Page 12 of 23 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 LastLast
Results 166 to 180 of 341
Reload Thread: Bigrick31's Sick New Project
  1. #166
    dbornotdb's Avatar
    dbornotdb is offline Custom Fabricator
    May 2004
    Bradenton, FL
    1,491
    19
    Re: Bigrick31's Sick New Project
    It is even in more pieces than those pics.
    The entire heating and cooling has been stripped from the dash, firewall shaved and I have stripped the rest of the deadening material out of it.
    The bitter after-taste of a poor quality job will last far longer than
    the sweetness of that cheap price!
  2. #167
    Bigrick31's Avatar
    Bigrick31 is offline Carpe Diem
    Mar 2004
    Mid*Cal
    3,557
    Just put 1 coat of white primer on the cab floor will be adding a second coat in an hour
  3. #168
    Bigrick31's Avatar
    Mar 2004
    Mid*Cal
    3,557
    Ok so this weeks progress first up Relocating the battery to the back (well the wiring atleast) and upgrading wiring to 2/0
    I picked up some rubber tubing to protect the wire from heat and objects since its run under the truck. the tubing normally costs about $1.45 a ft but i got a hook up from a friend so i only had to pay $.40 for it
  4. #169
    Bigrick31's Avatar
    Mar 2004
    Mid*Cal
    3,557
    next i masked off areas of the truck so i could primer them with rustolium primer to prevent further rust. luckly all the rust on the truck was jsut surface rust and could be sanded off.
    heres the tool i used for sanding 40 grit grinder disk
  5. #170
    Bigrick31's Avatar
    Mar 2004
    Mid*Cal
    3,557
    me ready for painting
    cab primered white. i chose white because thisy way i can make sure i dont miss any spots and when im ready to deaden it it will be easy to identify which areas need deadening rather than the floor being black.
    font tub primered
    rear of cab sanded down to metal ready for primer
    and hit with a coat of primer
  6. #171
    Bigrick31's Avatar
    Mar 2004
    Mid*Cal
    3,557
    next i began sanding down other areas that were exposed to rain
    rear fender sanded
    cowl vent sanded and part shaved just tacked together for the moment ill have to finish welding it and then grind it down and primer that.
    cowl vent ont he truck
  7. #172
    Bigrick31's Avatar
    Mar 2004
    Mid*Cal
    3,557
    and finally puting the front back together
    door on
    fender on
    both fenders and doors on now
    new radiator in (cost me $130)
    pick of the valves ill be using they are G C 250 extreme valves
  8. #173
    mikey060's Avatar
    mikey060 is offline CarAudio.com Veteran
    Aug 2005
    Calgary, AB
    28
    2,612
    awesome work...wish i had the tools/ money to do something like that
  9. #174
    Bigrick31's Avatar
    Mar 2004
    Mid*Cal
    3,557
    And thats about all for this week. i need to get 2 more headlights for the truck (there are 4 total and i only have 2) i also need to pickup an overflow for the radiator. then finish sanding the bed and attach it then get some wheels and a battery. after that ill get the valves all wiered up along with the compressor and switch box and it should be good to roll!
  10. #175
    Bigrick31's Avatar
    Mar 2004
    Mid*Cal
    3,557
    Quote Originally Posted by mikey060
    thanks
  11. #176
    Mar 2005
    Cullman, Al
    33
    765
    good choice of valves, thats the same ones I had on my hardbody
    *Refs*:LivinLife, Bamaboy, Belunt, SiX
    **New Project**
    92 Honda Civic Hatchback
  12. #177
    Bigrick31's Avatar
    Mar 2004
    Mid*Cal
    3,557
    Quote Originally Posted by ilaydit
    yea my buddy hooked me up with a great deal on them i heard they were pretty nice i especially like the way they are wired and how the have protection for the wiring
  13. #178
    Eldorado's Avatar
    Eldorado is offline Banned
    Dec 2005
    So Cal
    4,974
    250psi...you know what that means
    Nitrogen !
  14. #179
    skeptikal's Avatar
    skeptikal is offline Hold the wheel and drive skeptikal is a Supporting Member of the forum!
    Jul 2004
    Indiana, US
    4,066
    22 Post(s)
    This truck is going to be f*cking sick... Rick how much do you estimate this project costing?
    2005 Dodge Ram Quad Cab
    Pioneer DEH-80prs
    Image Dynamics X-65
    Image Dynamics XS-28
    PPI 900.4
    Wolfram 1500.1
    Sundown Audio SA-12 D4 (x2)
    Noico deadener
    NVX wiring
  15. #180
    Bigrick31's Avatar
    Mar 2004
    Mid*Cal
    3,557
    Quote Originally Posted by Eldorado
    Nitrogen !
    im already thinking about it!
    skeptikal This truck is going to be f*cking sick... Rick how much do you estimate this project costing?
    well so far
    $600
    $200 for valves
    $130 for radiator
    $150 in misc parts/tools
    so so far its about $1080 i got some wheels hopefully for about $150 shipped and i need to spend another $200 on parts untill it will be fully drivable $1380 for a fully functioning bagged and bodydroped truck. however ill be putting a lot more into it with stereo equipment changing out the rear end and possibly suspension. paint job and so on. im not sure the cost of the finished product Mainly because i dont even know what finished will be for this truck. my ideas keep changing/evolving all the time so its really hard to say. im trying to just take it step by step and think out my next move before i do it so i can get teh trucks prioritys straight.
  1. Bigrick31's 04 Sliverado Project Log
    By Bigrick31 in forum Car Interior/Exterior Enhancements
    Last Post: 02-15-2008, 10:59 AM
  2. Replies: 4
    Last Post: 06-29-2005, 08:12 AM
  3. Fiberglass Box Project - Plexiglass and 2 Tv's **PICS**
    By bobo244 in forum Enclosure Design & Construction Help
    Last Post: 06-14-2005, 12:12 AM
  4. My relay box construction, use as a guide if you wish ($26 project)
    By ChefJoe in forum Wiring, Electrical and Installation Help
    Last Post: 02-02-2003, 12:35 PM
