+ Reply to Thread
Page 12 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12
Results 166 to 170 of 170
Reload Thread: BoogerMan's 12k Crossfire build in a 1998 Toyota T100 SR5
  1. #166
    BoogerMan's Avatar
    BoogerMan is offline CarAudio.com Elite
    Jan 2016
    AZ
    716
    4 Post(s)
    239 Post(s)
    Plastidip results. Also installed the new signal lights and parking lights that I tinted with 20% film a little while back.
    BoogerMan's 2011 Toyota Camry SE
    Lots of SoundQubed. 151.5db at 38hz usaci outlaw
  2. #167
    Jeffro83's Avatar
    Jeffro83 is offline Senior VIP Member
    Dec 2017
    Indianapolis, IN
    193
    80 Post(s)
    Re: BoogerMan's 12k Crossfire build in a 1998 Toyota T100 SR5
    Excellent work bro everything you've done has been top-notch start to finish hope mine comes out half as nice
  3. #168
    BoogerMan's Avatar
    Jan 2016
    AZ
    716
    4 Post(s)
    239 Post(s)
    Quote Originally Posted by Jeffro83 View Post
    Thanks man. I'm really happy with everything so far! Take your time is the best advice I can give lol.
    Got a few more things done.
    Siliconed my rear window latch shut. Also siliconed between the sliding window and stationary window. Don't want any water leaks.
    Put 2 layers of closed cell foam in the track that the window slides on. Trying to prevent this back window from making horrific noises haha.
    Did a little paint correction today. Doesn't look too bad for a paint job done in 1997.
    Wrote this up for a buddy:
    Wash vehicle. Go over everything with clay bar and quik detailer to get the surface smooth. Lightly wet sand any orange peal or rough spots with 2000 grit then hit those with ultimate compound to remove most of the haze created by the sanding. Then go over the entire vehicle with ultimate compound again to remove any left over haze and any heavy surface scratches. Next go over everything with swirl x to remove light swirls and scuffs. Then ultimate polish to really bring out the color. Finish it all off with a coat of nxt gen tech wax 2.0. All the products used are Meguiars.
  4. #169
    BoogerMan's Avatar
    Jan 2016
    AZ
    716
    4 Post(s)
    239 Post(s)
    The box is finished and loaded up. Turned out shiny and smooth. It's not perfect but we spent a lot of time on it and I'm very happy with the results. Exactly what I wanted Still need to bolt it down and load up subs/wire, plexi window, and LEDs, but it's pretty much done! Still polishing the braces.
    View through the port while sitting the cab
    View through the plexi window back by the tailgate
    Timbren SES springs doing work! The box probably weighs 600 lbs as is and my truck only dropped a 1/2" from 40.5" to 40" from the ground to fender.
    40.5"
    40"
  5. #170
    Jeffro83's Avatar
    Dec 2017
    Indianapolis, IN
    193
    80 Post(s)
    Man that paint looks like it was just done yesterday would have never thought it could come back like that I'm definitely taking my build a lot slower than I would like mostly due to work and other obligations not to mention finances but my main goal is just to get everything installed in playing then I will come back later and put the finishing touches on it I know it's not the best way but after not having a system for about 10 years it's killing me plus whil I do want mine to be nice I am just not prepared to put that much effort into it right now as far as making it look like yours I do carpentry and remodeling for a living between that and car audio I've done enough custom work to know that the type of quality you are achieving takes massive amounts of time and patience although one day I would like to either get mine on that level or maybe on the next build
+ Reply to Thread
  1. BoogerMan's 5K SoundQubed Build in a 2011 Toyota Camry SE
    By BoogerMan in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 04-01-2017, 06:25 PM
  2. My old school build in 1993 Cobra. 1996-1998 time period i think
    By Husker in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 03-19-2012, 02:03 AM
  3. PROJECT: 1998 Lumina Build-in
    By skeptikal in forum General Discussion
    Last Post: 12-30-2004, 07:21 AM
  4. Trying to put a system in my 1998 Civic and need some help!!
    By Intercooler in forum General Discussion
    Last Post: 11-16-2004, 11:15 PM
  5. any one tell me speaker size in a 1998 Intrepid?
    By mickyd32 in forum Speakers
    Last Post: 03-24-2004, 11:24 PM
