+ Reply to Thread
Page 7 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 91 to 105 of 134
Reload Thread: Chaseinbass 96 GMC rebuild sort of ?
  1. #91
    ChaseinBass's Avatar
    ChaseinBass is offline CarAudio.com Elite
    Jul 2013
    Calif
    1,554
    2 Post(s)
    726 Post(s)
    Re: Chaseinbass 96 GMC rebuild sort of ?
    You think a group 78 will fit in the Tahoe battery tray? So I'm thinking of nabbing a few group 78's if they'll fit and increase my voltage. Who knows when yet but I'm still looking. I have a group 75 right now...
    Ya I have two 78s up front. But that wont increase your voltage ? What you got for an alternator ? Too bad you dont live close to me I would sell you my 3 juice box gp31s at a good price but I think shipping would kill the deal,
    Pioneer Prs80, Taramps 15000 HD,two 18 team FI ,PPI900.4, CDT HD-2/BLs and 2 pr Anarchy mids, s 4 group31 juicebox batterys , lots of 0 gauge and NRG aluminum hardware, Triple alts, 1 bank of maxwell ultra caps.
  2. #92
    Jul 2013
    Calif
    1,554
    2 Post(s)
    726 Post(s)
    My have an ho alt that will fit soon too
  3. #93
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    9,880
    24 Post(s)
    4159 Post(s)
    Quote Originally Posted by ChaseinBass View Post
    Sucky stock alt. Can't afford a HO alt right now.
    97 4 dr. Tahoe
    Optima redtop
    Alpine 9835
    Polk Audio MM6501 comps
  4. #94
    Jul 2013
    Calif
    1,554
    2 Post(s)
    726 Post(s)
    Those came stock with a 145 amp alt in those so it decent if its still working good ? I might sell the two cheaper extra alts I have when I get the singers fixed so save your lunch money lol !
  5. #95
    Jul 2005
    WA
    9,880
    24 Post(s)
    4159 Post(s)
    Looks like it's been replaced before. Says Autolite right on it. I think that's Autozone brand.
    97 4 dr. Tahoe
    Optima redtop
    Alpine 9835
  6. #96
    Jul 2013
    Calif
    1,554
    2 Post(s)
    726 Post(s)
    Do the two case halfs bolt together to each other or is there a space in between the too halfs maybe 1 1/2 inches of the stator is showing ? the ones with case bolting directly together are 105 amp alts and the ones with stator showing in between the two case halfs are 145 amp alts, I dont know if you can see but the stock one on driverside is 105 and the one on passenger side is 145 style ( hard to see stator because wireing I have in split loom running over it. Yours should be the 145 amp style.
  7. #97
    Jul 2013
    Calif
    1,554
    2 Post(s)
    726 Post(s)
    105 amp alts are called cs130 and 145 amp alts are either ad244 or dr44 only difference is in how the bridge rectifier diodes are mounted in rear case dr44 are press fit into rear case and ad244 have a simple bolt in recifier and are much easier to chang out.
  8. #98
    Jul 2005
    WA
    9,880
    24 Post(s)
    4159 Post(s)
    Hmm...I'll have to check on the amperage, I'm not entirely sure on it tho.. But here's a pic of when I changed my wiring...
    97 4 dr. Tahoe
    Optima redtop
    Alpine 9835
  9. #99
    Jul 2005
    WA
    9,880
    24 Post(s)
    4159 Post(s)
    Yup, looks like both cases bolt together. I did think about getting my alt re-wound, get it higher amperage but also read that it's not a good thing to do.
    97 4 dr. Tahoe
    Optima redtop
    Alpine 9835
  10. #100
    Jul 2013
    Calif
    1,554
    2 Post(s)
    726 Post(s)
    Ya yours is a cs130 105 amps so any of the ad244 or dr44 are a direct swap and put out 145 amps and those are less than $200 and a very
    good upgrade for you. I bought two off ebay for like 165 each for backups and only time will tell but so far there doing great and suposed to do 250 amps - I am guessing 175-200 but who knows. I am going to get a 500 amp load tester so I can test these and see what they put out.
  11. #101
    Jul 2013
    Calif
    1,554
    2 Post(s)
    726 Post(s)
    Chaseinbass 96 GMC  rebuild sort of ?-fullsizerender3.jpg Got the little grills put in to cover the bad chipping I did with the drill bit and they look better now and will hold me over till I redo the A pillars atleast.
  12. #102
    Jul 2005
    WA
    9,880
    24 Post(s)
    4159 Post(s)
    105? Wow that's weak. I forgot to look earlier and getting dark out....I'll have to look at that tomorrow. Funny because my s10 has a 105 amperage alt, and I replaced it recently.
    97 4 dr. Tahoe
    Optima redtop
    Alpine 9835
  13. #103
    Jul 2013
    Calif
    1,554
    2 Post(s)
    726 Post(s)
    Ya there the same and same goes with the 145 is a direct swap for it too . I thought all Tahoes atleast all the ones I ever seen came with 145 amp alts ? Have them look it up at auto zone
  14. #104
    Jul 2013
    Calif
    1,554
    2 Post(s)
    726 Post(s)
    Fed ex dropped off my caps today (1bank) and straps, enough to build 2 banks. I am still looking for another bank at a decent price.
    Chaseinbass 96 GMC  rebuild sort of ?-img_6689.jpgChaseinbass 96 GMC  rebuild sort of ?-img_6695.jpgChaseinbass 96 GMC  rebuild sort of ?-img_6696.jpg
  15. #105
    The Camry's Avatar
    The Camry is offline Hey, I Try.
    Sep 2013
    Western Oregon
    2,712
    13 Post(s)
    1228 Post(s)
    Quote Originally Posted by wew lad View Post
    coils look like stock psi coils to me, no scorching on the paper part of the coil so im sure its just fine
    caps are just a really great way to help maintain good voltage at the amp because they handle surge current much much much better than any battery besides lipos of course (which still dont beat caps but they are better than caps imo).
    theyre about $300 for a new bank of 6, and $150-250 for a used bank with the copper straps. only get maxwell or xs power caps the 3000f 2.5v-3v per cap version. theyre basically a huge buffer for massive current draw, instead of immediate delving into battery territory and dropping 2v, you might drop a tenth of a volt and slowly go down to battery voltages.
    its important you have the alternator output to back it up, they love a lot of charging current, but it is also possible that you could drop one batt and go caps in its place. they are somewhat small. guy over on caco lunchbox has like 8 banks? and hits 160s with uhh 2 tfes? idr lol
    Im running my system on a 80 amp alt and the only time i have bad voltage (12s) is at stop lights on hot days. Basically i get Ac or bass. Ive thinking of getting some caps as buffers. Can you give me some info on the viability of this?
    Sent from my SGH-M919 using Tapatalk
    Gain on an amplifier to meant to be matched to the output voltage of your headunit. Think 3 volt, 4 volt, 5 volt pre out specs you see on headunit specs. This is how gain works for a given pre out(5 volt) theoretically. However most head units clip(start to distort) at around 80% of your volume so your 5 volt pre out wont give 5 volts Cleanly. You will most likely get 4 volts out at something like 33/40 on your volume knob and would thus set your gain to 4 volts. (these things can be measured with a GOOD Multimeter. )
    80% of your total volume is (max volume) X 0.8.
    Example is 40(is your max volume so, 40 X .8=32
+ Reply to Thread
  1. 96 GMC Rebuild
    By ChaseinBass in forum Enclosure Design & Construction Help
    Last Post: 09-14-2016, 04:55 PM
  2. What sort of 1/3 octave eq do I need?
    By audioholic in forum General Discussion
    Last Post: 02-22-2004, 09:19 PM
  3. Replies: 1
    Last Post: 02-14-2004, 09:42 AM
  4. 96 GMC Sierra
    By Unregistered in forum Wiring, Electrical and Installation Help
    Last Post: 03-31-2002, 04:36 AM
