Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 35
Reload Thread: Drilled into gas tank
    dbubble's Avatar
    dbubble is offline SLOW LOUD AND BANGIN'
    Mar 2005
    ATX
    625
    Me like a ******* was tryna figure out why everytime I fill up at the pump I have a terrible gas smell the whole day, I remembered when I got my system put in my friend tried to drill the box to the floor in the trunk but ended up drilling in the gas tank. What can I use to seel it up from the inside? I was thinking like silicone but not sure
    References
    CA.com
    mcjas63, skeptikal, JAZN, RADEoN, cpierce, chinny, moe lester, powerNaudio, camry_tuner, LivinLife, loudblazer02,ace_800 , pboulos , Pitchblack98, Mistergrubbs, Faulkton,Louisiana_CRX, 5.3bowtie, blackbonnie
    SD.com
    penn tha chocolate thunda, ken18, jazzy
    XtrmAudioCncpts's Avatar
    XtrmAudioCncpts is offline CarAudio.com Veteran
    Mar 2005
    Fairfax, Va
    31
    4,294
    Re: Drilled into gas tank
    umm i would replace it. the car itself with a hole in the gas tank isnt very safe
    Quote Originally Posted by Devillain00
    XAC = pimpin since been pimpin
    pcolasfinest's Avatar
    pcolasfinest is offline Go ahead, drink it in.
    Aug 2005
    florida
    33
    1,363
    smooth move..........
    Ctminime's Avatar
    Ctminime is offline 1/2 Team SubHertz
    Nov 2005
    Lincoln, Nebraska
    30
    1,070
    o man.... o man i cant belive that u did that .... u gotta check on thinkgs like that before u start drillin holes..... but yea get a new and/or used one...
    VEHICULAR-'01 Monte Carlo Ls
    DECK-Alpine CDA-9855
    FRONTS-Type-R 6.5" components
    FRONT STAGE AMP Kicker Kx250.2
    SUB AMP-Elemental Designs-eD NinE.1 @ 1 ohm
    SUB-Stereo Integrity Magnum D2
    Wiring-1/0 AWG www.weldingsupply.com
    Electrical-2X Optima Red Tops
    Box-2.0 @ 32 HZ
    REFS- toolowtoogo, cadenceowner, chibahawk, fived, bibby
    Term Lab Scores
    RL-P 12's TL scores---142.8 db drag 138.2 in the bass race..
    SCORES ABOVE AT 30 HZ!!!! (box tuning that is)
    SI MAG 12 TL scores
    Box tuning 32hz - 140.9 @ 46hz
    Darth Audio's Avatar
    Darth Audio is offline Old School Veteran
    Oct 2005
    Dark Side
    44
    326
    They make patch kits to repair gas tanks, you can get 'em at Autozone etc. Don't ask why I know (I was very young, LOL) Obviously the best option is to replace it. But at a minimum you are going to have to drain and drop the tank to repair it. BTW silicone proably won't do well with gas.
    99 Mitsubishi Galant
    CDT Audio CL 62's
    CDT Audio UP219's
    CDT Audio CL1215
    3 MTX Thunder 2160's
    Alpine 9835
    GO IRISH!
    faulkton's Avatar
    faulkton is offline CarAudio.com Veteran
    Jul 2005
    neverland
    22,096
    6 Post(s)
    i hope you dont smoke,
    pretty funnay eugy
    dbubble's Avatar
    Mar 2005
    ATX
    625
    Well I did some research and found what I was looking for, its called JB Weld. They have one called Water Weld and its for gas tanks. So Im gonna try that out. thanks for the suggestions.
    Heres a link
    http://jbweld.net/products/water.php
    References
    CA.com
    SD.com
    iceteebone's Avatar
    iceteebone is offline Banned
    Aug 2003
    Michigan
    32
    37,876
    just don't fill your gas tank to the point where it starts to leak
  9. #9
    88Vette's Avatar
    88Vette is offline Senior VIP Member
    Feb 2006
    Houston,TX
    52
    416
    I've used that JB weld stuff on lots of things but never a gas tank.
    It does work great though. VERY strong after it sets. You can file it, grind on it..that is some tough stuff. Hope it works for you. It worked great for me on a plastic air cleaner housing.
    Good luck with all that!
  10. #10
    Ignatowski's Avatar
    Ignatowski is offline CarAudio.com Veteran
    Mar 2005
    Dirty South
    6,854
    104 Post(s)
    I would get a gas tank patch putty
  11. #11
    faulkton's Avatar
    Jul 2005
    neverland
    22,096
    6 Post(s)
    only tweekers use jb weld..if you do use be sure to cover it with lots of duct tape too
    pretty funnay eugy
  12. #12
    skadude016's Avatar
    skadude016 is offline CarAudio.com Veteran
    Feb 2003
    Canton, GA
    31
    7,317
    13
    2 Post(s)
    Quote Originally Posted by dbubble
    KA FUCKING BOOM!
    HU:Kenwood Excelon KDC-889
    Speakers: CDT 61A's with rainbow x-overs
    Front amp: Autotek MM100.4
    Sub amp: (2) Audiopipe 1500's
    Subwoofers: (4) 15" Crunch GPV
    Box: 16 cubes tuned to 28hz (removable port)
    Extra Batt: C&D 139AH
    151.xx sealed up 154.xx in the kick
  13. #13
    Ayrton's Avatar
    Ayrton is offline CarAudio.com Elite
    Sep 2005
    Atlanta
    47
    551
    Dear God please don't use JB Weld for this. Have it repaired by someone who knows what they are doing, or replace the tank.
  14. #14
    Prowler573's Avatar
    Prowler573 is offline R.I.P. Gossamer!!
    May 2005
    Northwest Louisiana
    44
    18,522
    You don't need to outsource a repair like that - it's easily enough accomplished by yourself.
    Get some proper gas tank repair, drop the tank, and fix it right. As the puncture will be in the very top of the tank you shouldn't even have to drain the tank prior to making the repair (although if it is very full getting the tank remounted may be a bit of a challenge once the repair is cured well)
    Refs: [CA.com] [eBay.com]
  15. #15
    mike75356's Avatar
    mike75356 is offline CarAudio.com Elite
    May 2005
    pittsburgh
    1,204
    ^^^^ exactly. Unless you have done this before i would not do it unless you or someone thats going to be there helping you had done this before. Its not an easy job and by the time you get everything done and all put back in and you happy most of the time the leak kits dont even work....... Best choice would be just to do it right the first time and get a whole new tank. I have done about 10 diffrent gas tank jobs at my dads shop and trust me your going to need help.
  1. Gas Tank Repair
    By PowerdByGuiness in forum Car Performance and Repair
    Last Post: 10-26-2005, 10:11 AM
  2. gas tank cover rattle
    By HawaiianHaole in forum General Discussion
    Last Post: 03-15-2004, 05:35 PM
