Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 72
Reload Thread: My system is weighing down the back of my car. What can I do?
  1. #46
    jkok7's Avatar
    jkok7 is offline Senior VIP Member
    Oct 2009
    Dallas, TX
    210
    43 Post(s)
    Re: My system is weighing down the back of my car. What can I do?
    Quote Originally Posted by ahardy17 View Post
    the airbag idea is good, there's also adjustable air shocks. I had some in my grand marquis when I had an outrageously huge box in there, and those could lift the back up about 3 inches with a little air from a compressor. also idk if anyone mentioned it yet or it it's plausible for you, but maybe switch your box to maple or something if it's mdf.
    Never heard of using maple. Thanks for the suggestion.
    Down hur we say Grace & Ma'am. If you don't like that, you aint worth a Damm!
  2. #47
    SounDrive's Avatar
    SounDrive is offline www.soundrive.audio SounDrive is a Supporting Member of the forum!
    SounDrive is a Supporting Vendor of the forum!
    Apr 2013
    Lebanon, TN
    3,072
    20 Post(s)
    1347 Post(s)
    Quote Originally Posted by jkok7 View Post
    You could swap out the battery for ultracaps as well. I upgraded the rear springs and struts in my car to progressive rate cargo springs and it works well. They're about twice as stiff as the stock springs and get stiffer the more they are compressed.
    Owner, SounDrive Audio
    Visit our store at www.soundrive.audio
    Like us on Facebook at www.facebook.com/soundriveAudio
    PLEASE EMAIL ME FOR FASTER RESPONSES - [email protected]
    Dealer for: SounDrive Audio | Synergy Audio | Audio Legion | XS Power | Mechman | SPL-Lab | Taramps | Limitless Lithium | Wolfram Audio | Singer Alternators | Ampere Vibraflex
  3. Thanks jkok7 thanked for this post
    Likes jkok7 liked this post
  4. #48
    Atimm693's Avatar
    Atimm693 is offline Shadetree Mechanic
    Nov 2006
    Up the down escalator
    2,572
    15 Post(s)
    They do make coil spreaders that go between the coils on the spring and spread them out a little. Might give 1-2" of ride height.
    If they make bags that fit your car easily, you don't have to install a compressor and tank. Just run a line with a shrader valve on the end of it from the bags to under the bumper or to the trunk... Pump them up once a week or so. This is pretty common for 1/2 ton pickups that needs a little extra support so they don't squat so bad when loaded down.
    I'm sure you could also have some strut spacers made if the rear struts are like most vehicles. They're just a block of aluminum usually that moves the strut down and lifts the rear of the car. But be weary as it will change the alignment on the rear and it might wear tires or handle funny.
    IIRC there is about 20lbs per sheet of weight savings with Birch plywood. I don't think the juice would be worth the squeeze to make a whole new box and save 50lbs.
    2002 Mazda Protege5
    Kenwood DDX23BT
    Rockford Fosgate 1050S
    2 10" Powerbass M10s
  5. Thanks jkok7 thanked for this post
  6. #49
    jkok7's Avatar
    Oct 2009
    Dallas, TX
    210
    43 Post(s)
    Quote Originally Posted by Tenacious. View Post
    how much do they run?
  7. #50
    jkok7's Avatar
    Oct 2009
    Dallas, TX
    210
    43 Post(s)
    Quote Originally Posted by Atimm693 View Post
    I won't try the spacers based on the risks. I got a wife kids to think about. I wish I would've known abou the birch or maple before just built my new box. LOL
  8. #51
    SounDrive's Avatar
    Apr 2013
    Lebanon, TN
    3,072
    20 Post(s)
    1347 Post(s)
    Ultracapacitors are around $200 for a single bank. I spent $200 on my springs and struts. If you install them yourself, it's really cheap... Of course, I didn't have the tools to do so
  9. #52
    jkok7's Avatar
    Oct 2009
    Dallas, TX
    210
    43 Post(s)
    I know a mechanic. I can have him put them on as I don't know what the heck I'm doin when it comes to springs and struts. So bout $200 uh?
  10. #53
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is offline CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    6,131
    3 Post(s)
    2554 Post(s)
    I bought coil spreaders for 30 bucks ..installed in 30 minutes and i have 130lbs of subs plus a box 160 lbs of batts plus 2 amps amp rack etc ..no sag
  11. Thanks jkok7 thanked for this post
  12. #54
    jkok7's Avatar
    Oct 2009
    Dallas, TX
    210
    43 Post(s)
    Quote Originally Posted by NASTY08IMPALA View Post
    Thanks man. What brand and where did you get em from?
  13. #55
    Aug 2012
    6,131
    3 Post(s)
    2554 Post(s)
    Not sure the brand as therez probably a ton of companies make the ..they all look and work the same..got them at local tint/stereo shop ...just call around
  14. Thanks jkok7 thanked for this post
  15. #56
    jkok7's Avatar
    Oct 2009
    Dallas, TX
    210
    43 Post(s)
    Gotcha.
  16. #57
    CerwinVega_Fan's Avatar
    CerwinVega_Fan is offline Coolest Member
    Apr 2009
    Dallas,TX
    4,395
    3 Post(s)
    773 Post(s)
    Look into get a airlift 1000 kit. They don't cost much at all and easy to install.
    Air Lift 1000 Air Bags for Coil Spring SUVs and Vans | Air Lift Company
  17. Thanks jkok7 thanked for this post
  18. #58
    jkok7's Avatar
    Oct 2009
    Dallas, TX
    210
    43 Post(s)
    Quote Originally Posted by CerwinVega_Fan View Post
    Yeah $90 on eBay. Sounds better than buying coil spreaders and things like that over and over. Thanks mane.
  19. #59
    Apr 2009
    Dallas,TX
    4,395
    3 Post(s)
    773 Post(s)
    No problem man. Glad I could help.
    There are Vids on youtube that will help with the installation.
  20. #60
    av83's Avatar
    av83 is offline CarAudio.com Veteran
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    I have a 2005 malibu that had serious azz problems. Two 100 lb batts, about 180 lbs in box and subs. So about 400 lbs including the amps. I just bought a couple pairs of rubber spring spacers. Bought em at O'Reilly for like $15. Good for a couple inches of lift and I didn't notice a ride difference.
    80prs
    SoundQubed 6.5 Pro's DD T2 Tweeters / new 4 Chan coming / new subs coming / DC Audio 5.0K
    Singer 310 6 phase 2 runs of Monster Cable 1/0 / Exide g78 AGM under hood and XS D3100 in rear
    Plenty of deadener. CCF and fiberglass insulation in doors... thanks to the advice of keep_hope_alive they sound AWESOME! :-)
  1. box size for 1 - 15 for the back of my crx
    By uptwome2007 in forum General Discussion
    Last Post: 03-01-2008, 04:44 AM
  2. No remote wire on the back of my deck
    By neek804 in forum Wiring, Electrical and Installation Help
    Last Post: 10-21-2007, 09:54 PM
  3. Got the back of my tc almost done... Pics...
    By desertheat in forum General Discussion
    Last Post: 10-01-2006, 10:14 PM
  4. I need to find a clip that plugs into the back of my sony cd player
    By animalthug in forum Wiring, Electrical and Installation Help
    Last Post: 07-02-2002, 11:30 PM
  5. Need someone to explain to me what these connectors are on the back of my "Eclipse"
    By Plugedearz in forum Wiring, Electrical and Installation Help
    Last Post: 04-08-2002, 04:06 AM
