Results 1 to 9 of 9
Reload Thread: hood pop broken
    blong131's Avatar
    blong131 is offline CarAudio.com Elite
    Jun 2007
    Emmaus, PA
    585
    hood pop broken
    when i pull the lever below the dash to pop the hood on my explorer, the hood doesnt pop...how do i get my hood open??!!
    blong131's Avatar
    Jun 2007
    Emmaus, PA
    585
    Re: hood pop broken
    noones ever run into this problem?
    nativeboy's Avatar
    nativeboy is offline PIMPING JOKER
    May 2007
    Flagstaff, AZ
    1,111
    Re: hood pop broken
    i had this problem before so all u do is just bang on tha hood till it pops open and dont bang on it too hard.....it should work...
    jmanpc's Avatar
    jmanpc is offline CA.com Nostalgist.
    Jan 2006
    Jacksonville, Fl
    25
    17,290
    Re: hood pop broken
    is it really loose? it might just be that the wire came out of the lever
    2007 Red Ford Focus ZX4 SE
    - Clarion DXZ955MC -
    - MB Quart RSD216 - 2 MB Quart RWE-354 in 4 cubic feet sealed -
    - MB Quart DSC4125 - Audiopipe AP1500.1D - Optima Blue Top -
    Team High Sexage
    blong131's Avatar
    Jun 2007
    Emmaus, PA
    585
    Re: hood pop broken
    the wire didnt come out of the lever and also i tried the banging thing...its not working
    nativeboy's Avatar
    May 2007
    Flagstaff, AZ
    1,111
    Re: hood pop broken
    well umm bang on tha middle of it should work....
    Fear Of Theive's Avatar
    Fear Of Theive is offline CarAudio.com Veteran
    May 2007
    Pittsburgh,Akron Ohio
    2,147
    Re: hood pop broken
    so now i know how to get into explorer's isn't thier a safety opener incase you have a body in the back?
    blong131's Avatar
    Jun 2007
    Emmaus, PA
    585
    Re: hood pop broken
    hwat?
  9. #9
    Ferendon's Avatar
    Ferendon is offline Proabbly drukn
    Jul 2007
    Fort Worth, TX
    957
    Re: hood pop broken
    Just reach up from under the front bumper, between the bumper and radiator. Find the end of the cable, which will be hooked into a metal tab on the release. Just push that metal tab, which is normally pretty easy, and it should pop open. If that doesn't work, you're going to have to find the cable above the wheel well, cut the housing, and pull the **** out of the cable with a pair of good pliers.
