+ Reply to Thread
Results 1 to 8 of 8
Reload Thread: 2015 Scion XB roof reinforcement
    kgcolby's Avatar
    kgcolby is offline Junior Member
    Jun 2018
    SoCal
    16 Post(s)
    https://drive.google.com/file/d/1JGb...ew?usp=sharing
    https://www.youtube.com/watch?v=r1KEnOQdd-M
    Good afternoon folks, So yesterday I took out my headliner because I know some welds broke. What I didn't know was that the whole roof of the car was actually glued? it's some kind of hard foam glue too that was completely detached so every time I closed my door it looked like one giant subwoofer flex.
    What are some ideas and tips that you guys can toss my way to
    1) re-bond the roof and cross framing together and possible reinforce it with cross steel beams?
    2) thermal control
    3) Sound deaden
    I was thinking JB-Weld my whole **** roof back down JB-Weld
    Reflective roll
    Sound board to dampen noise.
    I was tempted to buy Lizard skin both sound control and thermal barrier and spray my whole roof/floor area. That or just install NVX NVX 90 Mil
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    16,186
    245 Post(s)
    7915 Post(s)
    Re: 2015 Scion XB roof reinforcement
    neither. Just some pl 375 or pl 3x and 1/2 plywood all over the roof and some spray foam on any leftover empty crevices. Shove the plywood in between the welds. You'll have a roof so strong a sledge hammer will have a hard time breaking it. You will also be able to put the head liner back on and your overall bass will hit that much harder.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
    kgcolby's Avatar
    Jun 2018
    SoCal
    16 Post(s)
    Quote Originally Posted by Jeffdachef View Post
    happen to have any videos or instructions on how one would go about doing that?
    What about the aluminum roll? I would like to help resist heat as this cars a **** oven.
    kgcolby's Avatar
    Jun 2018
    SoCal
    16 Post(s)
    Bump -
    Would like to see how people exactly did this task.
    Jeffdachef's Avatar
    Feb 2013
    16,186
    245 Post(s)
    7915 Post(s)
    Quote Originally Posted by kgcolby View Post
    my sienna roof is like yours, I just cut long planks of wood (or a full sheet of wood if your vehicle fits it, mines couldnt and i had to cut mines into planks.) and stuffed it between the crossbraces and hit it with the construction adhesive. If there's a curve at any spot, I hit it with great stuff spray foam, Make sure you cover your car in tarp or something because the foam will drip overnight. Afterwards you can hit it with the heat rejection material, the wood and spray foam should already provide some insulation, another layer would cover you pretty well.
    Tools needed,
    either a skill saw or jigsaw. Giant crowbar (to put in place to just help open the cross braces up to shove the wood in, dont be afraid of the bar's seperating, they can take a lot of force, shove that wood in.)
    I started shoving the wood into the braces from the rear to front, make sure you go through each brace, they literally help keep your wood in place so the adhesive has time to cure.
    If you have to break the long wood plank in two because its too long and its hard to fit through the crossbraces, make sure you fully glue the two wood pieces and make it fully adhere with each other, i'd use pl 8x for this because that stuff is basically concrete.
    kgcolby's Avatar
    Jun 2018
    SoCal
    16 Post(s)
    I did as you said.
    How long till the smell goes away of the adhesive. Been 3 days and still strong.
    Also.. Toyota bracing is soda can thin lol it's not really bending back in shape.
    ---------- Post added at 06:05 PM ---------- Previous post was at 06:05 PM ----------
    I did as you said.
    Jeffdachef's Avatar
    Feb 2013
    16,186
    245 Post(s)
    7915 Post(s)
    I did as you said.
    I did as you said.
    should start to fade the 5th day and be gone in 2 weeks. Crack a window open overnight.
    Did you fill stuff up with great suff foam?
    Chris McNeeley's Avatar
    Chris McNeeley is online now Red Light Ear Rapist
    Jul 2016
    Toledo, ohio
    30
    313
    205 Post(s)
    jeff i swear if you just talked this kid into pl'ing his roof and he fucked it up, i will laugh soooo f*cking hard.
    which adhesive did you use? i demand pics of your violate roof
    Team Bang Hard Ohio Chapter
    2013 Subaru Legacy B-Pillar
    4 Crossfire v4 18s
    4 Crossfire 4k's
    2 Crossfire 2000.4s with Ampere JM1 Dsp
    3 SINGER 270's + MI Solar 115ah 18v + 16.5ah 12v x2
+ Reply to Thread
  1. 2015 Scion XB
    By kgcolby in forum General Discussion
    Last Post: 06-04-2018, 03:02 PM
  2. Roof reinforcement
    By evan4040 in forum Car Interior/Exterior Enhancements
    Last Post: 08-21-2016, 04:45 PM
  3. box for two 10w7s need reinforcement?
    By srch4aresn in forum Enclosure Design & Construction Help
    Last Post: 05-03-2013, 02:41 PM
  4. Sound REINFORCEMENT system
    By 16.6V in forum Subwoofers
    Last Post: 04-11-2007, 03:20 PM
  5. Mach5 for Sound Reinforcement
    By ninjatek in forum Subwoofers
    Last Post: 08-04-2006, 11:36 PM
