+ Reply to Thread
Page 9 of 72 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 59 ... LastLast
Results 121 to 135 of 1077
Reload Thread: Alex's Silverado
  1. #121
    jordon's Avatar
    jordon is offline CarAudio.com Elite
    Jul 2014
    Fort Bragg, NC
    822
    6 Post(s)
    399 Post(s)
    Re: Alex's Silverado
    I say real world testing is the best way to find out.
  2. #122
    adulbrich's Avatar
    adulbrich is offline Lock up your daughters!
    May 2014
    Ames, Iowa
    19
    13,834
    118 Post(s)
    6117 Post(s)
    Yeah, that's what I was thinking.
    If it doesn't do what I want, I'll just keep adding port length until the hair gets
    My Silverado is under construction AGAIN http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/621466-alexs-silverado.html
    Quote Originally Posted by massivespl View Post
    Love is when she licks your butthole and try's to kiss you and u smack her but she doesn't get mad because she know that nasty and she in the wrong
    Quote Originally Posted by Slo_Ride View Post
    Fuck me running. Even I wouldnt eat stripper snatch.
    Quote Originally Posted by ilikeradios View Post
    I would rather beat you to death with a garden rake then talk politics with you due to your overwhelming ignorance.
    Quote Originally Posted by Joseph7195 View Post
    A three legged hooker walks into a bar. Yadda Yadda Yadda, I ended up sucking a dick.
    Quote Originally Posted by gckless View Post
    When that hooker turns out to have a cock. That's bigger than yours.
    Quote Originally Posted by LongThrow View Post
    If I had $2,000, I wouldn't be running kicker comps.
  3. #123
    jordon's Avatar
    Jul 2014
    Fort Bragg, NC
    822
    6 Post(s)
    399 Post(s)
    Quote Originally Posted by adulbrich View Post
    I doubt you will have that much trouble pulling a hair trick
  4. #124
    adulbrich's Avatar
    May 2014
    Ames, Iowa
    19
    13,834
    118 Post(s)
    6117 Post(s)
    Quote Originally Posted by jordon View Post
    I really hope not, lol
    I finally did it with the Z's after changing the amp and headunit level ratios. Such a small detail made a huge difference
  5. #125
    Massive spl's Avatar
    Massive spl is offline Banned
    Jun 2015
    Michigan
    3,007
    52 Post(s)
    1 Thread(s)
    1837 Post(s)
    I just re-measured now and I have 30.4 cubes net after I put the baffle on
    ^ @hispls ; too
    Because I have so much internal volume, my port doesn't have to be very long. I only need about 16 inches of port length to get my 25hz tuning.
    However, I got to thinking. If I just make the baffle 4" thick and don't add anything extra for more port length, I'm tuned to ~30hz. I think that would meter really well, but would I still be able to do crazy hairtricks with a 30hz tuning and next to no port length? My last box was tuned to 27hz and had like 42" of length, which is why I ask. I don't care if it's a stupid question, because I guess this build log is kinda wrecked already
    EDIT: Or, is real world testing the best way to find out? I could easily add length to the port later on if it doesn't work out well
    I like low tuned big box. My truck is tuned to 30hz and my next wall will be tuned to 25hz or lower... You don't loose output tuned low if you do it right, prime example is the Hhr, it's tuned to 25hz and does 155db at 23hz and 160.5db at 35hz. ur pretty close to Michigan you should come hear the Hhr one of these days.
  6. #126
    Rich B's Avatar
    Rich B is offline CarAudio.com Veteran
    Oct 2006
    *under the rainbow*
    6,504
    14
    235 Post(s)
    It started raining, so I figured I'd take a quick pic of my progress and update my build logs. One side is almost done
    The white caulk in the background was there from my last build. I'm salvaging the floor and back panels. I'll scrape it off before I resin the corner and side wall
    Those are 2x4's turned sideways. The side is 3" of solid wood. Glued and screwed, plus will be covered with resin inside and out. Very sturdy to say the least
    Thats a lot of work, very good.
    At that stage it looked like your truck was having a sauna installed!
    Subscribed, I like your project, cant wait to see it getting closer to being finished.
  7. Thanks adulbrich thanked for this post
  8. #127
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,680
    15
    35 Post(s)
    3856 Post(s)
    Thanks, it was just the way you worded it. I couldn't tell if you were serious
    Hispls would disagree that I need more power
    Oh no, I was just joking with you earlier. You could actually gain as much as 8dB from doubling power. You just won't know until you try it.
  9. Likes Full Tilt liked this post
  10. #128
    mrpep's Avatar
    mrpep is offline CarAudio.com Elite
    Apr 2014
    chicago
    1,105
    13
    3 Post(s)
    482 Post(s)
    Alex's Silverado
    So are you screwing the 2x4's together and are you using any glue ? No criticism from it's a serious question. Anyway, the concept seems legit , let us know how it turns out.
  11. #129
    Jun 2015
    Michigan
    3,007
    52 Post(s)
    1 Thread(s)
    1837 Post(s)
    Quote Originally Posted by mrpep View Post
    So are screwing the 2x4's together and any glue ? No criticism from it's a serious question. Anyway, the concept seems legit , let us know how it turns out.
    2x4 are glued and screwed. U must be blind not to see it in the pictures. Have u never seen a shell get built before?
  12. #130
    mrpep's Avatar
    Apr 2014
    chicago
    1,105
    13
    3 Post(s)
    482 Post(s)
    Never but I assumed and cool beans bro, wish you the best in you build .
  13. #131
    adulbrich's Avatar
    May 2014
    Ames, Iowa
    19
    13,834
    118 Post(s)
    6117 Post(s)
    Quote Originally Posted by Massive spl View Post
    Yeah, true. I do like the idea of having a short port so you can look in and see the motors easily though
    I drove half way to Tennesse and back on Friday without my mom knowing, but Michigan is much further, lol. I'd definitely have to have her approval
    Quote Originally Posted by Rich B View Post
    Thanks, lol. Finally a positive comment
    Quote Originally Posted by hispls View Post
    Ok, there it's easy to detect sarcasm
    Of course, glued and screwed. Then going to resin over everything
    Thanks
  14. #132
    Jun 2015
    Michigan
    3,007
    52 Post(s)
    1 Thread(s)
    1837 Post(s)
    Thanks
    Dang u rebel
  15. #133
    adulbrich's Avatar
    May 2014
    Ames, Iowa
    19
    13,834
    118 Post(s)
    6117 Post(s)
    Dang u rebel
    Ikr?
  16. #134
    Jun 2015
    Michigan
    3,007
    52 Post(s)
    1 Thread(s)
    1837 Post(s)
    http://youtu.be/_aCCK3bkpnU
    If I was you I'd do a top port like this if u can fit three 21s staggered.
  17. #135
    germanyt's Avatar
    germanyt is offline CarAudio.com Elite
    Nov 2005
    Ponchatoula, La
    34
    1,665
    3 Post(s)
    346 Post(s)
    ^ @hispls ; too
    Just use the thickness of the baffle as the port. Lengthen if necessary. 30 cubes at 30hz with your power would be nasty.
    Check out what I'm up to here:
    https://www.facebook.com/bayousound.net/?ref=aymt_homepage_panel
    Brick and mortar store coming eventually. Website not ready so down until further notice.
+ Reply to Thread
  1. 94 Silverado, installing rear speakers
    By Nate8880 in forum Wiring, Electrical and Installation Help
    Last Post: 07-03-2002, 12:09 AM
  2. ANyone with Sierra/Silverado...
    By SierraonDubs in forum Subwoofers
    Last Post: 06-23-2002, 06:22 PM
  3. 2002 Chevy Silverado Help!!
    By cmcnally in forum Wiring, Electrical and Installation Help
    Last Post: 05-19-2002, 08:16 PM
  4. 81 Silverado
    By Garfield in forum General Discussion
    Last Post: 02-26-2002, 07:33 PM
  5. 81 Silverado
    By Garfield in forum Wiring, Electrical and Installation Help
    Last Post: 02-19-2002, 03:41 PM
Tags for this Thread
