Page 6 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 76 to 90 of 128
Reload Thread: Fiberglass How To's
  1. #76
    taosd's Avatar
    taosd is offline Member
    Aug 2002
    Canada
    111
    Re: Fiberglass How To's
    Do I need to get resin with wax in it? I talked to my cousin, who works at a boat shop, and he mentioned that I would need resin with wax in it. Why is this?
    HU: Pioneer Premier F90BT
    AMP: JL 500/1v1
    SUB: JL 12W6V2 D4 @ 2 Ohms
    CAR: 2005 Nissan Maxima SL
    BOUGHT FROM: dropped_mazda, qcsfinest704
  2. #77
    NMBR1SPT's Avatar
    NMBR1SPT is offline I Might Be Your Dad.....
    Jul 2006
    Orlando, Fla.
    1,748
    28 Post(s)
    correct me if I'm wrong to fiberglass my dash and door panels... all I need to do is sand lightly wipe it with acetone and put resin and then a thin layer of fiber sand then resin till smooth..... same for door panels and roof liner????
  3. #78
    nYc.kablamO's Avatar
    nYc.kablamO is offline Member
    Jul 2006
    nYC
    60
    I found the easiest way to do a glass job is with rollers. I found them at a marine supply store out here (for you guys that dont like ordering). The fiberglass roller has little bristles that permeate the glass and take out the air bubbles. It kind of makes the layers 'tighter' also. Theyre available in all different sizes and small stuff for contours etc. theyre reusable too.
    Witht he right tools youll cut your work time in half and end up with a better quality piece. I used to dab the paint brush and guesstimate by resin/mekp mixture too. Now I use a big plastic pitcher with a lid and spout, mix the resin using one of those harderer bottles so i get the right ratio (cmon who hasnt mixed it too hot and ended up with a cup of jelly and a half done layer i have!)..then pour with one hand and roll with the other. Alot less mess and alot less time.
    with the filling part i like to spread on like 1/4" of duraglass (fiberglass putty, short strand). I dont mix it hot because if it hardens right away you cant file it. A putty file is only tool that should be used to knock down the filler. Anything else and the piece will look wavy. for those that dont like ordering you can find them at autozone, pep boys etc.
  4. #79
    Frankensuby's Avatar
    Frankensuby is offline I'm in Ur F0rumZ
    Aug 2006
    PA
    911
    K, I need help.
    I'm in the middle of an enclosure build, and I should be ready to fiberglass by tomorrow night. I am building a 75% MDF enclosure, and I need to use fiberglass to allow the rest of the box to sit flush with the walls of my trunk. How do I go about applying the fiberglass to the box? What special things should I do...IE....do I need to sand the edges by the hole I am going to fiberglass, or do I need to use a structure like chicken wiring to make a specific shape? Is it a bad idea to leave air inbetween the box and the fiberglass shell, even when the enclosure is sealed?
    Thanks for any help,
    ~Levi
    2006 Subaru Impreza 2.5i
    System Currently:Speaker Amp|Phoenix Gold Xenon 100.2 Sub Amp| Phoenix Gold Xenon 600.1 Deck| Pioneer DEH6800MP Frontstage| Alpine SPR-17LS "]Sub| Phoenix Gold Xenon 10"
    Refs from Buyers:
    Refs from sellers: Dre2390
  5. #80
    BassAddictJ's Avatar
    BassAddictJ is offline CarAudio.com Veteran
    Apr 2005
    FL
    12,949
    1 Post(s)
    1 Thread(s)
    153 Post(s)
    for something simple like some basic kick pods or (what i plan on trying to do with my first fiberglassing project ever) making a case for a 7 inch LCD that the old case vroke for, how much would supplies cost me (ballpark guess)?
    Past:
    Pioneer Avic N5 Navi + CD-UB100 USB Adapter. Circa '96 PPI Ax606.2 in BLACK with 2 black graphic spacers.
    CDT DRT-25 1'' Silk Dome Tweeters / CDT ES-04 4'' Midranges / RE Audio XXX 6.5'' 2ohm Neo Mids In Glassed Kick Pods
    American Power Systems 240amp H.O. Alty / (2) Deka 8a31, 1/0 front to back.
    Random Prototype 3k @ 1ohm. TRF/PSI 8 layer 4in coil Monster 15 in 3 cubs @ 33Hz / Raammat 40sqft in the trunk.
    NEW SETUP IN THE WORKS
    Quote Originally Posted by Haunz View Post
    You could put 12V to my balls and clamp my dick to get 3kW+.
    Quote Originally Posted by Slayerx View Post
    Glad this got bumped so I could fap to it again.
  6. #81
    krstofer's Avatar
    krstofer is offline Member
    Jan 2007
    NJ
    36
    http://web.njit.edu/%7Ecas1383/proj/main/ --- bad link
    http://www.caraudioresources.net/technical.html --- looks like domain parking
    http://web.njit.edu/~cas1383/glassing/--- bad link
    http://www.eatel.net/~amptech/elecdisc/fibrglas.htm --- bad link
    http://www.geocities.com/stevebang2000/car-audio.html --- Looks like this site only sells custom kits not how to make them.
    Out of the links in the first post, it looks like this one is the best.
    http://chris.pfharlock.com/glass/
    Might want to update the post. Thanks for the links.
    Kenwood KAC-8401 amp Kenwood 3-way 5 1/2 Speakers Kenwood Excelon KVT-815DVD
    Kenwood Excelon Music Keg Rockford 6001bd
    <recently blown>Power Acoustik FUBR-10 Sub</recently blown>
  7. #82
    PowerNaudio's Avatar
    PowerNaudio is offline the power of audio
    May 2005
    killeen, TX
    1,876
    Quote Originally Posted by krstofer View Post
    [url]
    on this link http://www.geocities.com/stevebang2000/car-audio.html
    the guy is also providing a couple steps by steps of the proses he uses to get the enclosure to a finish product so it may provide a source for ideas on how to build enclosures for the more advanced.
    AIM:powernaudio,yahoo:powernaudio,email address: powernaudio at gmail.com contact me if you need any help.
    Portafolio
    builds
    more builds
    saturn l300 build
    videos
    References:Mr.Loki,dubbinjet,trucktoy,fancynapkin, netherland,Datdudedru,hockey1playa33,
    donbon86,PhatTonyDeMar,Saywhat?,vosschs,ChuckKlock er,budlightman361,baseballer1100,elslug,
    bdogg321,projectpat06,eatank,BodegaBay,playboyclic ,cbrrocketrdr,iwanturmags,pboulos,DaBeholder,
    bholtmeier,beatthis27,OldManTod,MTXman,Gianotti.
  8. #83
    phantom240's Avatar
    phantom240 is offline ALL YOUR INTERNETZ
    Aug 2005
    Southeast Louisiana
    30
    5,725
    13 Post(s)
    It doesnt. You need glass to apply glass.
    Quote Originally Posted by 18lexusowner View Post
    If your not a liberal cockbag than it's funny.
    Refs: Lostsoul, DaGh0st, Jadeaudio, mhschiefs806, revrider1, GavinVoy, maximpakt
  9. #84
    May 2005
    killeen, TX
    1,876
    Quote Originally Posted by Soler View Post
    how does applying fiberglass onto an mdf box without mat or clothe work
    did you mean "how does applying resin onto an mdf box without mat or cloth works?"
    if yes, then you justs mix with the proper ration of hardner to resin, then using a brush or roller, apply it to the enclosure or mdf panel, just like you would on to fiberglass mat or other surfaces or materials.
    fiberglass= A material made of extremely fine glass fibers. formed into mat, cloth, power, etc.....
    resin= A thermosetting resin that is made of an unsaturated polyester and often used in reinforcing Fiaberglass and laminating
    if you mean the string or powder fiberglass, you need a special gun for the string fiberglass that will tear the fiberglass up at the same time it sprayes it on to the work area.
    the fiberglass powder or beads, "i forgot the actual name" can be mixed with resin and applyed with a brushed or rolled on the work area. mostly used as a filler to increase density.
    "there allot more detailed info on the subject,if you just google your question for more results"
    Portafolio
    builds
    more builds
    saturn l300 build
    videos
  10. #85
    somekook's Avatar
    somekook is offline only 15"s
    Jul 2003
    Daytona Beach, FL
    30
    1,178
    yea this is the most helpfull link i saw on this thread.
    also, in the body shop i work at, and prety much all body shops, they use this plastic sheeting stuff, to protect a window or what have you from dust and sparks and **** flying into the car. that plastic masking works like awesome for laying down on your trunk floor or wherever youre about to apply fiberglass (instead of blue painters tape or masking tape). i dont know if a whole lot of people use this method yet, but theyre about to. test your plastic sheeting first to make sure resin doesnt eat through it.... that would ****.
  11. #86
    nate2587's Avatar
    nate2587 is offline .........................
    Mar 2007
    Lambertville, MI
    3,771
    Quote Originally Posted by MikeofTulsa View Post
    Since the other one disappeared......Feel free to post links.....no coments needed....just links please....please check for dead links and make sure they have not already been posted....thanks
    http://www.sounddomain.com/id/the1wagsjlguy
    http://www.sounddomain.com/member_pa...page_id=338498
    http://www.sounddomain.com/id/jeep98
    also my site...hope to have some glassing links on there soon...
    http://www.sounddomain.com/id/goddyd4me
    below is a quick and easy way to make a circle jig for a router.....for perfect circles its a must....
    enjoy
    lots of links are dead on this thread
  12. #87
    Drunkship's Avatar
    Drunkship is offline Member
    Nov 2006
    Marlboro, MA (near Boston)
    144
    Hello, my buddy wants to put a subwoofer in his car and wants it to be as light as possible while looking hidden.
    I suggested fiberglassing the spare tire well and puttin' the sub in there. Are there any links (a lot of links in these 6 pages are dead) showing how to go about doing this, step-by-step?
    Also, would doing that be a lot lighter than having a regular sealed/ported enclosure?
    The last question I have is, how would we go about giving the subwoofer the right amount of volume? With a regular enclosure you can just measure L x W x H, so we'd have to find the volume of a half circle (4/3 x pi x r / 2)?
    eBay: xVeritas37x
    Refs: BIG-SMOOTH, CrazedCat, zx12
  13. #88
    Zakerid's Avatar
    Zakerid is offline Senior VIP Member
    Apr 2007
    At home
    387
    don't know if this link was posted but it is a great tutorial
    http://www.gadrivers.net/~dwicker/fiberglass.html
  14. #89
    UpNCommin's Avatar
    UpNCommin is offline Member
    May 2007
    Austin, TX
    146
    i got everthing but once u guys said BAFFLE.. i was baffled.. .lol can anyone tell me what A baffle is?? also to fiberglass the dash wouldnt it juss be easy sand the plastic and then juss lay a fleece on top of that, hot glue it to the edges and then fiberglass away???
  15. #90
    May 2007
    colorado
    69
    13
    what is all involved in making a glass dash?
    Front- 5" alpine type-s
    Rear- 5x7" alpine type s
    Subs- 2 Kicker 12" cvrs
    Box- 4ft^3 tuned to 32hz
    Headunit- JVC KD-G720
    Ipod adapter
    Amps- Crossfire 400w 4channel
    Rockford Fosgate 6001bd
    Wire- 4gauge
  1. Fiberglass Help
    By BDIDDY in forum Enclosure Design & Construction Help
    Last Post: 07-27-2003, 03:06 AM
  2. the sound of fiberglass
    By iammiowngod in forum Enclosure Design & Construction Help
    Last Post: 07-24-2003, 05:03 PM
  3. Fiberglass Box
    By tehon3299 in forum Enclosure Design & Construction Help
    Last Post: 07-23-2003, 10:58 AM
  4. Fiberglass Help
    Last Post: 07-19-2003, 08:13 PM
  5. Fiberglass resin
    By LuNaTiC in forum Enclosure Design & Construction Help
    Last Post: 07-11-2003, 06:27 AM
  • You may not post replies
