Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Reload Thread: What class should i compete??
  1. #16
    aturcotte127317's Avatar
    aturcotte127317 is offline CarAudio.com Elite
    Dec 2008
    Sheboygan, WI
    863
    Re: What class should i compete??
    the PVC on the baffle is actually to connect two seperate parts of the box.
    becasue since it was two peices, i couldnt get the peice in the back in, unless the peice in the spare tire area, was not in yet. SO i tried putting the further back peice in first, then i was going to put the spare tire area peice in, but it was too tall, the only way the spare tire area peice would fit in is if i cut it down, but i had to cut it down so far that there was no way for the air to flow between the two parts of the enclosure (the further back peice was too high up for the spare tire area peice to reach) Thus me having to use those 90 degree bend PVC for the air to flow between the two sections
    if that makes sense....
  2. #17
    jdmferio13's Avatar
    jdmferio13 is offline feayfm
    Sep 2008
    Central,PA
    1,779
    3 Post(s)
    so your sub isnt actually in trunk then right draw something up so i could see looks like a cool design
    Bought From:Queball,Dumped,ampjunkielikeme,ridnclean
    Sold To
  3. #18
    18inchjeepin's Avatar
    18inchjeepin is offline CarAudio.com Elite
    Sep 2007
    Muncie, IN
    1,331
    that box confuses me, also work on the jigsaw skills
    Silver HHR - 155.1 db
    TEAM SOUNDSTREAM
    XS Power
    REFS:jeeper07,thegreatestpenn,TeamPSI(x3),dbman150,bad @SS chevy,tommyk90,*GQ*,THXdts, XxSuperAdamxX,fatboyracing,gymfreak101,LTnChynadol l,amartin_72,avs20,Twisted_0912
    SOLD TO: Kold_Killa,GMCJimmyslt2000,skitzafit,ravens9322,wE rd,jeramydean,Shinju,the12voltsux,gammey4,camaroau dio69,bigwheel15
    TRADED: RnK1026,wasted ink
  4. #19
    Dec 2008
    Sheboygan, WI
    863
    o yea the sub is in the trunk, but... well here are some pics that can hopefully help:
    ORIGINAL PLAN, BUT MADE ALOT OF CHANGES:
  5. #20
    Dec 2008
    Sheboygan, WI
    863
    Quote Originally Posted by 18inchjeepin View Post
    haha, i had a weak *** jigsaw, it took me 25 minutes to cut the hole for the sub... so i was trying to hurry....
  6. #21
    jdmferio13's Avatar
    Sep 2008
    Central,PA
    1,779
    3 Post(s)
    so basically the sub is behind the actual box of ports but all together it touches and you just change the small front baffle of ports to change tuning looks neat weird idea but whatever works.I take it your seats dont come down
    Sold To
  7. #22
    DUMPED's Avatar
    DUMPED is offline CarAudio.com Veteran
    Dec 2007
    Great North
    3,507
    for starters take a look at the different organizations and their respective rules and make your decision from there.
    if you're really serious about competing then the "very least" you could do it familiarize yourself with the rules...
    as for the enclosure it looks like the OP is attempting to connect the wheel well enclosure with the horizontal one via those PVC tubes and then porting out through those 3 PVC tubes on the left... is that correct OP? I cant see it being a good idea mind you...lol
    Refs: pedro123, Turboed331, woodplock7, djvi0lent, CrazyKenKid, DemonaL, MitchZ, 95Prober, fatryan, WildSebring, d_man1, djman37, rlm1014, lslugz, wave100205, jdmferio13, chereck04, nineball, 350Rocket, scdean, Frijoles24, IceCube0306, LS7GTSR, MTX9515, Raid3r89, taylorman, Chin_Chilla, 37wref, braves6117, SPL-Master, haunther, 37wref, 01 S 10, Farmacist, krisfnbz, tyler_fitz, acubsfan, sotelomichael, krazykarl, tymoto21, 18inchjeepin, mike11202, teenapp, TnT_Sounds, ssackett, spiroh, memphisman00, Arnold, 5.3bowtie, th3disturbed1, tylork92, Kern417, jerseyboy, blazron22z, groundpound4200, maddog, annarbor84, bannock
  8. #23
    Dec 2008
    Sheboygan, WI
    863
    Quote Originally Posted by jdmferio13 View Post
    no they do not fold down
    but yea it is definately not the way i was planning on making the box, but since i ran into compications, i decided to make it the way i did, and i like it.
  9. #24
    Dec 2008
    Sheboygan, WI
    863
    Quote Originally Posted by DUMPED View Post
    that is exactly what it is^^^
