+ Reply to Thread
Page 2 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 16 to 30 of 172
Reload Thread: Get Your SPL Related Questions Answered Here!
  1. #16
    linksyz's Avatar
    linksyz is offline Senior VIP Member
    May 2004
    Jacksonville, FL
    32
    374
    Re: Get Your SPL Related Questions Answered Here!
    Quote Originally Posted by Bumpin' Yota
    Pro Sound in Gainesville? I lived there for 4 years and never heard of that one....is it a brand new one on N Main street near the old AudioWorx? If that quote was for ported and finished boxes, it's a pretty good quote. I also build boxes for people as well, so lemme know....
    I dont have a whole lot of time right now, so I'll post back later on tonight when I do.
    i'm not sure what the name of the shop was (I think he said somethin like Pro Sound and dudes name was Shane if I recall right). Yes, the quote he gave me was for ported boxes (he said he'd have to make 2 and put a board on top so it looks like 1 big box. Sarasota is a bit farther away than Gainsville (I'd travel up to Orlando or Gainsville to get my box). Thanks for replying, no hurry about posting, just do it when you get some free time
  2. #17
    bigbassman's Avatar
    bigbassman is offline Master of all things loud bigbassman is a Supporting Member of the forum!
    Apr 2002
    Southern WV
    36
    2,890
    Quote Originally Posted by Puggsley456
    ok guys heres one for ya! This weekend I'll be entering my FIRST competition. Now my box is tuned to 30 hz(Iknow its not the greatest fo spl). Now what frequencies should I start with for the comp? My hearing isnt that great so I really dont know where to start. Should I just use a 30 sec sine wave of a variety of freq. And I know you should base your tuning around the resonnant freq of the car but what should I do if I dont know it?
    your peak will probably be in the 40-55hz area... best thing you could do is play say.. 40 hz.. then jump up to 45.. then 50.. and keep going until you don't gain on the meter.. then play around with frequencies between the tones you just played...
    Loyd L.
    SQL Prolly
  3. #18
    Bumpin' Yota's Avatar
    Bumpin' Yota is offline CarAudio.com Elite
    Mar 2003
    FL
    39
    953
    I heard somewhere that the loudest freq. is usually 10-15 hz above the port freq. If this is correct, which I dont know if it is, why would i have to go up to 60 hz?
    Should I do a 40-50 30 sec wave that way I can sort of narrow the range down?
    Ima get fired from my job due to lack of sleep posting on forums...lol
    I've had systems that peaked about 4hz above their tuning to as much as 10hz. Same vehicle. Beats me why, but if I had to guess, I'd venture how the sub reacts to the box....
    One lesson I learned early in my drag career, is that if you have NO idea what your note is, you shouldn't limit testing to what you think may be the loudest note. My old no wall install peaked at 38hz. Not at 42hz like I thought for a few shows. That mistake cost me 1.5dB or so... If you can test everything from 30-70, but I'd bet dollars to donuts your loudst is somewhere betweetn 40-60hz...
    You'd probably be safe with 40-55hz, especially considering hte trunk car, but I have seen a few installs peak at 65hz. (CRX hatchback)
  4. #19
    Randy Savage's Avatar
    Oct 2002
    New York
    33
    21,120
    41 Post(s)
    Hey Loyd, I think I recall reading something you said about switching your bracing...I'm throwing in some threaded rod tomorrow, what kind of gain did you see with the switch to threaded rod?
  5. #20
    Mar 2003
    FL
    39
    953
    Quote Originally Posted by linksyz
    I'm still in my final planning stages for subs and amp but I thought I'd ask few questions before I go ahead and buy my equipment. First off, I have a 1999 Mazda 626 so I'm sort of limited when it comes to putting a big box in the trunk. I decided to go with 2 Treo SS15.44 and I'm going to power them both with Hifonics BX1500 (750wrms to each driver). Wayne from Treo told me that I would need 3.5ft^3 for both drivers sealed or 5.5ft^3 ported (I forgot to ask him what should I tune the box to). I'm probably gonna go with 2 1"MDF ported boxes (easier to fit them in). This setup would be used for daily driving, but I'd also like to compete at few small local car shows. I want my setup to be SQL for daily driving and maybe be able to have more SPL for competitions. I am going to run 1/0 awg wire, do the big 3, already have a quote from Iraggi for an 180 amp (better at idle than 200amp) alternator, and I'm still not sure what battery to get (right now i have Autocraft Titanium 800cca), but I'm prob gonna go with Optima Blue Top like Bumpin 'Yota recommended. So I have my electrical system pretty much covered up. I'm going to get about 40ft^3 of Dynamat Extreme and deaden the trunk. Would I have to use any other sound deadener that doesn't cost a lot along with Dynamat Extreme in order to reduce rattles? Where would you guys recommend facing the subs, what tuning should I have on the box, and how big of a port? Box is really concerning me right now, and I've posted on a lot of forums and haven't gotten any answers . Bumpin' 'Yota: I will come to dB Drag in Jupiter on August 14th and I won't have nothing installed by then, I hope I can see you there to ask you few questions . Also, I've never built my box and I'll have to ask few local shops for quotes on it (Pro Sound.. shop in Gainsville quoted me $250 for those 2 boxes), or would you guys recommend that I get someone to do me a design so I do it myself? I know this is kind of OT (if you mods think its too much OT you can delete the post or I'll do it, and maybe have someone email me at [email protected] for few anwers)
    Thanks,
    Nino
    Not OT at all.
    Starting from the bottom up, to the best of my knowledge, adding dynamat knockoffs helped my score. (Using classic termpro, so I have no idea if I really did gain...) Most EVERYONE I talk to, tells me it hurt their scores a LOT. (Maybe I have a 153 on the TL right now and dont even know it! LOL) But it does WONDERS for rattles when used properly.
    As far as firing direction and tuning, I don't know. That's something only a meter can tell you exactly. Your ears can do so to a degree, but often using one's ears is very misleading. (And damaging.)
    Everything you mentioned looks good, and in fact I'd venture out on a limb and say you can likely support 2 1500s...(with 1 run of 1/0 for each amp because voltage drop between your battery and your amp is the DEVIL!!! lol)
    One thing else - Ground your amp(s) with 1/0 not only to the floor boards, but also to the frame below. Then up front, do your big 3, but then upgrade and add grounds. You want the engine block grounded to the firewall, the frame, and the battery. Grounds are VERY important!
    I have to make a trip to gainesville directly, so if you want we can get the ball rolling... PM me
  6. #21
    bigbassman's Avatar
    Apr 2002
    Southern WV
    36
    2,890
    Quote Originally Posted by snova031
    well... going from a nasty wooden brace.. quite substantial gain...
    in this last install.. I went from no interior bracing.. to horizontal allthread forward/back, and side/side.. yielded about 6 tenths...
    Loyd L.
    SQL Prolly
  7. #22
    ramos's Avatar
    Dec 2001
    Virginia
    52
    10,329
    104 Post(s)
    Quote Originally Posted by bigbassman
    yah.. I'll make it a point to visit this thread at least once a day...
    and always keep in mind... every vehicle is different, every install is different.. what works in one car, may not in another.. thats the joy of competition SPL...
    now ask away
    Loyd L.
    You guys are gods. I have been preaching this very same statement for years now.
    5 % equipment
    90 % install
    5% beer
  8. #23
    kickerlivinloud's Avatar
    kickerlivinloud is offline Banning survivor
    Feb 2004
    Finger Lakes, NY
    31
    3,280
    Question, can bracing inside the box cause the box to sound different??? I remember reading somthing like that some were but I didn't know if it was true or not.
    Thanks for all your help guys...
    Jon
  9. #24
    Mar 2003
    FL
    39
    953
    Quote Originally Posted by kickerlivinloud
    Jon
    Yes, of course. If you have a very large box that is only a single layer, and without bracing flexes like mad, adding 3 layers to the sides (effectively bracing it) or adding all thread will stiffen the box.
    Typically (not always, but usually) a flexing box will peak lower in frequency than a nonflexing one.
    Now if that added bracing introduces resonances (like 2x4s do) you should be able to hear that.
    I also believe, that the more you treat the air inside your box like a moving fluid instead of a gas, when designing your box, the better off you will be...
  10. #25
    bigbassman's Avatar
    Apr 2002
    Southern WV
    36
    2,890
    Jon
    yup...
    certain types of bracing (nasty wooden types) will cause turbulence and resonance..
    same goes for thin 1 layer boxes.. nasty resonance above 60 hz....
    also, a flexing box will yield a lower impedence, lower resonant point, and of course.. kills SPL
    Loyd L.
    SQL Prolly
  11. #26
    bigbassman's Avatar
    Apr 2002
    Southern WV
    36
    2,890
    Quote Originally Posted by ramos
    you don't wanna play with me....
    we live 2 hours away... and I've yet to meet up with you...
    wang
    Loyd L.
    SQL Prolly
  12. #27
    Mar 2003
    FL
    39
    953
    wang
    Loyd L.
    Who would wanna play with you? Didn't your mom had to tie a 64oz ribeye around your neck to get the family dog to play with you?
    lol jk
  13. #28
    ramos's Avatar
    Dec 2001
    Virginia
    52
    10,329
    104 Post(s)
    wang
    Loyd L.
    Jeez man, so does Rangerman but I haven't had that joy yet either One of these days brother man . I got to see the crazy eights
    5 % equipment
    90 % install
    5% beer
  14. #29
    Puggsley456's Avatar
    Puggsley456 is offline Who said you could talk?
    Apr 2003
    WPG>MB>CAN
    479
    well guys, i hit 138.6 with the box 6inches from the rear of the trunck(to let my amp breath) facing towards the rear . I think my peak is arround 52hz but cant be certain until I get more meter time. Now my car doesnt have fold down rear seats. I can get them because they came factory as an option. How much do you think things will change if I fold em down?
    - 99 Cougar -
    - Rainbow CMX265 Kickbass - PG ti600.2 -
    - Mach 5 Audio (2) IXL12's in 3.2 cubes [email protected] 33hz - USAmps MD.1D -
  15. #30
    TooLowTooGo's Avatar
    TooLowTooGo is offline 2Low2Go
    May 2004
    Jersey
    1,467
    7 Post(s)
    ok question, now this isnt what can gain more db question...because i kno there are so many factors. this is more of a personal question.
    which 2 boxes do you like better.
    1. CRX style...wit subs up ports back
    2. or subs and ports both facin back
    i have a chevy blazer, and right now a crx box for spl comps. i just wanted to kno what everyone else thinks is more effective n like better.
+ Reply to Thread
  1. *amplifiers/power ratings*
    By dbhittin in forum Amplifiers
    Last Post: 07-01-2008, 12:33 AM
  2. a few questions on SPL enclosure
    By AScreenName in forum Enclosure Design & Construction Help
    Last Post: 03-29-2005, 06:53 PM
  3. CDT CL-61A related questions
    By wombat007 in forum Speakers
    Last Post: 05-30-2004, 10:18 PM
  4. spl questions
    By traksta15 in forum Subwoofers
    Last Post: 03-30-2004, 01:05 PM
  5. I need a few questions answered...
    By buchel in forum Amplifiers
    Last Post: 11-17-2003, 10:37 PM
