Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Reload Thread: Ever Wonder the correct procedure for your 1/0ga Crimp Rings?
    Bumpin' Yota's Avatar
    Bumpin' Yota is offline CarAudio.com Elite
    Mar 2003
    FL
    34
    953
    Well first you need some stuff.
    LARGE bolt cutters
    1/0 ga wire
    1/0 ga crimp terminal
    Propane/butane torch
    Silver Solder
    SHARP knife
    1 volt = [1(kg)(meter^2)] / [(second^3)(ampere)]
    1 watt = 1 joule / second
    1 watt = (1 Newton)(meter) / second
    1 watt = [1 kg/(second^2)] (meter) / second
    simplifying we find:
    1 watt = [1(kg)(meter)] / (second ^3)
    therefore:
    P = (I)(V)
    1 watt = (1 volt)(1ampere)
    1 watt = ( [1(kg)(meter^2)] / [(second^3)(ampere)] )(1 ampere)
    1 watt = [1(kg)(meter^2)] / (second^3)
    And that is WHY Power is in the SI units of Watts. enjoy!
    Mar 2003
    FL
    34
    953
    Re: Ever Wonder the correct procedure for your 1/0ga Crimp Rings?
    Strip the 1/0 with your sharp knife. I usually make a ring around the wire then connect the cut ring to the end of the piece I want to take off.
    Mar 2003
    FL
    34
    953
    slide ring over stripped wire...
    Mar 2003
    FL
    34
    953
    I like to use at least 3 main crimps on it with the bolt cutters. Fortunately I was able to make 4. Keep in mind you can do similar with a vice or a hammer or one of those professional impact crimpers.
    Mar 2003
    FL
    34
    953
    Fire up the Propane Torch (8.99 at Ace Hardware + 3.29 for butane refilling bottle)
    Mar 2003
    FL
    34
    953
    Heat up the entire thing. When the solder just touching the bare metal melts you have a 'hot joint' Keep the flame on the opposite side of the area you are soldering. This ensures you have a "hot joint"
    AFTER SOLDERING
    BEFORE SOLDERING
    Note that the individual wire color changed to silver and that you can see individual strands. That is indicative of a "hot joint" and that the copper has now been tinned and the Crimp ring is now anchored. (Takes a LOT of solder btw)
    DBfan187's Avatar
    DBfan187 is offline Supa's mom was here!
    Jan 2003
    Poolside with Supa's mom.
    46,516
    1 Post(s)
    You call that a knoif? This is a knoif!
    sorry had to!
    How much was that solder?
    Mar 2003
    FL
    34
    953
  9. #9
    Acidburn's Avatar
    Acidburn is offline Super Mod-like-guy
    Dec 2003
    Tempe, AZ
    26
    15,596
    22
    looks good man, blow torches are fun
    MdOiDcEtRaAtToOrR
    1996 Chevrolet Impala SS 14.5 @ 94
    1967 Chevrolet Camaro 18.4 @ 74
  10. #10
    davidfre21's Avatar
    davidfre21 is offline Is just a lil racist...
    Apr 2003
    WesTex
    26
    10,699
    i want a link to ur cardomain site.... lots of cool stuff in there im sure
    IA FTW!!!
    Team Sundown... what?
  11. #11
    Mar 2003
    FL
    34
    953
    Knife pics coming....lol hehehe
    therefore:
    P = (I)(V)
  12. #12
    OLD_SCHOOL's Avatar
    OLD_SCHOOL is offline CarAudio.com Elite
    Aug 2004
    Buford, Ga. Metro ATL
    711
    i know when we sauder copper pipe for plumbing we use flux should you use flux on this can it help ?
  13. #13
    Radar's Avatar
    Radar is offline Old balls
    Feb 2003
    Earth
    2,052
    screw the knife, ill take that 20
  14. #14
    ANeonRider's Avatar
    ANeonRider is offline teamSSAudio.com
    Aug 2004
    Saskatoon, SK, CAN
    31
    2,811
    You can use flux, it only helps conduct the heat to the wire, and with a torch you may not need that as much.
  15. #15
    Mar 2003
    FL
    34
    953
    Quote Originally Posted by ANeonRider
    exactly, and a butane torch is FUN!!
    therefore:
    P = (I)(V)
