Page 8 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 106 to 120 of 128
Reload Thread: Fiberglass How To's
  1. #106
    gangstajpimpin's Avatar
    gangstajpimpin is offline Senior VIP Member
    Jul 2008
    Las Vegas, NV
    251
    Re: Fiberglass How To's
    www.uscomposites.com
    bout 35/gal
    My Feedback Thread
    Refs: datboiroy, VTECnicalAccord, funkpnut, Goindef154, davidtemple
  2. #107
    bad03ranger's Avatar
    bad03ranger is offline Get Some *****
    Mar 2008
    Reidsville, North Carolina, United States
    308
    Can i glass my MDF enclosure?
    Do i wrap the enclosure in fleece then glass or can i just spread body filler over it and smooth it down and paint it
  3. #108
    j1b1e1's Avatar
    j1b1e1 is offline Senior VIP Member
    Apr 2008
    Alabama
    267
    Old threads crash and burn. Only one link still works on the first page. Anyone got any good site for fiberglass. I'm trying to shed some weight and gain some box volume for my two 13w7's in my trunk... Thanks!
  4. #109
    BassMechkanic's Avatar
    BassMechkanic is offline the OLD in Old School
    Apr 2009
    Tampa, FL
    412
    1 Post(s)
    22 Post(s)
    post 106
  5. #110
    Oct 2009
    MOBILE, AL
    37
    Quote Originally Posted by j1b1e1 View Post
    Though I have only built only about 30 or so parts for cars out of fiberglass I can speak from an educated boat builders perspective. I have read through most of this thread and I gotta say, most of the techniques will work I wouldn't call them proper fiberglass techniques from my perspective. If you really want to know how to properly lay up fiberglass you should read
    http://www.bateau2.com/howto/epoxy_basics.php
    you say you want to shed some weight? Well, I am going to go against the grain in saying this but here goes...... and this is how I build all my fiberglass parts and I will build my next enclosure using this method. Because I have a light weight sports car, adding a 100lb subwoofer enclosure is out of the question! I'll kind of do a step by step which will use no fasteners.
    In weight savings you don't need to use 1/2 or thicker MDF, you simply need to build a "composite" enclosure. You will want to use 1/4" high grade ply. What your looking for is as few voids as possible. You know those football biscuits you see in plywood, well that was once a void in the lamination. High grade plywood will have 5 or more layers, this link is for example purpose only: http://plywood.boatbuildercentral.com/
    Your likely going to make the baffle out of fiberglass with only wooden rings, the sides and bottom will likely be made of ply. So, make all your cuts, lay out the box as if you were about to put screws in it; only drill 1/8" holes about every 4 to 6" apart and about 1/2" from the boards edge. You will then simply use zip ties, cable ties, copper wire, or fishing wire to "stitch" the box together LOOSELY. GAPS ARE GOOD!!! I would look for a gap no less than 1/8" what you can do is use your drill bit as a spacer, or popsicle sticks work great. Once you have the box stitched up your going to mix a paste of epoxy and a filler to the consistency of peanut butter. You want it to be ferm so that it will hold its shape. Using a ziplock bag, cut the corner and squeeze out the mixture between each cable tie. Then shape to make an inside radius. You can make a custom tool out of paint sticks, or use a tongue depressor. Once your "fillet" dries enough so it still can be shaped you can then pull out the ties and fill all the gaps around the inside. Your looking for about a 1/2" radius. You can put tape each side of the joint before putting in your epoxy and filler so that clean up will be much easier. Once its dry just pull up the tape.
    Structural fillets should be made of wood flour or milled glass fiber. I like wood flour its as strong as nails, VERY hard to sand, holds its shape well.
    http://boatbuildercentral.com/prodde...prod=E_woo_1lb
    Now that your fillets have dried you can then use fiberglass tape. I like 6" biaxial 6oz or heavier. I use an over lap lay-up, that is; 4" of the tape will be on one side 2 on the other side of the joint. Your next layer will then be 4" over the top of the first 2" and 2" over the 4." YOU DO NOT, have to wait for your fillet to dry completely. You can work "wet on wet" once the fillet is tacky your ready to lay tape. Wet your fiberglass out.
    NOW here is where I'm going to get flamed. YOU DO NOT have to saturate the cloth. Pour little pools of resin onto your fiberglass tape. Using a squeegee PUSH the resin into the cloth. This will push out any bubbles and bed the fiberglass into the plywood. What your looking for is a wet gauze look. The fiberglass weave will not be filled at this point! This joint will have a peal strength 100 times stronger than the fiberglass work your used to seeing.
    Still working wet on wet and on the inside of the box your going to lay one layer of wide fabric. It will be the width of the panel from your fillet to the boxes edge. You can use one continuous piece, starting at one corner and going all the way around the box back to your starting corner. Let me back up a second. You can go ahead and glass the back of the box then do the sides. Again I like 6oz or better biaxial fiber glass http://boatbuildercentral.com/prodde...od=E_bias_1708
    Using the same method as with the tape. Pour little pools of resin onto the panel your working with and push the resin into the fiberglass. Again, your looking for something that looks like wet gauze, and your weave WILL NOT be filled with this lay up. Once this process has fully dried and within 24 hours your going to mix a slurry of resin and a filler. Your wanting to build a light weight box so use "MICRO BALLOONS" http://boatbuildercentral.com/prodde...od=E_mic_.25lb
    The consistency your looking for is ketchup or mayonnaise. Pour that into pools and push it into the weave but only this time your filling the weave. You will only be able to work on one panel at a time until its dry enough that it does not run or sag.
    By this time you will have the inside of the box completely laid up. You can now move to the outside of the box and use the same lay-up schedule as the inside. You can also at this time mold your baffle into or onto the boxes face. Also, this type of enclosure should use dividers or interior supports.
    Now I assure you that building an enclosure as described above will not only be less weight but MUCH stronger than using 1/2 or greater MDF. I believe in it so much so that I would be willing to pay a bounty if proven other wise. IF the fiberglass lay-up is per the above directions.
    I've seen on every car audio board the improper use of resins. Even if you don't build a box as per the above directions; if you just use the method for wetting out your materials you will not only use FAR less resin but the end results will be a much stronger product.
    DISCLAIMER: I take various medications, due to which if any misspellings and punctuation's are found get over it..... lol... I do hope this helps someone, if nothing more than to save people money on using the proper amounts of materials. Lets stop these over saturated fiberglass lay-ups. Again, the links provided are for materials description only and not meant to be an ad. I have however, purchased many thousands of dollars worth of fiberglass and resins from them. They are fine people.
  6. #111
    godhatescivics's Avatar
    godhatescivics is offline 2 18s in a cobalt what?
    Apr 2008
    cleveland ohio
    33
    2,613
    REFSthee michael hughes crxbumpin ssackett rustywca pshcyoacoustics roadquakerebel s-saudio cruisin22z bumpinbuick atsaubrey
    TEAM SUNDOWN
    TEAM LETHAL BEATS
  7. #112
    j1b1e1's Avatar
    Apr 2008
    Alabama
    267
    Wow, lots of info... I'll read it in the morning. Thanks!!!!!!!!!!!!!!!
  8. #113
    GI JOEY's Avatar
    GI JOEY is offline Paid 4 by ur tax $
    Feb 2006
    Amarillo, Tx
    619
    how would you secure a 3/4 mdf box to a fiberglass bottom? Not sure how to attach the fiberglass.
    New Build 2001 Silverado 2500HD
    JBL Crown BPX2200.1, RE SE 10" quartet, .25 fiberglass, .75 mdf box. 5.2 cubes tuned to under 32 with 3 4" aeros.
    Truck 96 Silverado blowthrough
    JL W6v2 12" X 4, JL 1000/1 X 2, 141.5 DB drag 1st comp and no testing 148.8 db @ 53hz Outlaw
    Bought from: wone
  9. #114
    nineball's Avatar
    nineball is offline too many toys...
    Feb 2008
    home
    1,921
    11 Post(s)
    more fiberglass
    Quote Originally Posted by eharri3 View Post
    I have 4 12s getting 2K watts rms and my front stage is 4 Walmart JVC coaxials running off 16 watts rms of head unit power. My sub sounds fine but my mids and highs don't sound very clear and start to distort long before my subs do. Anybody know why? Any suggestions?
  10. #115
    Oct 2009
    MOBILE, AL
    37
    your going to need to make both surfaces mate together
    as closely as possible. If they don't touch then your going
    to need a glue or bed of resin to sink it into. To make said
    glue...
    I'm guessing we are talking about polyester resin? Your
    going to need a thickening agent like, milled fiberglass fiber,
    micro balloons, or a very strong glue made of epoxy and
    wood flour. The factor which determines is what is the dis-
    tance between the bottom of the board and fiberglass? This
    will determine how thick and what the glue will be made of...
    If the surfaces mate together with very little gap then I would
    use milled fiberglass fibers mixed with resin. Make a nice bed of
    the mixture and set the MDF into it. Then you can glass over it.
    If you would like, you can PM me or mail @ [email protected]
    I can supply you with links with a step by step. If I can find them
    through WEST SYSTEM web site.
    I hope I was able to help
  11. #116
    Apr 2009
    Tampa, FL
    412
    1 Post(s)
    22 Post(s)
    you can also use saw dust, mix that into your resin, makes it thicker like a paste, after that sets then put a couple layers of matt and resin
  12. #117
    nineball's Avatar
    Feb 2008
    home
    1,921
    11 Post(s)
    Quote Originally Posted by BassMechkanic View Post
    i would use duraglass before that
  13. #118
    GI JOEY's Avatar
    Feb 2006
    Amarillo, Tx
    619
    How many layers do you think I should do? I am only doing the bottom of the enclosure in fiberglass, I have read 7 and I have read it depends on the size of the box and the subs your running. Since it is the bottom it will have addtional support from the floor of the truck. I have also seen that you get higher spl numbers from a box that flexes a little.
    Bought from: wone
  14. #119
    nineball's Avatar
    Feb 2008
    home
    1,921
    11 Post(s)
    you have seen wrong. flex is your enemy. you need enough fg so that you have NO flex. if you can stand on the fg section and it flexes you need more.
  15. #120
    GI JOEY's Avatar
    Feb 2006
    Amarillo, Tx
    619
    Well the box is solid as hell. It is about 55 inches wide and I can barely get it to budge by lifting one side and pushing down on the middle. This is about 7 layers and 2.5 gallons of resin. With the rest of the box/ mdf it should make the bottom even more rigid. I used the bottom and top layers with fiberglass cloth and the middle layers are fiberglas matt. Its about 1/3 inch thick as of now.
    Think this is enough?
    Bought from: wone
  1. Fiberglass Help
    By BDIDDY in forum Enclosure Design & Construction Help
    Last Post: 07-27-2003, 03:06 AM
  2. the sound of fiberglass
    By iammiowngod in forum Enclosure Design & Construction Help
    Last Post: 07-24-2003, 05:03 PM
  3. Fiberglass Box
    By tehon3299 in forum Enclosure Design & Construction Help
    Last Post: 07-23-2003, 10:58 AM
  4. Fiberglass Help
    Last Post: 07-19-2003, 08:13 PM
  5. Fiberglass resin
    By LuNaTiC in forum Enclosure Design & Construction Help
    Last Post: 07-11-2003, 06:27 AM
  • You may not post replies
