Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Reload Thread: What do upgrade? - Sub, head unit or amp edition
    theabcs's Avatar
    theabcs is offline Junior Member
    Nov 2016
    Rialto, CA
    3 Post(s)
    Hello everyone,
    Firstly, thank you for taking the time reading my post and aid me.
    I have had my setup now for about 2 years and I am looking to upgrade. Before I say my setup, I would like to say that I value clearness and quality over loudness every day of the week and am not afraid to increase my budget to accommodate my audio needs.
    I am a novice when it comes to the details of the car audio world. Therefore, I would like to ask you, thee expert, what would you recommend me to upgrade (and why if I may ask)? I am currently only looking to upgrade one item, however, if an amp upgrade with a subwoofer upgrade would make a significant difference I will consider it.
    My Setup:
    Head Unit
    JVC KD-R840BT
    JVC KD-R840BT CD receiver at Crutchfield.com
    Specs
    Preamp Voltage 4.8 volts
    RMS Power Output 20 watts
    Peak Output 50 watts
    RMS Power Bandwidth 20-20kHz
    Amplifier
    Alpine MRP-M500
    Alpine MRP-M500 Mono subwoofer amplifier — 500 watts RMS x 1 at 2 ohms at Crutchfield.com
    Specs
    Amplifier Class D
    RMS Power Output (Watts x Channels) 300 x 1
    Power at 2 Ohms (Watts x Channels) 500 x 1
    Signal to Noise Ratio 75 dB
    Subwoofer
    Memphis 15-MCR12D4 12"
    https://www.amazon.com/15-MCR12D4-Me.../dp/B009OPEJ9A
    Specs
    Maximum Peak Power (Watts) 600
    Recommended RMS Power (Watts) 300
    Resonant Frequency (Hz) 31.41
    Sensitivity @ 1W/1M (db) 83.61
    I am leaning towards a new amplifier to better handle the sub's requirements. Thoughts?
    04tahoe's Avatar
    04tahoe is offline Member
    Nov 2016
    TN
    65
    36 Post(s)
    Re: What do upgrade? - Sub, head unit or amp edition
    I'm no expert compared to the guys on here, but I wouldn't recommend upgrading your amp unless you're upgrading the sub too. That amp is pushing more than enough power to that Memphis assuming its wired down to 2 ohm.
    Sent from my SM-S975L using Tapatalk
  3. Thanks theabcs thanked for this post
  4. #3
    04tahoe's Avatar
    Nov 2016
    TN
    65
    36 Post(s)
    And as far as upgrade it really depends on what you're looking for more bass or better sound quality. If more bass then id upgrade to a sub that can handle the power better. If better sound quality If you haven't already upgraded front and rears. Possibly component set up front and full range rear run off a 4 channel amp that's my next upgrade.
  5. Thanks jRi0T68, theabcs thanked for this post
  6. #4
    theabcs's Avatar
    Nov 2016
    Rialto, CA
    3 Post(s)
    Thanks for your reply!
    I currently do have a separate 4 channel amp covering my other speakers. I do have a full range in the rear and a component set up in the front, but I do not remember what they are exactly. Those speakers, I am fine with.
    I guess my next question is that if I upgrade my sub to one that can output more power, can still retain the bass clarity? I really enjoy the sound of my bass, however I feel as if it doesn't output enough for my satisfaction.
  7. #5
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,059
    40 Post(s)
    5947 Post(s)
    Sounds like your wanting more. Most people buy equipment 1st, whereas other's upgrade the elctrical 1st, then start adding the amp(s), sub(s), etc.
    Have you done the big 3 yet. it consits of the 3 charging wires, one of them a ground from neg battery to chassis.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
  8. Thanks theabcs thanked for this post
  9. #6
    theabcs's Avatar
    Nov 2016
    Rialto, CA
    3 Post(s)
    I had no idea what this was. I did a little research, and learned a little more about it. I will be doing this upgrade today or tomorrow.
    I do not know if this helps, but I do have an yellow top optima battery.
  10. #7
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,802
    233 Post(s)
    7687 Post(s)
    Quote Originally Posted by theabcs View Post
    lol.... you stated you wanted clarity but now its output thats the issue. bro just get a custom made ported box designed for sound quality and you will get the output you want while retaining sound quality. It currently sounds like you either have a sealed box or a pre-fab ported.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  11. #8
    theabcs's Avatar
    Nov 2016
    Rialto, CA
    3 Post(s)
    Quote Originally Posted by Jeffdachef View Post
    I am unsure of the quality of the box, but I am sure it is not of high quality. I did not know that the quality of the box will affect its sound. Thank you for your advice, I will definitely look into this!
  12. #9
    Jeffdachef's Avatar
    Feb 2013
    15,802
    233 Post(s)
    7687 Post(s)
    the box accounts for more than 70% of your bass output and sound quality so if you bought it pre-made, its a good chance that its designed by a monkey that has no idea how to get loud or sound good.
  13. #10
    theabcs's Avatar
    Nov 2016
    Rialto, CA
    3 Post(s)
    It was premade. I will buy a custom box instead of the big 3 upgrade. Is there any good manufacturers that you would recommend?
  14. #11
    jRi0T68's Avatar
    jRi0T68 is offline Senior VIP Member
    Jan 2016
    Olympia, WA
    216
    132 Post(s)
    The only way to answer this is to ask, what is the biggest area where you think the sound is lacking?
    Are your mids and highs not clear or loud enough?
    Is your bass too muddy?
    Is it that the bass just isn't loud enough?
  15. #12
    theabcs's Avatar
    Nov 2016
    Rialto, CA
    3 Post(s)
    Quote Originally Posted by jRi0T68 View Post
    I would say that the bass isn't loud enough and that I would like to improve this feature while maintaining the clarity.
  16. #13
    jRi0T68's Avatar
    Jan 2016
    Olympia, WA
    216
    132 Post(s)
    Start with a new box, I'd say. If you learn how and build it yourself, then when you decide to upgrade sub and amp, you'll be be prepared to build it a proper box from day 1.
  17. Thanks theabcs thanked for this post
  18. #14
    Jul 2005
    WA
    14,059
    40 Post(s)
    5947 Post(s)
    That's if the OP has the tools to do so.
    Will need a good design....and I know just who that would be @CSCStang
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  19. Thanks theabcs thanked for this post
  20. #15
    CSCStang's Avatar
    CSCStang is offline Enclosurist
    Mar 2014
    OC, Ca
    2,971
    412 Post(s)
    2 Thread(s)
    973 Post(s)
    I can help with a design, holler.
    Sent from my SCH-I605 using Tapatalk
    DAILY '12 Mustang AVH2700BS
    RS28F/682.9CF/PWX 8....ppi900.4/gmd5602 3 way active
    2 HDS208 TLINE @44hz...xtr2200.1
    BEATER '99 Silverado xcab AVH3600BHS
    X comps....c1c/PWX 8".....ppi600.2
    2 XFL 1544 TLINE @30hz....FSD3800.1
    DC 300 powerhouse....big 3 in both with 2/0 weld
    Check out my past builds at Cscstang customs on fb or cscstang_customs ig.
    I'll be back to building eventually....
Tags for this Thread
