Results 1 to 15 of 15
Reload Thread: One sub=lower class...
    Diplexers's Avatar
    Diplexers is offline Logarithmic Robot
    Dec 2003
    Phoenix, AZ
    40
    2,433
    4 Post(s)
    I am seriously thinking of running one SoloX 18" off of two Eclipse DA7232's. I want to compete Meca M5 but don't know if they have anything in Arizona. I could pull off street C in DB Drag. If you know of any events in Arizona, help me out.
    Eclipse CD5000
    PPI... DEQ-230
    PPI... PC450 4 channel
    Eclipse DA7232 (2000 watts RMS)
    Focal PS130 Front
    Kicker RS6 6.5" comps
    Kicker R5c 5.25" midrange
    Qckrun's Avatar
    Qckrun is offline Registered User
    Aug 2002
    Somewhere
    1,925
    Re: One sub=lower class...
    Quote Originally Posted by diplexers
    Check out USACi at www.caraudioevents.com
    Theres always tons of comps in Arizona, and if not Arizona, Vegas, which i dont think is to far from there. If you want to travel, there is a 2x weekend in Northern California on the Sept. 25/26th weekend for USACi, there also may be a show friday night, but its still up for debate.
    Just check out that site, and it should set u up. dB Drag isnt to popular in Arizona.
    Qckrun's Avatar
    Aug 2002
    Somewhere
    1,925
    Cottonwood, AZ---7/24
    Glendale, AZ---7/25
    I guess if u really want to go u can go in 2 weeks lol.
    Also if u can, theres a Triple point event in Vegas this weekend. $45 to enter, which for a triple, isnt bad. You should check it out if u like to drive.
    packerfan's Avatar
    packerfan is offline CarAudio.com Veteran
    Jan 2003
    Beaver Dam WI
    31
    3,809
    Id personaly send more power to the solox, 4kw might get a decent score but more power couldnt hurt.
    Eclipse CD7000
    MTX TA7804
    Eclipse SC8365
    MTX TA92001
    9 Elemental Designs 13Ov.2's (15.5 cu ft ported box)
    O/1g All around, 2 Yellow tops, big 3.
    Diplexers's Avatar
    Dec 2003
    Phoenix, AZ
    40
    2,433
    4 Post(s)
    Quote Originally Posted by packerfan
    That is 2000 watts each channel. Equals up to 8000 watts.
    Eclipse CD5000
    PPI... DEQ-230
    Focal PS130 Front
    somekook's Avatar
    somekook is offline only 15"s
    Aug 2003
    Daytona Beach, FL
    30
    1,178
    god, 8000 watts on a solox 18"... mmmmmmmmm
    packerfan's Avatar
    Jan 2003
    Beaver Dam WI
    31
    3,809
    4000 watts max.....1000 per channel rms=2000 watts per amp x 2 amps = 4000 watts
    Eclipse CD7000
    MTX TA7804
    Eclipse SC8365
    MTX TA92001
    Bumpin' Yota's Avatar
    Bumpin' Yota is offline CarAudio.com Elite
    Mar 2003
    FL
    39
    953
    Even with "only" 4kW on that sub, you are going to blow the coil if you abuse that sub like most people I know do.....
    Lots of thin wire gives great BL (40+) but not so hot (or actually very hot) for power handling...
    Yota made funny!
    1 volt = [1(kg)(meter^2)] / [(second^3)(ampere)]
    1 watt = 1 joule / second
    1 watt = (1 Newton)(meter) / second
    1 watt = [1 kg/(second^2)] (meter) / second
    simplifying we find:
    1 watt = [1(kg)(meter)] / (second ^3)
    therefore:
    P = (I)(V)
    1 watt = (1 volt)(1ampere)
    1 watt = ( [1(kg)(meter^2)] / [(second^3)(ampere)] )(1 ampere)
    1 watt = [1(kg)(meter^2)] / (second^3)
    And that is WHY Power is in the SI units of Watts. enjoy!
  9. #9
    Diplexers's Avatar
    Dec 2003
    Phoenix, AZ
    40
    2,433
    4 Post(s)
    Its 2000 max "per channel", two channels, dual mono. I know its the max rating, but that is what I plan on running it at.
    Eclipse CD5000
    PPI... DEQ-230
    Focal PS130 Front
  10. #10
    Mar 2003
    FL
    39
    953
    4kW rms is the power rating you'll have if you use 2amps or 8kW peak. Eclipse uses off terminology at times....
    therefore:
    P = (I)(V)
  11. #11
    tRiGgEr's Avatar
    tRiGgEr is offline CarAudio.com Veteran
    Jan 2004
    San Diego, Ca
    35
    12,794
    5 Post(s)
    Do you plan on plugging in to a nuclear reacture to pull off the MAX rating max means nothing. :thumbsup
  12. #12
    Diplexers's Avatar
    Dec 2003
    Phoenix, AZ
    40
    2,433
    4 Post(s)
    Quote Originally Posted by tRiGgEr
    No, instead I'm going to plug each amp into 3000 potatoes(series). That should give me the power I need.
    Eclipse CD5000
    PPI... DEQ-230
    Focal PS130 Front
  13. #13
    Termlab's Avatar
    Termlab is offline CarAudio.com Elite
    Jul 2004
    athens ohio
    1,874
    nuclear reactor vs. potatos....... not much of a difference if you ask me. good thinking
  14. #14
    CP400M's Avatar
    CP400M is offline Member
    Jun 2004
    So Cal
    146
    lol
  15. #15
    saywhat?'s Avatar
    saywhat? is offline satx120, jealous?
    Apr 2004
    H'Burg Mississippi!
    30
    11,175
    and maybe the potatoes will bake and u can feed everyone at the show.
  1. Which is Better Class A/B or Class D
    By monte_carlo97 in forum Amplifiers
    Last Post: 07-16-2004, 05:40 PM
  2. Replies: 10
    Last Post: 06-17-2004, 02:18 PM
  3. Explanation on Amplifier Classifications?
    By sungwei in forum Amplifiers
    Last Post: 04-13-2004, 01:31 AM
  4. Terminology - Please contribute
    By frozenfire89 in forum General Discussion
    Last Post: 02-12-2004, 11:06 PM
  5. Class d vs. class ab
    By joshpoints in forum Amplifiers
    Last Post: 08-09-2003, 03:13 AM
