+ Reply to Thread
Page 1 of 7 1 2 3 4 5 6 7 LastLast
Results 1 to 15 of 96
Reload Thread: JLJunkie's Retarded Budget Build
    JLJunkieMX107's Avatar
    JLJunkieMX107 is offline CarAudio.com Elite
    Jun 2007
    Grand Rapids, MI
    1,338
    1 Post(s)
    42 Post(s)
    I've been out of the scene for quite a few years and just getting back into it. So back in the day, I used to build a lot of boxes (worked at an audio shop as a box builder in 2007). I always wanted to take a bunch of cheap-o budget subs, build a decent box for them, and then throw as much power as those pieces of crap can handle to see how loud they can get......welcome to JLJunkie's retarded budget build. And no, this is not retarded in a good way lol
    The theme of this build is to spend as little as possible while still getting a decent bump in the trunk. I am a huge advocate of doing things correctly and safely, so there will be things purchased that aren't exactly "budget" grade. I will also be building out something more respectable and want to have all my electrical setup for my "good" install.
    Current status: the subs and amps are on the way. I wont give the subs away just yet, but I bought 8 of them for a whopping total of $105. Yep, 8 subs for $100 I need to send 1,600 watts through these bad boys, so in true budget fashion - I ordered an Audiopipe APMI 2000. These amps are super inefficient which means my electrical system will see a facelift before I start running this amp.
    I also have a few runs of 1/0 gauge on order so I can do the big 3. Eventually will have a battery bank for my future build, but not concerned about that for now. My stock alt is running at 160A, will need to upgrade that in the future as well (probably with a mechman 270A).
    Anyway, I did some work on my ride today and will post pics immediately following this post. This truck is a bone stock 2014 Ram 1500 crew cab, starting off fresh! I use this truck daily and regularly need my back seat to haul people around. The amps will be permanently mounted but I am going to fabricate a sliding tray system that lets me easily remove the sub box whenever I need to use the seats. Onward to what people actually view these threads for....the pictures!
    Jun 2007
    Grand Rapids, MI
    1,338
    1 Post(s)
    42 Post(s)
    Re: JLJunkie's Retarded Budget Build
    The truck, bone stock 2014 Ram 1500
    Got her in the shop, time to do work
    Here's everything that went in today. I needed to get a better HU in the truck but didn't want to spend a fortune. Ended up getting a Kenwood KDC-x399 for $50 at a pawn shop. Using a Metra double din install kit, to include their CAN bus wiring kit (this **** was so much simpler in the 90's). Also had to a get an antenna adapter
    Ripped the dash apart, that stock HU needs to go
    Almost ready to put in the new HU, however, that dang aluminum housing is in the way (won't let the new HU slide in). Also, staying refreshed with a nice can of Oberon
    The two lines are where I need to cut. This oscillating tool has been my savior on so many projects, zipped right through the aluminum like butter. Also, I have sliced my hand open too many times on sharp edges, swapped out attachments and sanded this crap down.
    Aaaaand the "new" HU is in and functioning, sounds so much better than the stock one too. Can't wait to get the subs/amp to get a little bass going.
    Jun 2007
    Grand Rapids, MI
    1,338
    1 Post(s)
    42 Post(s)
    Here is what I've got to work with for space on this build. I've got 15.8 cubic feet, maybe a little more if I want to breach the window line. I only need 12 cubes for these subs (doing a kerfed slot port).
    Here is a bonus for some of you old school guys on here. We recently moved into our current house and the previous owners were kind enough to leave a few boxes of random junk in the garage. Today, I finally got around to looking through it all and found this little gem hiding in there. In the 90's, these Aura MR-5's were the shiznit. Unfortunately, I only have one of the midbass speakers and not the whole set of components It's still a nice little speaker to have around the shop, brings back memories
  4. Likes OldSch00L765, Louisiana_CRX, Sleeklsc liked this post
  5. #4
    Jun 2007
    Grand Rapids, MI
    1,338
    1 Post(s)
    42 Post(s)
    Received the amp today, the subs should be here tomorrow. Buck is designing a box for these beasts. Hopefully I'll be able to start building the box and upgrading my electrical next week. 1/0 runs on order, starting with the big 3 and should have my 270A alt in a couple of weeks. I'll mostly likely try to run dual alts but I just need to find or fab a **** bracket.
  6. #5
    Spooney's Avatar
    Spooney is offline CarAudio.com Veteran
    Dec 2007
    Charlotte,MI,USA
    37
    4,430
    4 Post(s)
    799 Post(s)
    Excited to see how this turns out man. I am doing something very similar but it’s still probably a year out. Got subs already and amps on the way but no vehicle as of yet lol.
  7. #6
    poolman966554's Avatar
    poolman966554 is offline Senior VIP Member
    Mar 2015
    NW, PA
    406
    1 Post(s)
    183 Post(s)
    Im gonna guess 8 Dual 8"s.. dont forget about rise, unless your wiring low, the subs may never see full power. which means your electrical "might" be ok. checking voltage is the only way to know, but ill bet your close to max..
    Btw, i like these kinda build threads. always nice to see how others minds work. keep us updated
    Avinusa HU for 2007 Honda Crv
    Electrical : Duracell Grp 34 AGM with Big3
    front stage : Sundown Sae 50.4 on DB651s
    Sub amp : AB 4480.1
    Subs : 2) Sundown SA-12s @1 ohm in 3.8cu'ft @ 32hz
  8. #7
    Jun 2007
    Grand Rapids, MI
    1,338
    1 Post(s)
    42 Post(s)
    Quote Originally Posted by Spooney View Post
    I will keep you guys posted. I am having fun just building this and not trying to go for impressive numbers. I always wanted to throw some power at a bunch of cheap subs in a decent box just to see what happens.
    Quote Originally Posted by poolman966554 View Post
    Man, you are pretty close on the brand. Not Dual or Boss, but pretty close. This was actually a pretty respectable brand in the 90's but their quality went to crap over the years. I haven't seen anyone run these before, so it will be interesting. UPS says they will be here tomorrow so I will have a few pics to post
    From what I discussed with Buck, it looks like we are going with a 6th order. This thing should be a beautiful design (if you've seen Buck's work). In all honesty, these speakers don't deserve to go in the box I am going to build lol. However, one day I might throw in some decent 8's to see what it can really do.
    The final load on the amp will be 2 ohms. From the tests I've seen on this amp, it did 1300 watts @ 13.9V on a certified run. It pulled 156 amps, my stock alt is 160A. I think with the big 3 and maybe an extra battery it might be a good bandaid for now. I really can't wait to get the HO alt installed so I can be worry free.
    Also, TheFiverMan just shipped a couple of Soundqubed HDS3 12's to me, so stay tuned for build log #2 (the more respectable thread lol)
  9. #8
    Jun 2007
    Grand Rapids, MI
    1,338
    1 Post(s)
    42 Post(s)
    Spooney, I just realized that I am only about 30 minutes from you (I live in Saranac). You'll have to hear it once it's done and let everyone know what you think.
  10. #9
    Popwarhomie's Avatar
    Popwarhomie is offline Team Lethal Pressure
    Jan 2010
    Jacksonville, FL
    5,319
    64 Post(s)
    2475 Post(s)
    Pyle?
    2016 Focus ST - Rockford DSR1 / PPI 900.4 / Silverflute 6.5" mids / Massive CT2 tweeters /Sundown Xv2 15"/ Taramps DSP3k / Stinger Roadkill / KNU wiring / Northstar SMSAGM80 /
    2010 Focus coupe [email protected]
    Pioneer 80prs /(8) FU Audio 750 12"s / (4) FSD 2600s / (1) FSD 125.4 / (1) FSD 85.4 / (4) Crescendo UN-10" mids / (4) Crescendo FT1 tweeters / Stinger Roadkill / 2/0 EB flex wire / (5) Powerware 90AH batteries / DC 270XP Alt /
    https://www.youtube.com/popwarhomie
    Quote Originally Posted by XxAndreaxX View Post
    too many freq at once, burn the coil, we all know, over 40-50hz, its all coilburning material.
  11. #10
    Jun 2007
    Grand Rapids, MI
    1,338
    1 Post(s)
    42 Post(s)
    Quote Originally Posted by Popwarhomie View Post
    Pyle?
    Very, very close man. In the same bracket. I actually had to hunt these down, they aren't being sold at your local big box stores. Honestly, from what I thought of this company in the 90's, I never expected them to produce a sub of this poor quality and such a low price. These things were like $12 bucks a piece lol. I didn't really intend to build the suspense on what these babies are, but this is fun lol. Buck isn't allowed to guess tho.
    I really wanted to do 8 Elemental Designs 8" subs. However, I realized that I've been gone from the audio world for too long and that Elemental Designs went out of business 6 years ago
  12. #11
    THATpurpleKUSH's Avatar
    THATpurpleKUSH is offline Smoke weed everyday
    Sep 2009
    Banging gears and passing queeers
    5,682
    15 Post(s)
    2275 Post(s)
    I bet it's 8 of those Blaupunkt subs from Walmart.com lol
  13. Likes erod856, hispls, pw91686 liked this post
  14. #12
    Jun 2007
    Grand Rapids, MI
    1,338
    1 Post(s)
    42 Post(s)
    Quote Originally Posted by THATpurpleKUSH View Post
    Hahaha you nailed it man. I've got 8 of the GBW801's arriving tomorrow. We'll see if these bad larrys give the funky pups a run for their money.
    Blaupunkt used to be great back in the day. It is still respectable over in Germany (that's where I've been the last 6 years). But maaaaan, there stuff has gone to crap over here in the good 'ol US of A.
  15. #13
    Sep 2009
    5,682
    15 Post(s)
    2275 Post(s)
    Quote Originally Posted by JLJunkieMX107 View Post
    You will be very surprised with the build quality when you get them. I have 4 of the 10s and 2 of the 12s.
  16. #14
    MattinMO's Avatar
    MattinMO is offline Senior VIP Member
    Dec 2017
    St.louis, MO
    187
    118 Post(s)
    Def the blaupunkts! I hooked up my 1 12 in my Audi and it actually impressed the **** out of me I’ve got it on a newer punch 300
    My wife doesn’t know about my car audio addiction...shhhh
  17. #15
    Jun 2007
    Grand Rapids, MI
    1,338
    1 Post(s)
    42 Post(s)
    You guys are getting me super excited about this build now. I took a chance on these for this budget build and hoped I would be surprised. The 2 that I debated on were these Blaupunkts and the Soundstorm SS8. I can't wait to get these things slappin'.
+ Reply to Thread
  1. Budget Build? SQ
    By bunnerrabbit in forum Advanced SQL/SPL Discussion
    Last Post: 08-15-2017, 12:42 AM
  2. Replies: 6
    Last Post: 03-03-2015, 10:37 AM
  3. starting new build from scratch (budget build)
    By truckcap22 in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 03-18-2011, 02:59 AM
  4. two 12 for budget build
    By leadparrot in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 10-15-2010, 10:14 PM
  5. Budget Build For Gf
    By NoPh33rRaCiNg in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 11-12-2008, 10:51 AM
