+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 24
Reload Thread: Jeep enclosure build Literally
    cherryman's Avatar
    cherryman is offline Junior Member
    Feb 2013
    Jackson TN.
    20
    5 Post(s)
    6 Post(s)
    Since I closed my Sub forum on this server I havent posted much here but this remains my favorite audio forum. I have been slammed with builds one after another and I encourage you to visit my website and you tube channel to see the more technical builds. Reason that brings me here today is not self promotion I thought I owed it to this forum to share a build thats very unique and to my knowledge has never been attempted. I was asked if it was possible to make the entire front end of a jeep to hold a 15" forte sub. Im only about 8 hours in to the actual fabrication so far(way more in autocad) so not alot to show you yet but it is taking shape. The headlights will be 6.5 midranges the blinkers asre bullet tweeters and the fog lights will be lights. The winch area holds the amp and the bumper is separated from the main enclosure to isolated and minimize vibration. the fenders are not done yet but should tie the rest of the look together. The hood spoiler will be probably the hardest part to fabricate.
    Attached Thumbnails Attached Thumbnails Jeep enclosure build Literally-27071.jpg   Jeep enclosure build Literally-27200.jpg
  2. Likes Slo_Ride, macsdad liked this post
  3. #2
    ObTechAudio's Avatar
    ObTechAudio is offline Senior VIP Member
    Apr 2014
    Provo, UT
    446
    9 Post(s)
    155 Post(s)
    Re: Jeep enclosure build Literally
    **** that's nice work!
  4. #3
    CSCStang's Avatar
    CSCStang is offline Enclosurist
    Mar 2014
    OC, Ca
    2,971
    409 Post(s)
    2 Thread(s)
    973 Post(s)
    Great work as always, Robert..
    Sent from my SCH-I605 using Tapatalk
    DAILY '12 Mustang AVH2700BS
    RS28F/682.9CF/PWX 8....ppi900.4/gmd5602 3 way active
    2 HDS208 TLINE @44hz...xtr2200.1
    BEATER '99 Silverado xcab AVH3600BHS
    X comps....c1c/PWX 8".....ppi600.2
    2 XFL 1544 TLINE @30hz....FSD3800.1
    DC 300 powerhouse....big 3 in both with 2/0 weld
    Check out my past builds at Cscstang customs on fb or cscstang_customs ig.
    I'll be back to building eventually....
  5. #4
    cherryman's Avatar
    Feb 2013
    Jackson TN.
    20
    5 Post(s)
    6 Post(s)
    Thanks Chris tomorrow Ill start building out the fenders and the the driving led lenses.
    Attached Thumbnails Attached Thumbnails Jeep enclosure build Literally-capture.jpg
  6. #5
    The Camry's Avatar
    The Camry is offline Hey, I Try.
    Sep 2013
    Western Oregon
    2,777
    13 Post(s)
    1254 Post(s)
    Wheres this going?
    Sent from my SGH-T999 using Tapatalk
    Gain on an amplifier to meant to be matched to the output voltage of your headunit. Think 3 volt, 4 volt, 5 volt pre out specs you see on headunit specs. This is how gain works for a given pre out(5 volt) theoretically. However most head units clip(start to distort) at around 80% of your volume so your 5 volt pre out wont give 5 volts Cleanly. You will most likely get 4 volts out at something like 33/40 on your volume knob and would thus set your gain to 4 volts. (these things can be measured with a GOOD Multimeter. )
    80% of your total volume is (max volume) X 0.8.
    Example is 40(is your max volume so, 40 X .8=32
  7. #6
    cherryman's Avatar
    Feb 2013
    Jackson TN.
    20
    5 Post(s)
    6 Post(s)
    Its going in the back of the his Jeep. He sent a couple different angles of the front end I provided one in the thread starter. I was also provided with the paint codes to exactly match the colors. we are debating painting the hooks blue to match or silver to mimic chrome.
  8. #7
    The Camry's Avatar
    Sep 2013
    Western Oregon
    2,777
    13 Post(s)
    1254 Post(s)
    Quote Originally Posted by cherryman View Post
    Im impressed by the hooks shape and the grating. Talk about fine detail
  9. #8
    cherryman's Avatar
    Feb 2013
    Jackson TN.
    20
    5 Post(s)
    6 Post(s)
    Thanks the little details will continue to accumulate like the number circles in the driving lights drawing the eye everywhere. There is no diamond plate on his jeep I just thought the extra texture would add more realism. Unfortunately some characteristics cant be duplicated without subtracting from the needed net volume so trade offs were made. The two ports exit out under the fenders just like hot rod exhaust they will have to be turned up to avoid the backseat obstructing airflow. Its important to keep all the fabrication MDF based to sell the over the top factor. Making the headlight spoiler concerns me the most still not sure how to it. The finished video of the entire process will shed more info on this build. I might layer stack and contour sand like the dodge box I made 2yrs ago(https://www.youtube.com/watch?v=jMo-89_Ot54).
  10. #9
    cherryman's Avatar
    Feb 2013
    Jackson TN.
    20
    5 Post(s)
    6 Post(s)
    Ive had a chance to get the fenders,ports,lenses and 6.5 midrange baffles. I also spent time recreating the fender gaps and body panel gaps which was really rewarding when usually gaps are bad in the enclosures. The bottom bumper which slides out to mount/wire the amp and isolate the amp from vibration. I wanted to make the bumper roundness and curve back to the fog lights closer to the picture but the bumper had to be offset further out to make the amp mount correctly. I expect the black paint to maybe alter the depth perception in that area. The width of the jeep stops the fenders from being wider another trade off the get the volume needed for the sub.
    Attached Thumbnails Attached Thumbnails Jeep enclosure build Literally-1.jpg   Jeep enclosure build Literally-2.jpg   Jeep enclosure build Literally-3.jpg   Jeep enclosure build Literally-4.jpg   Jeep enclosure build Literally-5.jpg
  11. Likes oxsign liked this post
  12. #10
    cherryman's Avatar
    Feb 2013
    Jackson TN.
    20
    5 Post(s)
    6 Post(s)
    Bumper painted fake fog lights installed and headlight spoiler fabricated. Decided to build it in sections and build up layers. Then I needed to hand sculpt sand to the final look.
    Attached Thumbnails Attached Thumbnails Jeep enclosure build Literally-20160709_160547.jpg   Jeep enclosure build Literally-27813.jpg
  13. #11
    fattest1here's Avatar
    fattest1here is offline Junior Member
    May 2010
    Mesquite, TX
    29
    1 Post(s)
    Excellent Work. It's going to look sick.
  14. #12
    cherryman's Avatar
    Feb 2013
    Jackson TN.
    20
    5 Post(s)
    6 Post(s)
    Here's the finished box video soon will explain the entire process keep in mind the windshield is only for car shows and will be removed most of the time. The bumper and enclosure are two different pieces to minimize vibration. Bumper lights are on one channel and enclosure lights are on a second channel wih a keychain remote.
    Attached Thumbnails Attached Thumbnails Jeep enclosure build Literally-20160906_113106.jpg   Jeep enclosure build Literally-20160906_113054.jpg   Jeep enclosure build Literally-20160906_113100.jpg   Jeep enclosure build Literally-20160707_125306.jpg   Jeep enclosure build Literally-20160719_101957.jpg
  15. Likes oxsign liked this post
  16. #13
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    12,654
    33 Post(s)
    5330 Post(s)
    That just blows my mind how good that is. Simply amazing. Esp the grated/black part. Looks real.
    Nice work indeed. Would like to see this published in magazine or something. (take that pimp my ride, lol)
    I see you got a CNC router in the background. I'm a CNC machinist myself. Just completed my sub enclosure in my avatar last week.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
  17. #14
    cherryman's Avatar
    Feb 2013
    Jackson TN.
    20
    5 Post(s)
    6 Post(s)
    Thanks Boomin Ill get this video posted soon on my youtube channel. Heres another interesting build just completed a true stealth box.
    Attached Thumbnails Attached Thumbnails Jeep enclosure build Literally-20160811_112518.jpg   Jeep enclosure build Literally-20160811_112531.jpg
  18. Likes oxsign liked this post
  19. #15
    Jul 2005
    WA
    12,654
    33 Post(s)
    5330 Post(s)
    Slick. Very slick. Who would've thought that!!
    I remember before the internet stated, I heard read an article about some guy tuning his coffee table as a HT sub enclosure.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
+ Reply to Thread
  1. Enclosure Build
    By THUMPPER in forum Enclosure Design & Construction Help
    Last Post: 04-17-2007, 08:51 AM
  2. Enclosure Build Pics
    By sub sonic in forum Enclosure Design & Construction Help
    Last Post: 03-24-2007, 04:51 PM
  3. TC-3000 12" enclosure build up. lots of pics.
    By PowerNaudio in forum Enclosure Design & Construction Help
    Last Post: 11-22-2006, 08:27 PM
  4. WTB Air Tools for Fiberglass & Enclosure Building!!
    By danteBirosel in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 08-14-2006, 12:28 AM
  5. PV Sound 01 --> Enclosure Build A++++
    By twoohfour in forum Buyer/Seller Feedback
    Last Post: 02-22-2006, 09:31 PM
