+ Reply to Thread
Page 71 of 72 FirstFirst ... 21 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 LastLast
Results 1,051 to 1,065 of 1077
Reload Thread: Alex's Silverado
  1. #1051
    staan's Avatar
    staan is online now Senior VIP Member
    May 2016
    new orleans, la
    394
    274 Post(s)
    Re: Alex's Silverado
    Quote Originally Posted by Louisiana_CRX View Post
    The green wire should be constant
    why on earth would you try and give advice on something that could cause damage without actually knowing?
  2. #1052
    Papermaker85's Avatar
    Papermaker85 is offline Better built than bought!
    Dec 2006
    New orleans LA
    32
    11,492
    58 Post(s)
    2 Thread(s)
    4721 Post(s)
    This is a very very very simple circuit.
    The primary input power is switched via the ignition.
    When the relay's coil has current flow it closes the contacts.
    Its called a switched power supply.
    The sensing wire is to regulate the alternators output and voltage.
    The field wire is for a run status
    The rest is history.
    Insidious Audio
  3. #1053
    los33's Avatar
    los33 is offline Car Audio G
    Apr 2014
    Houston, TX
    3,231
    24 Post(s)
    2059 Post(s)
    Quote Originally Posted by LosissaTool View Post
    So fukking irrelevant to the fullest.
    What on earth made you come in and try so boldly to make such an idiotic post as this?
    Is there not stopping the amount of non-intelligent posts you already provide daily?!?
    Sent from my Z970 using Tapatalk
  4. #1054
    Dec 2006
    New orleans LA
    32
    11,492
    58 Post(s)
    2 Thread(s)
    4721 Post(s)
    Quote Originally Posted by los33 View Post
    Its that simple. Its a ******* alternator. Lol
    Insidious Audio
  5. #1055
    adulbrich's Avatar
    adulbrich is offline Lock up your daughters!
    May 2014
    Ames, Iowa
    19
    13,781
    118 Post(s)
    6103 Post(s)
    Quote Originally Posted by SounDrive View Post
    I still stand by my opinion that 6 of the SDA3 15s in a ported wall with a good design would be much louder than anything you've tried so far. There just isn't enough room inside the cab to do a bandpass with a lot of cone area while maintaining good airspace and ratios.
    Our 4th order for 8 SDA3 15s is 48 cubes of airspace, not counting the displacement of the subs and the enclosure itself. It's doing a 161 (for now, we need to work on several issues robbing from the score) two Taramps Bass 12k wired at 1 ohm each, 7 d3100s, and a single 320a alternator. We gave out 100+ demos 2 Saturdays ago at Slamology with very little downtime. You can downsize your power and electrical a LOT and still be very loud and demo all day, and practical to drive daily. With a solid design, around 10k clamped should net you around a 160 with a musical wall.
    I sold 2 of them to Martin here and I still have 6, so I could try that.
    He's on my ignore list, so his posts here don't really matter. I suggest you add him too
    My Silverado is under construction AGAIN http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/621466-alexs-silverado.html
    Quote Originally Posted by massivespl View Post
    Love is when she licks your butthole and try's to kiss you and u smack her but she doesn't get mad because she know that nasty and she in the wrong
    Quote Originally Posted by Slo_Ride View Post
    Fuck me running. Even I wouldnt eat stripper snatch.
    Quote Originally Posted by ilikeradios View Post
    I would rather beat you to death with a garden rake then talk politics with you due to your overwhelming ignorance.
    Quote Originally Posted by Joseph7195 View Post
    A three legged hooker walks into a bar. Yadda Yadda Yadda, I ended up sucking a dick.
    Quote Originally Posted by gckless View Post
    When that hooker turns out to have a cock. That's bigger than yours.
    Quote Originally Posted by LongThrow View Post
    If I had $2,000, I wouldn't be running kicker comps.
  6. #1056
    Dec 2006
    New orleans LA
    32
    11,492
    58 Post(s)
    2 Thread(s)
    4721 Post(s)
    Ill put money i could streetbeat low to mid 150s with 6 of those drivers in your truck.
    Ill tell you the start 3 on top 3 on bottom port in the middle and a few tricks in the box..
    Insidious Audio
  7. #1057
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,376
    15
    32 Post(s)
    3681 Post(s)
    Quote Originally Posted by adulbrich View Post
    ok, positive still needs to be switched so it doesn't drain batteries
    Yes, you want it to only energize when the car is running.
  8. #1058
    adulbrich's Avatar
    May 2014
    Ames, Iowa
    19
    13,781
    118 Post(s)
    6103 Post(s)
    Quote Originally Posted by hispls View Post
    Right, is my diagram I posted correct? You've obviously used these before. I just want to be sure before I hook them up
  9. #1059
    SounDrive's Avatar
    SounDrive is offline www.soundrive.audio SounDrive is a Supporting Member of the forum!
    SounDrive is a Supporting Vendor of the forum!
    Apr 2013
    Lebanon, TN
    3,071
    20 Post(s)
    1346 Post(s)
    That is correct.
    Also to answer your earlier question about the 911, you want to use one 911 per external regulated alternator. You *can* run two alts per box, but it will shorten the life of the regulator. Three alts on one box won't last long at all. I had one fail on me at a show when running two alts, then swapped to one regulator per alt and never had any more issues
    USAlts is in the process of making an all in one box that will control as many alternators as you need. I believe Mechman and maybe Singer have similar plans too.
    Owner, SounDrive Audio
    Visit our store at www.soundrive.audio
    Like us on Facebook at www.facebook.com/soundriveAudio
    PLEASE EMAIL ME FOR FASTER RESPONSES - [email protected]
    Dealer for: SounDrive Audio | Synergy Audio | Audio Legion | XS Power | Mechman | SPL-Lab | Taramps | Limitless Lithium | Wolfram Audio | Singer Alternators | Ampere Vibraflex
  10. #1060
    adulbrich's Avatar
    May 2014
    Ames, Iowa
    19
    13,781
    118 Post(s)
    6103 Post(s)
    That is correct.
    I bought a box from US alternators that was supposed to keep voltage steady on the PCM regulated alternator I bought from them. It was basically supposed to bypass the PCM regulation without throwing a code and reducing engine power.
    After a couple months of troubleshooting, it never ended up working. I will not be buying anything from that company again.
  11. #1061
    adulbrich's Avatar
    May 2014
    Ames, Iowa
    19
    13,781
    118 Post(s)
    6103 Post(s)
    Just bought a third regulator
  12. #1062
    SounDrive's Avatar
    Apr 2013
    Lebanon, TN
    3,071
    20 Post(s)
    1346 Post(s)
    Did you talk to Dan about the issue? If it was a product issue he would replace it no problem. Those modules are working on tons of vehicles without a problem.
  13. #1063
    Dec 2006
    New orleans LA
    32
    11,492
    58 Post(s)
    2 Thread(s)
    4721 Post(s)
    You can simulate an input to the ecm......
    Insidious Audio
  14. #1064
    adulbrich's Avatar
    May 2014
    Ames, Iowa
    19
    13,781
    118 Post(s)
    6103 Post(s)
    It wasn't an issue of replacing it. He said someone else with an 07 had the same issue with the regulator in the alternator I bought. They were not able to solve the problem.
    Regardless, I'm going to run isolated electrical systems this time, so I won't be needing a PCM bypass box
  15. #1065
    Hertz Mafia's Avatar
    Hertz Mafia is offline FEATHER RUFFLER
    Jul 2016
    Michigan
    1,517
    27 Post(s)
    924 Post(s)
    U should just run one alt for trucks stock electronics and then the other three alts for the audio side seperate. That's what my buddy does in his 2011 tahoe. Works perfect
+ Reply to Thread
  1. 94 Silverado, installing rear speakers
    By Nate8880 in forum Wiring, Electrical and Installation Help
    Last Post: 07-03-2002, 12:09 AM
  2. ANyone with Sierra/Silverado...
    By SierraonDubs in forum Subwoofers
    Last Post: 06-23-2002, 06:22 PM
  3. 2002 Chevy Silverado Help!!
    By cmcnally in forum Wiring, Electrical and Installation Help
    Last Post: 05-19-2002, 08:16 PM
  4. 81 Silverado
    By Garfield in forum General Discussion
    Last Post: 02-26-2002, 07:33 PM
  5. 81 Silverado
    By Garfield in forum Wiring, Electrical and Installation Help
    Last Post: 02-19-2002, 03:41 PM
Tags for this Thread
