Results 1 to 11 of 11
Reload Thread: Preparing for a Comp
    monte_carlo97's Avatar
    monte_carlo97 is offline Power Acoustik Punk
    Feb 2004
    Midwest Ohio
    26
    3,509
    I am going to a comp this sunday and i am pretty well set to go. But i was just wondering if there is any things you can do to get a little more.
    Such as i have hard that you can turn on the A/C to get a little more
    Or put your battery on a charger the night before.
    Stuff like that
    Any little tips would be apreciated
    97 Monte Carlo
    H/U - Kenwood Cd\MP3(KDC-MPV6022) - Up For Sale
    The All Power Acoustik System (Removed)
    Amps(2) - Class D 3000watt (A3000DB)
    Subs(2) - 15" MOFO 2600watt(MOFO-15)
    Caps(2) - 2.4 Farad Digital Cap (PC2.4)
    EQ(1) - 7 Band Preamp Graphic Equalizer (PEQ70)
    Rears(1 Pair) - 4-Way 6x9's (XP2K694)
    Fronts(1 Pair) - 2-Way 5 1/4's (XP2K52)
    Comp Set(1 Set) - 5 1/4 Component Set (XP2K50C)
    Comp Amp(1) - 4 Channel amp 960 watts max Plasma Sphere (TS960-4)
    Monitors(1) - 7" Widescreen TFT/LCD (PT713HRS)
    DVD H/U(1) - DVD Player (PADVD610)
    Box - 9 ft^3 box tuned to 35 hz.
    New System Yet To Be Determined. Although It Will Be All MA Audio.
    CP400M's Avatar
    CP400M is offline Member
    Jun 2004
    So Cal
    146
    Re: Preparing for a Comp
    Add a couple more subs and some more amps
    ANeonRider's Avatar
    ANeonRider is offline teamSSAudio.com
    Aug 2004
    Saskatoon, SK, CAN
    31
    2,811
    Most definately do not turn on any unnecessary accessories like A/C, that just drains your electrical system, not help it flow more.
    kickerlivinloud's Avatar
    kickerlivinloud is offline Banning survivor
    Feb 2004
    Finger Lakes, NY
    26
    3,280
    Remove your fuses when burping. The are not needed for short burps but be sure to put them back in or you will fry your amp.......
    Jon
    packerfan's Avatar
    packerfan is offline CarAudio.com Veteran
    Jan 2003
    Beaver Dam WI
    26
    3,809
    DONT turn or demo your stereo before the comp because it will drain the battery.
    Take a charger with you to the show and inbetween charge it.
    Eclipse CD7000
    MTX TA7804
    Eclipse SC8365
    MTX TA92001
    9 Elemental Designs 13Ov.2's (15.5 cu ft ported box)
    O/1g All around, 2 Yellow tops, big 3.
    Feb 2004
    Midwest Ohio
    26
    3,509
    Quote Originally Posted by packerfan
    got that covered
    97 Monte Carlo
    bigbassman's Avatar
    bigbassman is offline Master of all things loud
    Apr 2002
    Southern WV
    32
    2,890
    keep your vehicle under shade..
    what kinda show is this... and what meter?
    doing certain things will affect score on certain meters..
    and most importantly... where in ohio?...
    Loyd L.
    SQL Prolly
    Feb 2004
    Midwest Ohio
    26
    3,509
    Quote Originally Posted by bigbassman
    How does that have an effect
    It is a db drag. The guy who is the manager of the store that is putting it on said it was a db drag mic. But he also has his head up his @ss so who knows.
    Loyd L.
    It is in mid western ohio. About two hours from cincy. If you want, come up. I would like to see your 8's
    There is going to be about 50 cars there
    97 Monte Carlo
  9. #9
    Nikuk's Avatar
    Nikuk is offline Been Gone Too Long
    Jul 2004
    Buffalo, NY
    32
    7,848
    Quote Originally Posted by monte_carlo97
    colder air = denser air. more effective to pressurize... right?
    and cooler equipment of course. :*******:
    What the f00k happened to this place?
  10. #10
    TooLowTooGo's Avatar
    TooLowTooGo is offline 2Low2Go
    May 2004
    Jersey
    1,467
    Quote Originally Posted by ANeonRider
    hmmmm. well i heard if u run ur ac in ur car for say 15 mins to where it is really cold inside....then when its ur time to go and if it is still really cool in the car ull hit a good 1-2db's higher.
    so is this true or false?
    my ac dont work even if its true, lmfao
    Headunit: Alpine 7995
    Electrical: Iraggi 260 and a bad battery
    Subs: (2) 12" MTX 9500's
    Subs amp: (2) PA A3000DB's
    Speakers: (4) Orion p6.2's and (2) 8" MTX 4500's
    Speaker amp: (1) PA A600-4HP
    Wiring: Knu Koncepts
    148.2 and going up
    149.5 - NEW Term Lab (4 12" MTX 7500's powered by 1 Orion 2500D @ 2ohms) - NEW SCORES TO COME!!!!
    aim: FromJerzey
    REFs: Naxis2k1, NjccBflo, HCCAfan, Bavarian3, Mr. Loki, Bigrick31, JeffyZ33, Harrison486, Jester1318, Ctminime, lslugz, enzowho
    For more refs click here and here
  11. #11
    Feb 2004
    Midwest Ohio
    26
    3,509
    The Results are a 146.6 on a linear x mic
    97 Monte Carlo
  1. Northern California USACi Comp
    By Qckrun in forum Car Audio Competition, Shows and Events
    Last Post: 09-27-2004, 05:07 PM
  2. Replies: 4
    Last Post: 07-27-2004, 12:14 AM
  3. local comp
    By JL_Golfer_08 in forum General Discussion
    Last Post: 06-28-2004, 02:44 PM
  4. Question regarding 6.5" comp & rear speakers
    By Spy021 in forum Speakers
    Last Post: 04-12-2004, 08:33 PM
  5. comp today at Ultimate Sounds
    By KARLEON in forum Car Audio Competition, Shows and Events
    Last Post: 04-06-2004, 02:57 PM
