Page 3 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 31 to 45 of 128
Reload Thread: Fiberglass How To's
  1. #31
    ramos's Avatar
    Dec 2001
    Virginia
    48
    10,302
    5 Post(s)
    Re: Fiberglass How To's
    Fiberglast.com or you can check your yellow pages for fiberglass supplies.
    5 % equipment
    90 % install
    5% beer
  2. #32
    AJ Quick's Avatar
    AJ Quick is offline Junior Member
    Jun 2004
    Minnetonka, MN
    I have learned so much from the other tutorials and pictures found around here. I have chronicalled my own fiberglassing expirenece in a tutorial found here:
    http://www.ajquick.com/cars/tutorials/fiberglass.php
    http://www.AJQuick.com/ Fiberglassing Tutorial!
  3. #33
    ss3079's Avatar
    ss3079 is offline Eh Dere Hi Dere Ho-ser
    Mar 2002
    Up North
    22,571
    ^Awesome
    - Steve
    Moderator
    2007 Chrysler 300C
    2005 Chevrolet Silverado 2500HD Crew Cab
    Optima, Volant, Bully Dog, Corsa, Gibson, Powermaster, California Super Trucks, Fox Racing, Airaid
    Alpine 7998, Alpine HDA-5460, Arc Audio MEQ-30, (2) Adire Audio Shiva, Image Dynamics CD-2COMP, Image Dynamics CX64, (2) Image Dynamics ID8V.2, Arc Audio 2100CXL, Arc Audio 4150CXL, Arc Audio 1500D-R
    2006 Kawasaki Ninja ZX14
    Quote Originally Posted by DJGTSR
    I dont mean to be rude, but what is the highest level of education that you finished?
  4. #34
    jay99's Avatar
    jay99 is offline Member
    Jul 2004
    Canada, ONT
    54
    anybody know how to fiberglass a dash?
  5. #35
    MikeofTulsa's Avatar
    MikeofTulsa is offline The one and Only!
    Feb 2002
    Tulsa, OK
    20,859
    36 Post(s)
    a dash would take alot of time.....but first thing you got to do is take the old dash off and then make a fram for the new one.....and make sure all the holes match up for the screws and such.....very difficult project and very time consuming
  6. #36
    DBfan187's Avatar
    DBfan187 is offline Supa's mom was here!
    Jan 2003
    Poolside with Supa's mom.
    46,452
    1 Post(s)
    RESIN!
    It burns!
    I was dumb again, didn't wear any protection as usual.
    How do I get it off. It burns.
  7. #37
    req's Avatar
    req
    req is offline am a mod.
    Jul 2004
    Syracuse, NY
    28
    15,426
    21
    acetone. (it usually says "EPOXY\FIBERGLASS RESIN THINNER" under the word ACETONE that is in bold large letters.
    got a huge glob of resin off my armhair in a matter of seconds. just rub it as if it were soap, and it dissolves off.
  8. #38
    DBfan187's Avatar
    Jan 2003
    46,452
    1 Post(s)
    Ah thanks. It did the trick. Just a little sticky now
  9. #39
    bboybrown's Avatar
    bboybrown is offline Junior Member
    Jun 2004
    sactown
    28
    couldnt u just keep adding fiberglass resin to the fleece instead of using fiberglass matte. i am very new to fiberglassing, so please excuse my newbiness
  10. #40
    UndercoverPunk's Avatar
    UndercoverPunk is offline Super Mod
    May 2004
    Dayton, OH™
    15,649
    Quote Originally Posted by bboybrown
    That would make it VERY brittle, the matt adds strength, not just hardness...
    Caraudio.com - Where the average member couldn't wire a SPST toggle if they had to.
    More proof.
    Quote Originally Posted by Andrew_as View Post
    I need a program or something that will help me find mounting depth without having to build box and such...
    No, Andy, I'm sure the context is fine.
  11. #41
    Nsanityownzu's Avatar
    Nsanityownzu is offline Junior Member
    Nov 2004
    Fort Lauderdale
    for the "normal cloth" you want something really absorbant and strechy like fleece or old sweat pants and then you put the fiberglass on that mold
    Now according to Steve brown ( one of the makers of the Alpine Civic, RSX, and Cooper ) you should use very thin material..because thick material as a much higher chance of cracking compared to thin material...just my input
  12. #42
    rzhawk73's Avatar
    rzhawk73 is offline Junior Member
    Nov 2004
    littleton, co
    you can but you need to add a filler to it Aerosil-Cabosil works well.
    i would add it to the inside of the box that way you dont need to sand as much
    filler
  13. #43
    TimberJon's Avatar
    TimberJon is offline Member
    Feb 2004
    LA, CA
    136
    You should use 2-4oz fiberglass mat, and, using latex or nitrile gloves, (not medical grade) soak it in fiberglass by using a paint roller to roll resin across a piece of cardboard, then put the mat over the wet patch, and generously roll more on, then pick it up and put it where you want it. After laying 1-layer everywhere, start making 2-layer patches and place them everywhere. For a strong fiberglass job you would want a minimum of 4 layers, more if you feel its necessary. Do NOT put a little more catalyst than is told by the manufacturer of the resin kit. Ive seen guys catch their trunks on fire. Overcatalyzed resin can reach up to 500 degrees.
    I strongly suggest buying Smith Fibercast resin kits. They come in small kits too for Kickpanel installs.
  14. #44
    TimberJon's Avatar
    Feb 2004
    LA, CA
    136
    I also suggest using Vulkem sealant in addition to any Dynamat or other sound dampening materials. vulkem is caulk style so you can squirt the goop anywhere you need it, and its runny enough to fill certain areas. Good for filling holes and loose areas of your trunk, behind your liscense place, around screws, to use as a barrier against moisture, for holding many layers of dynamat together, and for sealing sub enclosures. Vulkem comes in white and black colors. Nobody really knows about it because its used in construction and the petroleum industry.
    Works great as a sealant. Dont fill your walls with it however, itll get heavy. Better than cilicone. Its thick and pasty, but wet, so you can smear it around with a latex glove wherever you want it. Good for making smooth transitions.
  15. #45
    req's Avatar
    req
    Jul 2004
    Syracuse, NY
    28
    15,426
    21
    Quote Originally Posted by TimberJon
    why not just use some kind of evercoat filler\kitty hair for smooth transitions?
    i suppose it would work as a glue\sealer in a deadenening job.
    mind giving a link to this stuff?
  1. Fiberglass Help
    By BDIDDY in forum Enclosure Design & Construction Help
    Last Post: 07-27-2003, 03:06 AM
  2. the sound of fiberglass
    By iammiowngod in forum Enclosure Design & Construction Help
    Last Post: 07-24-2003, 05:03 PM
  3. Fiberglass Box
    By tehon3299 in forum Enclosure Design & Construction Help
    Last Post: 07-23-2003, 10:58 AM
  4. Fiberglass Help
    Last Post: 07-19-2003, 08:13 PM
  5. Fiberglass resin
    By LuNaTiC in forum Enclosure Design & Construction Help
    Last Post: 07-11-2003, 06:27 AM
  • You may not post replies
