+ Reply to Thread
Page 4 of 72 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 54 ... LastLast
Results 46 to 60 of 1077
Reload Thread: Alex's Silverado
  1. #46
    adulbrich's Avatar
    adulbrich is offline Lock up your daughters!
    May 2014
    Ames, Iowa
    20
    13,849
    119 Post(s)
    6123 Post(s)
    Re: Alex's Silverado
    Quote Originally Posted by jordon View Post
    Should be loud for now but once you get alot more power should be nasty. Tuned in.
    This guy has less cone area than me and a Sundown 6k amp for power:
    https://www.youtube.com/watch?v=-ol7_NfUDOc
    ^That looks nasty to me (You'll have to skip about half way through)
    My Silverado is under construction AGAIN http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/621466-alexs-silverado.html
    Quote Originally Posted by massivespl View Post
    Love is when she licks your butthole and try's to kiss you and u smack her but she doesn't get mad because she know that nasty and she in the wrong
    Quote Originally Posted by Slo_Ride View Post
    Fuck me running. Even I wouldnt eat stripper snatch.
    Quote Originally Posted by ilikeradios View Post
    I would rather beat you to death with a garden rake then talk politics with you due to your overwhelming ignorance.
    Quote Originally Posted by Joseph7195 View Post
    A three legged hooker walks into a bar. Yadda Yadda Yadda, I ended up sucking a dick.
    Quote Originally Posted by gckless View Post
    When that hooker turns out to have a cock. That's bigger than yours.
    Quote Originally Posted by LongThrow View Post
    If I had $2,000, I wouldn't be running kicker comps.
  2. #47
    adulbrich's Avatar
    May 2014
    Ames, Iowa
    20
    13,849
    119 Post(s)
    6123 Post(s)
    Quote Originally Posted by hispls View Post
    That on the shell should be really solid but with a router and flush bit, rabbet bit, and roundover bit you can stack 3/4 to make a baffle much easier and cleaner than trying to carve through 3.5 of pine to make your mounting holes and get a nice flush mount. Buy a second flush bit because you'll always break one when you're in the middle of something. The router should also simplify copying pieces elsewhere when you're trying to double layer.
    I can't find my router and can't afford a new one
  3. #48
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    10,127
    15
    38 Post(s)
    4159 Post(s)
    Quote Originally Posted by adulbrich View Post
    Yes, much more when I have money
    I'd bet that it costs you 1000$ per dB gained once you're at 8K if you just plan on adding more power. Far cheaper and more effective ways to gain audible output from where you should be sitting with the equipment you have.
  4. #49
    jordon's Avatar
    jordon is offline CarAudio.com Elite
    Jul 2014
    Fort Bragg, NC
    829
    6 Post(s)
    403 Post(s)
    That is nasty.
  5. #50
    hispls's Avatar
    Sep 2009
    10,127
    15
    38 Post(s)
    4159 Post(s)
    Don't they have pawn shops where you live? Best source for buying tools.
    If you want this build to look decent and be solid you can't afford not to own a router.
  6. Likes CSCStang liked this post
  7. #51
    adulbrich's Avatar
    May 2014
    Ames, Iowa
    20
    13,849
    119 Post(s)
    6123 Post(s)
    How would you suggest getting more audible output then?
    That is nasty.
    Yup
    They do. Didn't think about going there for a router. Hopefully they've got jigs too
  8. #52
    72Impala's Avatar
    72Impala is offline CarAudio.com Elite
    Mar 2005
    Clarksville, TN
    29
    1,097
    8 Post(s)
    346 Post(s)
    I think hispl is saying tweaking your build and such. Test with port in different positions, subs or port loading off different things, port area, ect. You could potentially gain a few db just changing your wall.
    As said before I would do the thickest baffle possible, along with 3 layers or better all around. You can weld a metal cage and put a box inside that of maybe 1 layer but that would be a lot more work.
    I think in your small cabin you could do 158 tbh.
    I saw a guy do a 155.3 with 2 18's no wall on a single taramps 20k in a crew cab this year. Also saw a guy with a single 15" and aa7500.1 do a 154 in a s-10. You do it right and you will meter high. That low tuning is going to hurt you though
    2003 6.8L V10 Excursion Limited
    2015 MECA STREET 5 WORLD CHAMP
  9. #53
    hispls's Avatar
    Sep 2009
    10,127
    15
    38 Post(s)
    4159 Post(s)
    Yup
    Optimize the box. For starters over build it, and build it bigger than you think you need. You can then easily add material to round corners or angle the rear (which can gain significantly)....or just add material to shrink the box if needed.
    Extreme reinforcing of panels next. If you don't care about competing where doing so would put you in extreme/modified classes welding some steel to the roof and doors or adding 1/4" of fiberglass would be big. Fill behind plastic trim with caulking and similar so that nothing rattles or flexes. Even just heavy deadening to reduce the noise floor amounts to the same as free output as far as seeming audibly louder.
    Really throwing 1200$ at another 8K amp and another 1000$ into batteries won't gain you more than 2dB. A very poor investment compared to other options, particularly since if you don't reinforce panels they will sound awful and probably break anyway particularly if you try to double power.
  10. Likes Jeffdachef liked this post
  11. #54
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Might have missed it but what will be net volume/port area for the enclosure?
  12. #55
    Massive spl's Avatar
    Massive spl is offline Banned
    Jun 2015
    Michigan
    3,007
    52 Post(s)
    1 Thread(s)
    1837 Post(s)
    Bro u just talking out your arse. U can't tell him another 8k and $1000 in batteries won't gain 2db.. HOW THE FVCK DO YOU KNOW? God dang internet know it ally's in here...in the Hhr we went from 158db to 160.5db just by switching to nsv3s and 16v, that cost under 2grand for the switch and we gained 2db.... And another thing a guy did 155db in a crew can with two 18s so you should do a 58db yet the guy that said that 72impala only was doing 157 with 4 wardens in his excursion on lots of power... It's hard to get loud but since ppl seen it on the internet so it has to be easy.. Adulbrich is 17 and a lot of those really loud guys u see on the Internet are late 30-50year olds with experience. Shlt didn't happen over night
    A good example is swift on Caco. Had 3-4sp4 18s and then 3-4 dss 18s on two ampere 7.5ks in a f150 4door, he would meter like a 154 sealed and like a 158 door open and that's a bpillar.. According to everyone he should be in 160s+ no problem but oh wait it's not easy getting loud, takes tons of testing and time, and the testing and time is what guys are lacking these days, they just spray from and 2x4 and make some noise. Swifts build was clean though. Lol
  13. #56
    hispls's Avatar
    Sep 2009
    10,127
    15
    38 Post(s)
    4159 Post(s)
    Quote Originally Posted by Massive spl View Post
    Because the laws of physics say that at the very best he will gain 3dB from doubling power and that's assuming no compression and no losses from panels flexing which is impossible. Your friend changing amps and gaining 2.5dB doesn't disprove the relationship between electrical power and sound intensity.
    Furthermore I only said I bet that's the case not that you definitely can't ever under any circumstances gain more than 2dB out of doubling power. Please at least take the time to read before you try to hurl insults at people.
  14. #57
    Jun 2015
    Michigan
    3,007
    52 Post(s)
    1 Thread(s)
    1837 Post(s)
    He changed subs not amps.i guess u can't read, And gain 2.4db
  15. #58
    adulbrich's Avatar
    May 2014
    Ames, Iowa
    20
    13,849
    119 Post(s)
    6123 Post(s)
    Quote Originally Posted by 72Impala View Post
    Yeah, I'm going to make it as thick as I can. I want lows, and don't really care about how high I meter, honestly. I'll be tuned to 25hz, which is lower than most here, so I could care less if they say my score isn't shit, lol
    I am making it as big as I can. Rather than adding a bunch of metal, I was thinking about doing a stripper pole
    Quote Originally Posted by mlstrass View Post
    26 cubes net tuned to 25hz with 16 square inches of port area per cube.
    Thanks, lol. I'm just trying to get loud down low. I'm not trying to get a 160 at 50hz with no lows. This is a daily and demo vehicle
  16. #59
    72Impala's Avatar
    Mar 2005
    Clarksville, TN
    29
    1,097
    8 Post(s)
    346 Post(s)
    Since your talking crap. Mine is no wall bro. No wall doing the same score as you in a bigger vehicle. Oh and I outlawed a 158 so louder than you without a wall. And on probably the same clamped power
  17. #60
    adulbrich's Avatar
    May 2014
    Ames, Iowa
    20
    13,849
    119 Post(s)
    6123 Post(s)
    Yeah, I would assume it's much harder to get loud no-wall, especially without structural reinforcements because of your class
+ Reply to Thread
  1. 94 Silverado, installing rear speakers
    By Nate8880 in forum Wiring, Electrical and Installation Help
    Last Post: 07-02-2002, 11:09 PM
  2. ANyone with Sierra/Silverado...
    By SierraonDubs in forum Subwoofers
    Last Post: 06-23-2002, 05:22 PM
  3. 2002 Chevy Silverado Help!!
    By cmcnally in forum Wiring, Electrical and Installation Help
    Last Post: 05-19-2002, 07:16 PM
  4. 81 Silverado
    By Garfield in forum General Discussion
    Last Post: 02-26-2002, 06:33 PM
  5. 81 Silverado
    By Garfield in forum Wiring, Electrical and Installation Help
    Last Post: 02-19-2002, 02:41 PM
Tags for this Thread
