Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 31
Reload Thread: anyone know how to tint?
  1. #16
    whitedragon551's Avatar
    whitedragon551 is offline Moderator
    Mar 2009
    IL
    13,604
    43 Post(s)
    1435 Post(s)
    Re: anyone know how to tint?
    Quote Originally Posted by whitedragon551 View Post
    Llumar and Solar Gard are the best tint film.
    You have to have a heat gun, a spray bottle, and a squeegee. You clean the outside of the window and lay the tint over it. Cut around the outer most part edge of the window, but inside the door metal. Then you spray the inside of the window with your squirt bottle, lay the tint on, squeegee the water out and heat shrink it to the window. You cant roll the windows down for 4-7 days depending on how warm it is. If its about 55+ you can get away with 4 days.
    Quote Originally Posted by JoiNt- View Post
    every place ive had do mine do it from the inside, they use an adheasive glue to make sure it stays on the window and yes its HARD to get off or even peal it (i got tickets and had to remove it from my front windows) places dont tint the outside for many reasons....harsh weather conditions that can damage the tint...mud, road salt, acid rain, and from people who can just walk up to ur car and scratch the hell outta the tint cuz its on the outside of the window....the film is only measured and cut from the outside
    EDIT: oh and goodluck going thru a carwash with tint on the outside lol
    Quote Originally Posted by pro-rabbit View Post
    I think there is some confusion on this.
    Dragon is correct on how they trim and form the section using the outside of the window to do so. However, it is applied on to the inside of the window after it is fitted to the glass.
    Please show me where I said you applied tint to the outside of the vehicle? I specifically said you spray the inside of the window and apply the tint. I said you use the outside to cut it properly.
    CA.com FAQ's
    CA.com TOS Agreement
    Forum Rules
    HU: ///Alpine 9887, KCE-400BT, KCE-433IV, KTX-100EQ Imprint, 8Gb iPod Touch
    Front Mids: Eclipse SC6500
    Front Tweeters: Morel made Xtant 28MM Silks
    Subs: Audiomobile Evo 10" TC2+
    Enclosure: 1.1 Cubes sealed with 10 Ounces Poly Fill
    Amp: Audio Systems Twister F6 380 III
  2. #17
    fasfocus00's Avatar
    fasfocus00 is offline doITdaWHITEwayORdoITtwice
    Jun 2007
    New Orleans, LA
    5,618
    3 Post(s)
    459 Post(s)
    i can only speak on my experience with tint. Don't cheap out on brand, Llumar is leaps and bounds better than most of the tint on the market. I went cheap and got the mid grade 3M tint as part of a pre-cut kit on eBay, needless to say it's now completely clear after 2 years. I had Llumar on my car before and it lasted for 8 years, i just wanted it darker so I removed it and got the 3M kit from eBay for $80 shipped (big waste). if you can get a pre-cut kit from ebay using Llumar, go for it. trimming your tint is not that difficult if you can't find a pre-cut kit or if you just decide to use a roll. key to trimming correctly is a good Olfa style blade. shrinking tint takes patience especially if you have never done it. 2 keys to shrinking tint, lots of patience and a good heat gun. next is the application of the tint, this is probably the easiest part as just use a lot of solution to help position the tint. they got a guy (looks like he's 12) that has a youtube channel (tintstuff) and does a phenomenal job tinting, makes it looks like a chic can do it. after watching tons of his stuff I have since tinted a few cars (all my own) as well as added some additional tools.
    Here is my feedback Thread: http://www.caraudio.com/forum/showth...ght=fasfocus00
    "If you ain't cheatin', You ain't trying"
  3. #18
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    I figured that part was over looked so I thought I wold help you out a tad lol.
    I couldn't imagine having tint on the outside part of the window...would be tore up in a week lol
  4. #19
    snoopdan's Avatar
    snoopdan is offline Banned
    Dec 2005
    Louisville, KY
    20,158
    19
    1374 Post(s)
    I actually had tint on the back window on my Fiat years ago due to neon lighting being already glued to the inside of the glass. The tint lasts about a year then starts delaminating....but it can be done!
  5. #20
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    Quote Originally Posted by snoopdan View Post
    lol, leave to you to make it happen.
    I would think a rear window would hold up much longer then a side window though.
  6. #21
    snoopdan's Avatar
    Dec 2005
    Louisville, KY
    20,158
    19
    1374 Post(s)
    What can I say, it was the 90's....Neon in car's was the "in" thing.
  7. #22
    jungstah's Avatar
    jungstah is offline Senior VIP Member
    May 2012
    san francisco
    278
    78 Post(s)
    there are guides all over the internet, but i tried before and it is REALLY HARD. hardest part IMO is when you roll the window back up and have to get it inside the rubber gasket at the top of the window without having the gasket lifting up the edge of your film off the glass.
    Pioneer AVH-P2400BT
    Stock Pioneer 4" components
    Hifonics Brutus BRZ1700.1D
    Two SA-12's
    cruddy prefab ported box----new box otw
  8. #23
    mat3833's Avatar
    mat3833 is offline CarAudio.com Elite
    Mar 2008
    florida
    1,070
    232 Post(s)
    every time ive had my cars tinted ive asked them to pull the door panels off and run the tint an inch below the gasket/scraper thing. never had any place refuse and i always gave them some extra cash for the work. bonus with doing it that way is i never had to wait a week for my windows. just had to wait a day. oh and the ONLY tint that might ever possibly be put on the outside is the sunroof. all others go on the inside after being measured on the OUTSIDE. :-)
    Matt
  9. #24
    rebelfromva's Avatar
    rebelfromva is offline CarAudio.com Veteran
    Jun 2011
    VA
    3,818
    1605 Post(s)
    Quote Originally Posted by mat3833 View Post
    Matt
    I'm assuming it would be a hell of alot easier to do with the panels off? I may try when I deaden my doors
    09 Cobalt LT
    Headunit -Alpine CDA-9887
    Front Stage - PHD FB 6.1 PRO SIX M/B, FB 5.1 m/b, FB 1.1b tweets
    Highs amp -Pheonix Gold Xenon 100.4 & 200.4
    Sub stage - 2 DC M2 LVL 5 12s
    Sub amp - 2 DC 5.0Ks
    Electrical - Singer 270 alt, big 3 0/1 & 12g ofc audio technix, 2 XS d3400s
    Deadener - 80 mill Audiotechnix deadener
    "Trunk hit hard like Kimbo Slice"
    TEAM DC AUDIO
  10. #25
    mat3833's Avatar
    Mar 2008
    florida
    1,070
    232 Post(s)
    idk if its harder or not. i just kno it takes about an hour longer to have them do it. but ive been goign to the same place for 10 years. they will tint my entire windsheild and then do the legal "strip"
    Matt
  11. #26
    urmomsmin3's Avatar
    urmomsmin3 is offline Senior VIP Member
    Jan 2013
    balto
    177
    37 Post(s)
    ive done mine before never will again i bought it pre cut and did it its a pain in the *** better off to just pay 100$ and get it done lol
  12. Dislikes 05trailblazer disliked this post
  13. #27
    05trailblazer's Avatar
    05trailblazer is offline k33p groaning son :)
    Mar 2011
    Dallas,TX
    2,048
    194 Post(s)
    lol its not even hard at all once you get the right tools you'll be succesful. if you want good tint window rolls visit WindowTint.com they have good prices
    HU:Pioneer 80-PRS
    Fnt&Rear Spkrs: 8 Neo-Pro-v.2 soon
    Mid Amp: Sax-50.4& Sax-200.4
    Subs: 4 Sundown Audio 18s Z v.4 tuned at 15hrtz
    Amp: 2*NS-1s
    batts:,xs2500,xs3000 x20
    wire:0g OFC Audio Technix
    alt: 3 HO alts from??? from mechman or singer?
  14. #28
    bumppinKota's Avatar
    bumppinKota is offline Banned
    May 2012
    Center Colorado
    589
    153 Post(s)
    Buy tint in a large amount and practice on your friends car. That's what I did and if you have laid vinyl on a car before its simallar to tint soap and water then Squeegee the water out. My first time was rough. I also find it easier and longer lasting if I remove the door panel and get below the trim
  15. #29
    Mar 2011
    Dallas,TX
    2,048
    194 Post(s)
    some people are just lazy/ or fail at doing things and give up quick.
    HU:Pioneer 80-PRS
    Amp: 2*NS-1s
  16. #30
    May 2012
    Center Colorado
    589
    153 Post(s)
    White dragon has it right but measure inside I tried outside and came up short. Trail and error find what works for you. Just remember you can try and if it ***** remove it clean it and try again.
  17. Likes 05trailblazer liked this post
  1. Does anyone know how to use JBL600.1 Xover?
    By Daniel in forum Subwoofers
    Last Post: 11-28-2004, 07:03 PM
  2. Replies: 2
    Last Post: 07-25-2002, 02:08 PM
  3. Does anyone know how to remove back seats?
    By MrLevir in forum General Discussion
    Last Post: 07-15-2002, 10:05 PM
  4. Anyone know how to remove the dash panel on a 1997 Intrepid...
    By bulldog in forum Wiring, Electrical and Installation Help
    Last Post: 01-03-2002, 06:36 PM
