Results 1 to 7 of 7
Reload Thread: 99 Blazer not turning over
    vgeek's Avatar
    vgeek is offline wat
    Oct 2005
    Northern Kentucky
    614
    1 Post(s)
    Okay, my mom's truck is once again having problems. It is a 1999 4.3 4x4 Trailblazer package.
    When you go to turn the key, nothing happens. When you try to turn the key back towards you, you can't get it far enough back to remove from the ignition. The fuel pump was replaced 6 months ago, and was similar to this problem, but it would try to turn over; now, nothing at all happens, no clicking noises or anything to signify any attempts of activity. Checked all the inside fuses and the fusebox under the hood. Any suggestions?
    Slo_Ride's Avatar
    Slo_Ride is offline Take It Easy
    Oct 2005
    Atlanta
    13,383
    35 Post(s)
    3261 Post(s)
    Re: 99 Blazer not turning over
    you're saying you can't remove the key?
    vgeek's Avatar
    Oct 2005
    Northern Kentucky
    614
    1 Post(s)
    Correct. Accessory is furthest back, then off/remove key is 2nd, then the ON position, then finally is the start position. It goes from on and lets you attempt to turn it over, but it doesn't turn over or even try to start.
    Slo_Ride's Avatar
    Oct 2005
    Atlanta
    13,383
    35 Post(s)
    3261 Post(s)
    Have you check the battery? If the ignition swith is stuck in the "on" position then it probably kill the battery. As you try to turn the key to remove it, turn the steering wheel in both directions as well. Sometimes the switch will get locked and you have to turn the steering wheel to unlock it.
    Is it in park?
    vgeek's Avatar
    Oct 2005
    Northern Kentucky
    614
    1 Post(s)
    It's in park, the thing is, it won't shift out of park. The wheel won't lock either because the key is still in the ON position. Normally when it's in the ON position, it will let you change from park to drive and such, not right now though.
    Lckmyblls's Avatar
    Lckmyblls is offline 4 Combat Tours & Counting
    Jun 2006
    Fort Campbell Ky.
    1,363
    sounds like your battery died from the key being in the on posistion and the reason it wont shift outta park because you to depress on the brake pedal to activate the brake switch to let you shift it out of park....sounds like you might need an ignition switch ive seen that on these models a few time before.....
    Too often, we lose sight of life's simple pleasures. When
    someone annoys you it takes 42 muscles in your face to frown,
    BUT it only takes 4 muscles to extend your arm
    and b!tch-slap that [email protected]%ker upside the head.
    IF YOU DONT STAND BEHIND OUR TROOPS PLEASE FEEL FREE TO STAND IN FRONT OF US!
    SOLD TO:bubbagumper6,protonman,Flakko,Theiroff,omizzle,Thu mpinCRX,path2spl,Mazdakid,mad212 Bought From:Towncar,IonSQL,mrwigglezdj,stevew007,hc3_cuz,cosmi ccharlie, Fast1one, branham1127 Traded:Theiroff,IonSQL,bagdntagd
    May 2006
    LACA
    111
    i'd be checkin into the ignition lock cylinder
