+ Reply to Thread
Page 3 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 31 to 45 of 172
Reload Thread: Get Your SPL Related Questions Answered Here!
  1. #31
    bigbassman's Avatar
    bigbassman is offline Master of all things loud
    Apr 2002
    Southern WV
    32
    2,890
    Re: Get Your SPL Related Questions Answered Here!
    Quote Originally Posted by Puggsley456
    How much do you think things will change if I fold em down?
    about 2-3.5 db
    also gain .5 to 1.5 db for removing the rear deck speakers..
    Loyd L.
    SQL Prolly
  2. #32
    bigbassman's Avatar
    Apr 2002
    Southern WV
    32
    2,890
    Quote Originally Posted by TooLowTooGo
    ok question, now this isnt what can gain more db question...because i kno there are so many factors. this is more of a personal question.
    which 2 boxes do you like better.
    1. CRX style...wit subs up ports back
    2. or subs and ports both facin back
    i have a chevy blazer, and right now a crx box for spl comps. i just wanted to kno what everyone else thinks is more effective n like better.
    depends.. are you competing in dash legal SPL, or outlaw style..
    one style does better legal, and another style works better outlaw..
    Loyd L.
    SQL Prolly
  3. #33
    TooLowTooGo's Avatar
    TooLowTooGo is offline 2Low2Go
    May 2004
    Jersey
    1,467
    last one i competed in was near the kicker panel. next one is on the 1st n thats goin by dash.
    but no comps aroun here are illegal, all legal. so wich u think is better?
  4. #34
    kickerlivinloud's Avatar
    kickerlivinloud is offline Banning survivor
    Feb 2004
    Finger Lakes, NY
    26
    3,280
    KK, new question. Should I brace my box on the outside or the inside??? I don't want my box to be huge so if I can save some air inside I am going to do it. Just cerious if that has any affect on the sound or anything....
    Thanks...
    Jon
  5. #35
    saywhat?'s Avatar
    saywhat? is offline satx120, jealous?
    Apr 2004
    H'Burg Mississippi!
    25
    11,175
    i know its not a crazy spl setup but im gunna be running 4 RE8's on a RF 500.2 (645 watts birthsheet) im gunna go 2 cubes obviously, its in a b2200, im not sure exactly on what i should port it at seeing that i want SQL out of these, i was thinking something like 35? if its allowed i can fold my passenge seast forward and my driver seat completely back to open paths for air, change visors, take out center console, all that stuff. im not sure what resonant freq. of the truck is, but i guess in logic a closed cab would be louder than a trunk? let me know what u think, and yota if u have AIM my name is sacreddispute03, i may want to use the mic some weekends, as im in orlando. u ever make trips around the state?
  6. #36
    Puggsley456's Avatar
    Puggsley456 is offline Who said you could talk?
    Apr 2003
    WPG>MB>CAN
    479
    Quote Originally Posted by bigbassman
    about 2-3.5 db
    Loyd L.
    Ok, Ive looked around and getting a different seat is totally out of the question. The work needed to track one down isnt something I wanna deal with right now. So, With the setup I have now would you recommend getting the most out of my system.
    ^^^Heres where I currently have it because I need to let the fan on my PG amp breath.
    ^^^^Heres my amp which is installed on the back of the seat. Do you think it would be wise for me to take the seat right out and jump to another class?
    Or just flip the box facing forward and seal it off?
    - 99 Cougar -
    - Rainbow CMX265 Kickbass - PG ti600.2 -
    - Mach 5 Audio (2) IXL12's in 3.2 cubes net@ 33hz - USAmps MD.1D -
  7. #37
    packerfan's Avatar
    packerfan is offline CarAudio.com Veteran
    Jan 2003
    Beaver Dam WI
    26
    3,809
    What are some tricks for walls?
  8. #38
    Bumpin' Yota's Avatar
    Bumpin' Yota is offline CarAudio.com Elite
    Mar 2003
    FL
    34
    953
    Quote Originally Posted by packerfan
    First measure everything. Realise you may have to actually build the box for the wall inside of the vehicle. If you have to do this, anchor what loyd calls a 'dance floor' The Dance Floor is just some MDF securely anchored to the floor of the vehicle, or where the floor of the box will be. It is on top of this dance floor where you will assemble the box for your wall. Having the dance floor inplace allows you to rotate and move the big box around easily to screw and glue everything together.
    Typically, your box will be completely assembled save the face of it. (Double layer your box or triple it if you are worried about flex - recommended for anything over 10cubes.)
    Once the 5 sides are together and dried, secure this box to the dance floor/car.
    Since your box is 1.5-2.25" thick, you now have room to have an interchangable face, yet still keep that facia around the boxface to keep the rest of the car sealed off. You can use Lag Bolts to secure the face to the box. (Lag bolts are the very coarsely threaded bolts that screw into a lead sinker. The lead sinker is placed inside a hole and as the lag bolt screws into the sinker the sinker expands. You'll need 2.25" minimum for this to work.... 3" - 4.25" would be preferable)
    For the facia around the face plate, I'd HIGHLY recommend buying a contour gauge so you can draw a line perfectly identicle to your interior. I'd also recommend carpeting the facia pieces unless you are after SPL only....
    Make your port VERY sturdy and thick!! If the port is ~3" thick, you can place a 3" PVC 1/2 pipe at the end to reduce turbulence...
    Remember the port is the point of TREMENDOUS acoustical pressure where spl will exceed 170dB.... 170dB at 40-50hz WILL shear drywall screws with EASE, so make sure the port is STURDY!
    1 volt = [1(kg)(meter^2)] / [(second^3)(ampere)]
    1 watt = 1 joule / second
    1 watt = (1 Newton)(meter) / second
    1 watt = [1 kg/(second^2)] (meter) / second
    simplifying we find:
    1 watt = [1(kg)(meter)] / (second ^3)
    therefore:
    P = (I)(V)
    1 watt = (1 volt)(1ampere)
    1 watt = ( [1(kg)(meter^2)] / [(second^3)(ampere)] )(1 ampere)
    1 watt = [1(kg)(meter^2)] / (second^3)
    And that is WHY Power is in the SI units of Watts. enjoy!
  9. #39
    jbl_marshall21's Avatar
    jbl_marshall21 is offline important person
    Oct 2002
    nebraska
    2,491
    alright heres a good question, i think. i'm not sure how to say this but i'll give it a shot.
    lately i have been trying out some tones and things w/o a mic. is there a point were turning the volume up so much would cause flexing on the vehicle, which would make it not be as loud as a lower volume, but by keeping the volume down, stop the flexing?
    did u guys understand that? if not i'll try explaining it again
    Alpine CDA-9886
    RUX-C701
    PXA-H701
    JL xr-650csi
    JL vr-650cxi
    2 8" W7
    JL HD750/1
    JL HD600/4
    2007 Chevy Trailblazer
  10. #40
    Feb 2004
    Finger Lakes, NY
    26
    3,280
    Quote Originally Posted by Me
    Thanks...
    Jon
    Wow that is a good question! Now only if someone smart could help us out and give us an anwser...
    Jon
  11. #41
    supa_c's Avatar
    supa_c is offline Abministrator
    Apr 2004
    In a chair
    19,367
    i have a Q. in my burb would it be better to fold down the 2nd row seats for more db. the box is facing the back with no carpet on the tailgate(fell off). maby put a sheet of mdf over the folded seats so the carped doesnt absorb the waves ? just wonderin.
  12. #42
    May 2004
    Jersey
    1,467
    ok i asked this in a thread aswell just incase. so if its not answered there maybe it will be answered here, i hope.
    Distortion
    ok Distortin, yes it is bad for a sub....real bad. buuuuut will distortion in SPL give u a higher DB?
    what im saying is if u crank the volume n etc.... all the way up where u kno theres distortion, will it lessen ur db rating or higher it because its still louder?
  13. #43
    supraman1379's Avatar
    supraman1379 is offline Loud 01 Ranger
    Mar 2004
    Ocala, Fl
    25
    3,180
    What should I do to make my sealed box louder, I already have polyfill in it.
    Ride: 2001 Ford Ranger
    Color: Red
    Head Unit: Kenwood 52x4
    Speaker Amp: JL Audio e4300
    Front Speakers: Kicker 4x6
    Rear Speakers: Stock
    Sub Amp: Bostwick 1100 (1100 RMS @ 1ohm)
    Subs : (2) Kicker CVR 15's
    Enclosure: 4.3 Cubes per chamber tuned o 32hz
    AudioControl - 145.9 dB
    TermLab Mic - 145.6, 146.0, 142.5(mic was messed up)
    Videos
    http://s108.photobucket.com/albums/n...Picture009.flv
    http://s108.photobucket.com/albums/n...Picture011.flv
  14. #44
    Oct 2002
    nebraska
    2,491
    port it, thats about the only way. or you can try firing it different directions.
    Alpine CDA-9886
    RUX-C701
    PXA-H701
    JL xr-650csi
    JL vr-650cxi
    2 8" W7
    JL HD750/1
    JL HD600/4
  15. #45
    Mar 2004
    Ocala, Fl
    25
    3,180
    yea right now i have it firing on an angle up and towards the fron so it sounds pretty good. I also folded down the seat so it helps it a lot.
    Color: Red
    Videos
+ Reply to Thread
  1. *amplifiers/power ratings*
    By dbhittin in forum Amplifiers
    Last Post: 06-30-2008, 11:33 PM
  2. a few questions on SPL enclosure
    By AScreenName in forum Enclosure Design & Construction Help
    Last Post: 03-29-2005, 05:53 PM
  3. CDT CL-61A related questions
    By wombat007 in forum Speakers
    Last Post: 05-30-2004, 09:18 PM
  4. spl questions
    By traksta15 in forum Subwoofers
    Last Post: 03-30-2004, 12:05 PM
  5. I need a few questions answered...
    By buchel in forum Amplifiers
    Last Post: 11-17-2003, 09:37 PM
