+ Reply to Thread
Page 11 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11
Results 151 to 159 of 159
Reload Thread: BoogerMan's 12k Crossfire build in a 1998 Toyota T100 SR5
  1. #151
    BoogerMan's Avatar
    BoogerMan is offline CarAudio.com Elite
    Jan 2016
    AZ
    709
    4 Post(s)
    238 Post(s)
    Re: BoogerMan's 12k Crossfire build in a 1998 Toyota T100 SR5
    Quote Originally Posted by Papermaker85 View Post
    Nice. Gonna be epic
    Thanks man I hope so!
    Got the alt grounds done. Still waiting on my new 16 ton hydraulic crimper so I used my H press instead. It actually worked really well
    BoogerMan's 2011 Toyota Camry SE
    Lots of SoundQubed. 151.5db at 38hz usaci outlaw
  2. #152
    oxsign's Avatar
    oxsign is offline No Affiliation
    Jan 2006
    Sanford, FL
    5,833
    5 Post(s)
    259 Post(s)
    Very nice. Make sure you paint or gel all that area you sanded for the ground so it doesn't rust up on you. This is coming out great so far.
  3. #153
    BoogerMan's Avatar
    Jan 2016
    AZ
    709
    4 Post(s)
    238 Post(s)
    Quote Originally Posted by oxsign View Post
    Thanks! Yeah I'll definitely spray over it with some black rustoleum. Just waiting to make sure this placement is going to be final.
    Got my Plasti Dip Spray System in the other day! The gallon of black should be here Monday so it will be time to blackout the remaining chrome pieces on the truck.
    4 coats of high build primer sprayed on the pillars.
    Sanded the primer with 220 then added some body filler and sanded again. A few more coats of primer and some glazing putty before getting sprayed with black.
    Got the box flipped up on its side. Will get primed as soon as the braces are done.
    You can really see the angle of the baffles here. I'm getting really excited!
    Added Clippo and the Ohio Gen logo to the alt bracket
    Made a better base for the stock fuse box. 13 ply birch with 3 coats of primer and black
    Secured the battery rack with some better bolts, removed the yellow base and added a strap over the top. The battery fits much tighter now and isn't going anywhere. Also got it painted with 3 coats of primer and black.
  4. #154
    staan's Avatar
    staan is offline Senior VIP Member
    May 2016
    new orleans, la
    406
    284 Post(s)
    nice work
  5. #155
    wew lad's Avatar
    wew lad is offline wew lad inc
    Mar 2015
    Des Moines, IA
    4,515
    45 Post(s)
    2330 Post(s)
    great progress as always man!
    ew to the optima, though lol
    Quote Originally Posted by JohnKuthe View Post
    I AM The Future of personal transportation, NOW!!
    Quote Originally Posted by Loudz View Post
    Pretty sure everyone on this site hates you (@JohnKuthe) more then me and that's very hard to accomplish.
  6. #156
    BoogerMan's Avatar
    Jan 2016
    AZ
    709
    4 Post(s)
    238 Post(s)
    Quote Originally Posted by staan View Post
    nice work
    Thanks!
    Quote Originally Posted by wew lad View Post
    Thanks man! lol I'm just using it until I get my Limitless installed. It will be disconnected after the lithium is put in so it doesn't drag down the resting voltage.
    Second round of primer done. Glazing putty around the seems next then one last coat of primer then wet sand and black base
    I figured I should probably clean up my engine since I am going to have my hood open at shows.
    Before
    After
    Before
    After
    Before
    After
  7. #157
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    12,191
    31 Post(s)
    5119 Post(s)
    Those pillars tho...should make a statement. Can't wait for this to be done!!
    My Optima redtop finally gave out, after 6 years. Went with Interstate.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
  8. #158
    BoogerMan's Avatar
    Jan 2016
    AZ
    709
    4 Post(s)
    238 Post(s)
    That's what we are hoping! Same here lol.
    We got a couple more things done this past weekend.
    Painted the tailgate hinges black. I'm trying to make it look half as decent as it should sound
    Before
    After
  9. #159
    BoogerMan's Avatar
    Jan 2016
    AZ
    709
    4 Post(s)
    238 Post(s)
    We made a little more progress on the doors. Just need to cover up the other hole with a panel then we will start playing with some 2 part foam.
    Got my under body leds cut to length and ready to be installed next
    Decided to take out the 1/4" self tappers and use 5/16" bolts to go all the way through my frame. I feel more comfortable with the bolt in there for the long run. It ended up being a little easier than expected since I was able to use 2 factory holes. Got it sprayed with some rustoleum paint as well.
+ Reply to Thread
  1. BoogerMan's 5K SoundQubed Build in a 2011 Toyota Camry SE
    By BoogerMan in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 04-01-2017, 06:25 PM
  2. My old school build in 1993 Cobra. 1996-1998 time period i think
    By Husker in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 03-19-2012, 02:03 AM
  3. PROJECT: 1998 Lumina Build-in
    By skeptikal in forum General Discussion
    Last Post: 12-30-2004, 07:21 AM
  4. Trying to put a system in my 1998 Civic and need some help!!
    By Intercooler in forum General Discussion
    Last Post: 11-16-2004, 11:15 PM
  5. any one tell me speaker size in a 1998 Intrepid?
    By mickyd32 in forum Speakers
    Last Post: 03-24-2004, 11:24 PM
