+ Reply to Thread
Page 5 of 5 FirstFirst 1 2 3 4 5
Results 61 to 66 of 66
Reload Thread: Bye bye back seats....
  1. #61
    CRXBMPN's Avatar
    CRXBMPN is online now ---> TEAM B.L.O. ME <---
    Jul 2004
    Maine
    37
    8,906
    45
    1 Post(s)
    345 Post(s)
    Re: Bye bye back seats....
    Quote Originally Posted by hispls View Post
    I'd hope the pair of NS1s would give more power. They make legit rated power, hang with low impedance well enough and are strong with high voltage.
    I may have to waste a PTO day either Thurs or Fri this week, I can't carry any over and my job gives us Xmas day after instead of us having to use time so I miscalculated. If so, and you still need a place with a garage, I may be good. The only thing to be concerned with is........ the possible Nor'Easter coming up end of week.
    Team Bass Lovers Of MainE/The Loud Crowd/CentralMaineBassHeads
    2k5 SLAP Stock 2 National Champion - I feel old...!
    2009 Mazda 5 Mini Van - Shocker/Sundown 12s + 2x Sundown NS1 = 155.3 p.b. so far...
  2. #62
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,957
    15
    36 Post(s)
    4044 Post(s)
    Quote Originally Posted by CRXBMPN View Post
    I ordered the wrong part number from weldingsupply.com so I'm still waiting on ring terminals but I think even without I'd like to build up something to hold the batteries and re-mount the amps. We'll keep an eye on the weather and go from there I suppose.
  3. #63
    JonM's Avatar
    JonM is offline Member
    Jan 2017
    Columbus Ohio
    142
    77 Post(s)
    I'm new to this. What would you have paid if you took this to a shop and had them build it? How did you conceptualize the build before you started?
  4. #64
    beatzboi's Avatar
    beatzboi is offline Member
    Jul 2014
    United States
    129
    2 Post(s)
    41 Post(s)
    Quote Originally Posted by JonM View Post
    Obviously this is an extreme build, not your daily ride. Most I see are using cardboard boxes to mock up, or "conceptualize the build"
    Or if you are good with measurements, and sketch up you can do a mock setup there also
  5. #65
    The Camry's Avatar
    The Camry is offline Hey, I Try.
    Sep 2013
    Western Oregon
    2,883
    14 Post(s)
    1299 Post(s)
    Shops will always rip u off. Most of us can build a very loud or competition system for around 2000$
    Paying a shop to do that and you're talking atleast double to triple that.
    I haven't read this thread but id be willing to guess that he spent atleast500-1000 on wood alone
    Sent from my SGH-M919 using Tapatalk
    Gain on an amplifier to meant to be matched to the output voltage of your headunit. Think 3 volt, 4 volt, 5 volt pre out specs you see on headunit specs. This is how gain works for a given pre out(5 volt) theoretically. However most head units clip(start to distort) at around 80% of your volume so your 5 volt pre out wont give 5 volts Cleanly. You will most likely get 4 volts out at something like 33/40 on your volume knob and would thus set your gain to 4 volts. (these things can be measured with a GOOD Multimeter. )
    80% of your total volume is (max volume) X 0.8.
    Example is 40(is your max volume so, 40 X .8=32
  6. #66
    hispls's Avatar
    Sep 2009
    9,957
    15
    36 Post(s)
    4044 Post(s)
    So as an update I did get some more batteries in this winter and 00 gauge cable but didn't have a chance at all to test. Got back this spring and had some setbacks which prevented me from doing anything. I found I had a couple subs with tinsels broken so I performed some minor surgery to the subs and replaced them and can actually get around to some testing with the new amp.
    Happy with the numbers and still have some things to try. Here's video of outlaw metering we did while testing voltage at the amp.
    https://youtu.be/qFwMAeTvrT0
+ Reply to Thread
  1. Twisted's 4-15s @ 30hz 20 Cubes Box Build-Bye Back Seats :(
    By twistedchild420 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 07-03-2011, 12:05 AM
  2. Amps Under Back Seat?????
    By Geminidj2000 in forum Amplifiers
    Last Post: 12-13-2002, 10:45 AM
  3. Lift kit for back seat of new f-150?
    By Strick6_2 in forum General Discussion
    Last Post: 09-03-2002, 05:33 PM
  4. Does anyone know how to remove back seats?
    By MrLevir in forum General Discussion
    Last Post: 07-15-2002, 10:05 PM
  5. Replies: 2
    Last Post: 02-05-2002, 12:56 PM
