Results 1 to 10 of 10
Reload Thread: 350 engine swap
    Chika-Boom's Avatar
    Chika-Boom is offline Junior Member
    Jan 2005
    Alexandria, LA
    23
    350 engine swap
    hey guys
    Does anybody know how hard it is to do the 350 engine swap on a 1990 Isuzu set up with airbag suspensio??
    saywhat?'s Avatar
    saywhat? is offline satx120, jealous?
    Apr 2004
    H'Burg Mississippi!
    30
    11,175
    Re: 350 engine swap
    prolly pretty tough, dunno if its the same as a mazda, but mazda's u gotta tunnel the cab and everything. theres a guy on SSM "Adragnsuzu" or suttin to that effect, that has a 383 stroker, which i believe is a 350 block stroked and bored.
    Chika-Boom's Avatar
    Jan 2005
    Alexandria, LA
    23
    Re: 350 engine swap
    thanks
    Jan 2005
    pittsburgh
    103
    Re: 350 engine swap
    yes a 350 is simply bored and stroked to 383
    dbhittin's Avatar
    dbhittin is offline Banned
    Apr 2002
    Van...Wa
    34
    5,828
    Re: 350 engine swap
    its a 350 block with a 400 crank and something else
    wErd's Avatar
    wErd is offline Maker of All Good Threads
    Nov 2003
    usa
    5,498
    347 Post(s)
    Re: 350 engine swap
    383 isnt bored? its just a stroker kit, if it was bored over it'd be a little bit bigger than 383.
    refs: viveet, dvrmstrng,velobard,pickup1,rumblebee2
    assassyn's Avatar
    assassyn is offline CarAudio.com Elite
    Jan 2005
    Michigan
    730
    Re: 350 engine swap
    a 383 is a 350 block bored .030 over and has a 400 crank
    TEAM ASSASSYN
    MY Main 4
    1987 Towncar 2 12" L7's 3500w SSL amp, 6-6x9"s
    1970 Monte Carlo 6-6x9 lighting audio, and 2 8" Optimus
    2001 jeep cherokee limited. Infinity Speakers/Amp
    1987 Caddillac sevelle 4x4 ( Looking for 6 bolt 20"s)
    Nov 2004
    Rochester NY
    34
    663
    Re: 350 engine swap
    an izuzu is the same as a s-10 so i dont think that it is that bad. i have a manual to install it in a s-10 if you are intrested
  9. #9
    Jan 2005
    Farmington, NM
    96
    2,475
    45 Post(s)
    Re: 350 engine swap
    Quote Originally Posted by bumpncarstereo
    an izuzu is the same as a s-10 so i dont think that it is that bad...
    if that's true(which i'm not arguing cuz i don't know), and if your bell housing bolts match up to a small block chevy engine, you will just have to buy a conversion kit for an s10. you will need the engine mounts that set the v8 forward and a set of headers to pipe exhaust out of the engine compartment...maybe a bigger radiator and an electric fan if it becomes too tight of a fit...and hopefully your accesories brackets will bolt up to the front of the new engine...then there's the water pump, bolts, hoses,...and can your rear axle handle the power?...crap! maybe you should consider a few minor upgrades to your stock engine.
    --My truck: 2007 GMC 1500 crew cab, Kenwood DNX570HD, DLS front stage, 2x SQ3500s, 2x Sundown NSv3 12"s in blow through, Second Skin deadening.
    --Wife's car: 2013 Chevrolet Impala LTZ, Kenwood DNX470, GermanMAESTRO components on CT125.2, 2x AT10"s on an AT800.1, RF Deadskin deadening.
    --Work truck: 2014 GMC 2500 crew cab, Kenwood DNX470, Kenwood front stage, DD M1A on a pair of American Bass XD10s.
  10. #10
    Tirefryr's Avatar
    Tirefryr is offline PoonTang Addict!
    Oct 2003
    IN
    39
    1,767
    9 Post(s)
    Re: 350 engine swap
    Quote Originally Posted by assassyn
    You sir are correct. 4.030" bore, 3.75" stroke.
    A bunch of SSA stuff.
  1. More HP!!!!!
    By thumpinblazr in forum Car Interior/Exterior Enhancements
    Last Post: 10-23-2004, 04:20 AM
  2. Engine noise/ How much $$ to fix
    By nambo25 in forum General Discussion
    Last Post: 10-02-2002, 11:58 AM
  3. Ok im ready to fix the engine noise.
    By iceberg in forum Wiring, Electrical and Installation Help
    Last Post: 02-05-2002, 01:59 PM
