+ Reply to Thread
Results 1 to 11 of 11
Reload Thread: Wrap car floor in leather vinyl?
    DarkKnightSM's Avatar
    DarkKnightSM is offline Senior VIP Member
    Mar 2017
    Co Springs
    366
    1 Post(s)
    188 Post(s)
    Was wondering if anyone ever did a vinyl on the floor of a vehicle instead of carpet. Vinyl appears to be a tad challenging to work with, atleast for me. I tried wrapping some wood and plastics in a fake leather vinyl and i had a hard time with the glue drying and now im getting air bubbles in some ofthe peices i wrapped. If i could i would do my whole car in a leather vinyl wrap i would but i need to get the basics down, i think it would be cool to wrap the floor though, although extremely unpractical
  2. Dislikes Chris McNeeley disliked this post
  3. #2
    staan's Avatar
    staan is online now Senior VIP Member
    May 2016
    new orleans, la
    469
    311 Post(s)
    Re: Wrap car floor in leather vinyl?
    just buy new carpet if yours is trash, quick thinking of extremely tacky things to do.
  4. #3
    Mar 2017
    Co Springs
    366
    1 Post(s)
    188 Post(s)
    Quote Originally Posted by staan View Post
    Anyone can go buy new carpet, that wasnt what the thread was about.
  5. #4
    jeepguylv's Avatar
    jeepguylv is offline CarAudio.com Elite
    Oct 2014
    las vegas, nv
    510
    2 Post(s)
    169 Post(s)
    I would never do this for many reasons, but first you would need some high density foam ( preferably 1/2" ), then you obviously need the vinyl, cut the foam into patterns ( where all the flat spots start to curve and you want the patterns to be roughly 1/8" apart from each other ) then you need to cut the vinyl 1/2" larger then the foam patterns, you then need to glue the vinyl to the foam ( do not use spray adhesive from the can it just won't hold, use contact cement from an upholstery supplier and a cheap $20 cup gun from harbor freight ) then you sew the patterns together, now you have to figure out how you want to attach it to the floor, you can spray the contact cement to attach it to the floor which would be a nightmare if you ever had to remove it, so I would glue that cheap carpet you use for speaker boxes or for trunks ( called stretch carpet ) to the back of the foam and get a roll of Velcro from home depot and clean your floor really good and prep it with rubbing alcohol then only use the stiff side of the Velcro and stick several pieces to the floor and stick your vinyl floor to that this way it can be easily remove for whatever reason you need, and trust me this Velcro sticks good so no worries on it shifting.
    cutting your patterns and sewing them together correctly is the most important, otherwise you will never get the vinyl to lay in on the contours without having a ton of wrinkles and bunching.
    this is just one way to do it.
    H/U: 80prs
    FRONT STAGE: 4 crescendo neopro 8" 4 crescendo FT1's
    FRONT STAGE AMP: leviathan III
    ALT: mechman 240
    BATT: 1 odyssey agm under the hood and 3 group31 agms in the back
    POWER CABLE: all 0/2 welding cable
    SUB AMP: crossfire 8k 12v
    SUBS: 2 FI triple stack BTL's at 1ohm
    BOX: 12cube net with 3 8" sono ports
    BEST SCORE SO FAR: 155db @49hz 2500w clamped in the kick
  6. #5
    Mar 2017
    Co Springs
    366
    1 Post(s)
    188 Post(s)
    Quote Originally Posted by jeepguylv View Post
    Oh wow, way more involved then i was hoping, but **** would it look good. Cleaning up spills would be a breeze. The idea came to me when i got tired of lookimg at stains on a carpet. Oh and dog hair! I would finally be able to let my dog in the car
  7. #6
    Buick_66's Avatar
    Buick_66 is offline Member
    Dec 2015
    Kitchener, Ontario
    82
    24
    3 Post(s)
    22 Post(s)
    Some old pick ups used to have vinyl floors...farmers used to hose them out!
    15" Eclipse Titanium, 2 8" JBL GTO 804, 3 way Focal 165VR3, 2 way Focal 165 V30, Hifonics XI Colossus, 2 Hifonics XI Zeus. Visonik 3 way Crossover, Phoenix Gold DD10
  8. Thanks keep_hope_alive thanked for this post
  9. #7
    gmctrucks's Avatar
    gmctrucks is offline Member
    Feb 2011
    Houston, Texas
    52
    7 Post(s)
    I did my headliner on a 1976 Firebird I had it cane out nice.
  10. #8
    Chris McNeeley's Avatar
    Chris McNeeley is offline Red Light Ear Rapist
    Jul 2016
    Toledo, ohio
    29
    212
    123 Post(s)
    I'm stripping my floor to metal, using pl 8x I'm attaching fiberglass mat and using a deadner roller to get smooth and then glassing over it. Will use black 2 part epoxy after as top coat. Vinyl s*cks.
    2013 Subaru Legacy B-Pillar
    4 Crossfire v4 18s
    2 Crossfire 8x's @.33
    1 Crescendo C.2 SQ with a Ampere JM1
    3 SINGER 270's + Limitless 100ah 16v + 25ah 12v
  11. #9
    Hertz Mafia's Avatar
    Hertz Mafia is online now FEATHER RUFFLER
    Jul 2016
    Michigan
    1,793
    36 Post(s)
    1100 Post(s)
    I got a police Tahoe now and it has the rubber ppv issued floor
  12. #10
    keep_hope_alive's Avatar
    keep_hope_alive is online now Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,080
    28
    47 Post(s)
    1502 Post(s)
    i agree upholstery skills would be required to sew the undulations in a proper way. Could look cool if done really well. Carpet is a PITA.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  13. #11
    Jeffro83's Avatar
    Jeffro83 is offline Senior VIP Member
    Dec 2017
    Indianapolis, IN
    213
    92 Post(s)
    I was thinking about just Rhino Lining my floor so I could spray it out like the Old Farmer's used to or they sell three-quarter inch thick rubber mats at Tractor Supply would probably look kind of different but they do have the diamond plate pattern on them and they are tough as hell not sure how it would affect it sound from a system though
+ Reply to Thread
  1. Enclosure wrapped in leather?
    By AmericanFighter in forum Enclosure Design & Construction Help
    Last Post: 04-16-2012, 02:02 AM
  2. Tips for wrapping a box in vinyl?
    By got_focus? in forum Enclosure Design & Construction Help
    Last Post: 06-28-2009, 01:14 AM
  3. car amp in the house
    By Unregistered in forum Amplifiers
    Last Post: 03-24-2003, 10:20 PM
  4. Car Subs in Home Entertainment system.
    By Glassed-Expo in forum General Discussion
    Last Post: 05-21-2002, 02:03 AM
  5. are there any car shows in dayton ohio?
    By auctionboysean8 in forum Car Audio Competition, Shows and Events
    Last Post: 05-09-2002, 07:40 PM
