99 saturn sc1
    STP Belt Dressing. $4 at VatoZone. It will moisturize the belt, and provide a small amount of adhesion to stop the squeak. But, if it's squeaking, then any solution is temporary. You've got something that needs to be replaced.
    And I believe you'd have the 2.0 Ecotec, which is known for a ****** belt tensioner. If that's the case, get a set of hole saws. You're going to have to drill a hole in the fender wall to get the bolt all the way out to remove the assembly. Just make sure and prime it when you're done, and put the fender guard back in.
  10. #10
    bannock's Avatar
    Jul 2005
    winnipeg,mb
    685
    12 Post(s)
    Re: 99 saturn sc1
    yeah i found out quick about the tensioner being ******. Cept i didnt have to drill any holes. the fender guard is loose and once i take off the tire i can get at it no problem
