+ Reply to Thread
Page 2 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 16 to 30 of 159
Reload Thread: BoogerMan's 12k Crossfire build in a 1998 Toyota T100 SR5
  1. #16
    els1989's Avatar
    els1989 is offline CarAudio.com Elite
    Mar 2015
    Minnesota
    1,352
    6 Post(s)
    581 Post(s)
    Re: BoogerMan's 12k Crossfire build in a 1998 Toyota T100 SR5
    I've got a set of add a leafs I'd sell you for 10 bucks from fab tech... They should work in your truck for the added wait
  2. #17
    basshz's Avatar
    basshz is offline Junior Member
    Oct 2015
    Earth
    1 Post(s)
    2 Post(s)
    Double check your weight ratings for your truck. The rating should list three sets. One set of weight ratings for the cab loaded, another set for the bed loaded, and another for towing. My truck lists these weights on the drivers side door label. Another thing to consider is how old your leaf springs are and how strong they actually are in stock new form. If you will be going over the maximum listed weight ratings you should definitely think about beefing up your suspension.
    My trucks stock leaf springs were sh**** for hauling and keeping a safe ride at highway speeds.
    I have used shocks with stiffer compression, adjustable shocks, roadmaster active suspension and torklift helpers. For my truck what ended up working the best was some Monroe airshocks and a $40 leaf spring helper set from o'reillys.
    Try to cut as a big a hole as possible (or what you're comfortable with) for your box.
    Are you planning to use the whole bed (going over the wheel well humps?) or just keeping it down the middle?
  3. #18
    BoogerMan's Avatar
    BoogerMan is offline CarAudio.com Elite
    Jan 2016
    AZ
    709
    4 Post(s)
    238 Post(s)
    @CSCStang , not sure about the box specs yet, but definitely a 4th order. Most likely a v style setup with 3 subs on each side. My bed dimensions are 49" between wheel wells, 17" tall, and 72" deep.
    Thanks @els1989 . I'll let you know once I get around to that part of the build.
    @basshz awesome thank you! The sticker says GVWR 6,000 lbs and GAWR is FRT 2,900 lbs and RR is 3,400 lbs. No idea what is for what haha
    I think what I'll do is meet up with the guy in my group who is the engine/mechanic guy. Hopefully he can tell me if my current leaf springs are okay or if they need to be replaced and if I should do helper bags, helper springs, airs shocks etc once we know exactly how much extra weight I'll be adding
    The cutout is already 52" wide and 8" tall. I'm going to try to make that work so I don't have to cut it and reseal with a new boot but if whoever designs my box says cut out more height I will lol.
    I'll be using just between the wheel wells since I don't think I'll need more space than that. That's about 34 cubes external so should be plenty for 6 12s in a 4th
    BoogerMan's 2011 Toyota Camry SE
    Lots of SoundQubed. 151.5db at 38hz usaci outlaw
  4. #19
    BoogerMan's Avatar
    Jan 2016
    AZ
    709
    4 Post(s)
    238 Post(s)
    Got the back seats, port, and 2 subs pulled out tonight. My small screw gun died and I can't get the other 2 subs out without it. I'll pull those out Thursday and then hopefully have the box out by the weekend
  5. #20
    basshz's Avatar
    Oct 2015
    Earth
    1 Post(s)
    2 Post(s)
    Quote Originally Posted by BoogerMan View Post
    GVWR is your gross vehicle weight rating. This is roughly the total weight of your vehicle unloaded. Whether it takes into account fuel or not is hard to say.
    GAWR is gross axle weight rating. This is the rating of weight each axle can sustain. FRT is front and RR is rear. Again it's hard to say how much of the weight of your vehicle is distributed over the axles. You would need to do corner weighting to get an idea.
    52" and 8" tall is a big cutout so you should be good. Heck at those dimensions I personally would be tempted to try a parallel tuned 6th order. That depends on if your subs would model good for it though.
    Your bed is definitely way more accommodating than mine (72" length, 43" width :between wheel wells:, 16" high :with tonneau cover: ) but even at 34 cubes that number starts to shrink down quick with all displacements. Hopefully your box designer can maximize the space.
    With your cutout dimension though a 4th order would be easiest. When I get home I can send a pic of one of my 4ths layout that might give you an idea or two.
  6. #21
    BoogerMan's Avatar
    Jan 2016
    AZ
    709
    4 Post(s)
    238 Post(s)
    Quote Originally Posted by basshz View Post
    Thanks for all the info! I appreciate it.
    I think I'm going to stick with a 4th even if I could fit a 6th because it will be much easier for me to make a 4th. I've only built one box in my life (Camry build) so I'm still new to this, but I want to do as much as I can on my own as I really enjoy it and enjoy learning!
    I have a guy that is going to make me a dual alt bracket and then I'll have someone design the box, but besides that the rest will most likely be done by me. I can't improve my skills if I pay someone else to do it haha.
    Here is one of my teammates blow through. Super clean and pretty **** loud for only the C7s
    I think I'll do something similar to this but 3 subs on each side
  7. Likes timma100, CoolHandMark liked this post
  8. #22
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    12,654
    33 Post(s)
    5329 Post(s)
    Tuned in.
    Last build was phenomenal.
    Surely this one will be just as ****** as the last
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
  9. Thanks BoogerMan thanked for this post
    Likes BoogerMan liked this post
  10. #23
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    I just finished an 8 12's 4th with C7's, so must be Crossfire month lol
    I'm guessing you'll have to shrink the opening into the cabin as it's 400^2 of area and with a V config firing at the opening I doubt your subs will want that much. The 8 12's I did is around 325^2 as that's what tested best for 25-50hz passband.
    And I agree that mid 50's shouldn't be a problem as those are strong subs....
  11. Thanks BoogerMan thanked for this post
  12. #24
    Jul 2005
    WA
    12,654
    33 Post(s)
    5329 Post(s)
    Quote Originally Posted by mlstrass View Post
    Any pics? Love me some multiple sub builds. That's if boogerman doesn't mind.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  13. #25
    mlstrass's Avatar
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Don't want to threadjack.....
  14. #26
    Jul 2005
    WA
    12,654
    33 Post(s)
    5329 Post(s)
    Yeah I know...that's why I said if boogerman didn't mind.
    I'm pretty sure he won't
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  15. #27
    BoogerMan's Avatar
    Jan 2016
    AZ
    709
    4 Post(s)
    238 Post(s)
    Post away! I was going to do 8 C7s but could only fit them if I built around the wheel wells and that seemed a bit out of my comfort zone for my second build. I'd love to see how it turned out though!
    And yep, I won't be using the entire cutout for the port. Just whatever I need which I know won't be 400"^2
    I found a local acrylic supplier so I might be doing an acrylic top and back with blue LEDs in the box to really make it look nice and professional
  16. #28
    BoogerMan's Avatar
    Jan 2016
    AZ
    709
    4 Post(s)
    238 Post(s)
    Got a couple questions about wire and battery bus bars.
    I want to do blue for my positive and black for my negative.
    Is this welding cable okay? Hard to find blue
    2/0 WELDING CABLE BLUE
    Then here is the black on the same site
    2/0 CCI ROYAL EXCELENE WELDING CABLE BLACK
    Also, how many runs should I do if I get 2/0? I'm thinking 2 runs positive and 2 runs negative should be good since front to back battery distance will only be about 10-15 feet.
    And who do you guys get bus bars through? Toolmaker seems to make nice stuff...
    Thanks!
  17. #29
    BoogerMan's Avatar
    Jan 2016
    AZ
    709
    4 Post(s)
    238 Post(s)
    Look what came in the mail today
    Can't wait to start playing with this bad boy!
  18. Likes timma100 liked this post
  19. #30
    Papermaker85's Avatar
    Papermaker85 is online now Better built than bought!
    Dec 2006
    New orleans LA
    32
    12,004
    66 Post(s)
    2 Thread(s)
    4921 Post(s)
    Thanks!
    between the batteries Id do at minimum the total of the entire load. if you have 12kw your looking at close to 900 amps. I personally would do 3 runs.
    that being said i would eliminate the front battery and just run a 1/0 to the front distro panel feeding the cars electronics. and just run a 2/0 to the rear battery from each alt with buss-bars between the batteries..
    Insidious Audio
+ Reply to Thread
  1. BoogerMan's 5K SoundQubed Build in a 2011 Toyota Camry SE
    By BoogerMan in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 04-01-2017, 06:25 PM
  2. My old school build in 1993 Cobra. 1996-1998 time period i think
    By Husker in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 03-19-2012, 02:03 AM
  3. PROJECT: 1998 Lumina Build-in
    By skeptikal in forum General Discussion
    Last Post: 12-30-2004, 07:21 AM
  4. Trying to put a system in my 1998 Civic and need some help!!
    By Intercooler in forum General Discussion
    Last Post: 11-16-2004, 11:15 PM
  5. any one tell me speaker size in a 1998 Intrepid?
    By mickyd32 in forum Speakers
    Last Post: 03-24-2004, 11:24 PM
