+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Reload Thread: 2011 Challenger Build
  1. #16
    moparnut's Avatar
    moparnut is offline Member
    Nov 2017
    Wagoner, OK
    97
    30 Post(s)
    Re: 2011 Challenger Build
    Quote Originally Posted by Louisiana_CRX View Post
    Everything looks nice for someone who’s been out of it for 20 years...
    Thank you.
  2. #17
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    10,101
    15
    38 Post(s)
    4138 Post(s)
    Like riding a bicycle. Right back in there like you never forgot.
    Great looking work so far. Does the new sub perform well in the t-line?
  3. #18
    moparnut's Avatar
    Nov 2017
    Wagoner, OK
    97
    30 Post(s)
    Quote Originally Posted by hispls View Post
    Thanks. Box building is box building. If you have access to the tools, the rest can be figured out fairly easy.
    It performs very well. It'll hit 28hz and move my daughters hair a little, but really comes alive at 36-37Hz. However it is not performing so well since I changed the port to front facing. I'm getting some serious cancellation issues having the port next to the sub like that. I lost all of the gain it was getting from the trunk also, so I'm going to port it through the rear deck like it was before. That was my original design and it sounded great then. The design has changed a few times and may change a few more. It's fluid at this point. It's part of the fun for me.
  4. #19
    hispls's Avatar
    Sep 2009
    10,101
    15
    38 Post(s)
    4138 Post(s)
    Quote Originally Posted by moparnut View Post
    Couldn't really see by your pics what was going on when you ported out through that hole. You'll have to take better pictures when you figure out a way to get the port moved.
  5. #20
    moparnut's Avatar
    Nov 2017
    Wagoner, OK
    97
    30 Post(s)
    Hopefully these pics will shed some light. It was an easy move that took a few minutes to make. I originally had the port exiting through the top of the box and put in a piece to block off the top and open the front. I just removed it, covered the piece in vinyl, and positioned it to block the front to open the top back up. The port now is open to the factory sub hole as it was at the start of this whole thing. Cancellation issues are now gone and all is well.
  6. #21
    hispls's Avatar
    Sep 2009
    10,101
    15
    38 Post(s)
    4138 Post(s)
    Got it.
  7. #22
    moparnut's Avatar
    Nov 2017
    Wagoner, OK
    97
    30 Post(s)
    Been a while since I updated, but she is still getting worked on. The stock head unit is gone. In it's place is a Clarion CZ702. Not the best out there, but lightyears ahead of the factory and the 5V preouts, time alignment and parametric EQ are nice. It also has a 3 way mode for running an active setup once I get my 4 channel amp.
    The factory door speakers were replaced with a set of precision power sedona 6.5 components. No pics, but the door panel is still factory for now so nothing to see other than a flush mounted tweeter.
    I also finally started on the vanity panel for the box in the trunk. I have resined the fleece and now need to lay a layer or two of glass mat. I'm going to smooth out the lines so they are not so sharp. This will probably be painted and upholstered to break it up a little, in addition to having the holes for the windows cut out. I'll post more updates as they come.
+ Reply to Thread
  1. 2011 Dodge Challenger Build
    By carshateme in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 09-30-2013, 11:28 AM
  2. Challenging build, very limited space.
    By jolly_26 in forum General Discussion
    Last Post: 06-23-2012, 05:42 PM
  3. Which Harness for 2011 Challenger?
    By GaresTaylan in forum Wiring, Electrical and Installation Help
    Last Post: 08-08-2011, 11:01 PM
  4. d-REW's 2011 Sundown build log
    By d-REW in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 01-18-2011, 11:56 PM
  5. Challenge: Build me a system
    By Deamonicus in forum General Discussion
    Last Post: 05-18-2006, 08:48 PM
