Results 1 to 14 of 14
Reload Thread: 2002 Ford Taurus Mosconi, Illusion Audio, Audible Physics
    Octave's Avatar
    Octave is offline Member
    Jun 2011
    Orlando, FL
    142
    3 Post(s)
    You probably have seen a raging bull but have you seen a singing bull? Well I introduce to you Dustin's 2002 Ford Taurus "Project Singing Bull". Dustin wanted a truly stealth install but a very dynamic system for this songster.
    The front sound stage starts with a set of the Audible Physics NZ3/AT. The pillars were wrapped in OEM headliner material and the terminals were heat shrunk.
    Grilles were made out of pressed metal mesh for daily driving protection but may be removed for critical listening.
    Focal | DynAudio | Mosconi | TRU Technologies | Digital Designs | Rainbow Audio | Illusion Audio | Zapco
    Mobile Electronics Magazine "Top 100 Installer" 2010, 2011, 2012, 2013
    www.OCTAVEONLINE.com
    Octave's Avatar
    Jun 2011
    Orlando, FL
    142
    3 Post(s)
    Re: 2002 Ford Taurus Mosconi, Illusion Audio, Audible Physics
    Once the pillars were done the doors were the next subject of attention. The doors stock house the typical Ford 5x7 but that meant there would be room for a set of Illusion Audio Carbon C8 midbass.
    A staple at Octave is to use plastic for the mounting rings to ensure against moister damage. Wood rings are substandard because no matter how you treat them moister will eat at them but plastics never will have that problem.
    The drivers door presented a small challenge with its molex plug. There wasn't room to run wire through it but I got lucky. There was one wire that was not used so it was removed and heat shrunk for protection. Once removed it cleared a path for the speaker wire to be ran.
    The rings were mounted using 4 10-24 screws that screwed into nutserts in the door and a foam gasket was applied to the backside before mounting.
    Octave's Avatar
    Jun 2011
    Orlando, FL
    142
    3 Post(s)
    The speaker wire was heat shrunk and zip tied to the basket.
    The speaker was mounted to the mounting ring using 10-24 screws.
    The passenger door received the same treatment as the driver but the running of the speaker wire was easier because the molex had a straight pass through.
    With the midbass mounted the door panels were modified to allow the midbass to breathe into the interior without hinderance. Grilles were made and screwed to the door panels. The grilles were wrapped with black grille cloth to bring some of the black accents present in the dash into the door to help tie in the grilles giving a factory appearance.
    Octave's Avatar
    Jun 2011
    Orlando, FL
    142
    3 Post(s)
    With the grilles on the pillars and doors the two tie together nicely.
    The electrical system got a full upgrade from a high amperage alternator to upgraded power wiring.
    The main system fuse holder is mounted to an aluminum L bracket that was bolted an open mounting point on the OEM fuse block.
    After removing the interior fuse block on the drivers side access was given to a grommet in the fire that was able pass the 0 gauge cable for the system power.
    Octave's Avatar
    Jun 2011
    Orlando, FL
    142
    3 Post(s)
    Once the power wire was dropped into the interior all the wiring could now be ran. All speaker wire and signal wire was laid over foam tape to minimize the induction of mechanical noise from the cable rubbing against the chassis.
    Throughout the wire runs Hush Mat Quite Tape was used to secure the wire at 6" intervals.
    Octave's Avatar
    Jun 2011
    Orlando, FL
    142
    3 Post(s)
    The USB cable for the DEH-80PRS was ran along the under side of the center console and into the center console storage area. More Hush Mat Quiet Tape was used to secure the wire.
    Wiring behind the radio tied up and tidy.
    With the front of the car completely wired the trunk was next. Great attention to detail was used to ensure a truly custom install. The Straight Wire Symphony RCAs were cut to length and terminated in house. All wires go directly from the speakers to the amplifiers without breaks in lines to ensure against voltage drops. The trunk houses a Mosconi AS 100.4 for the Audible Physics, a Mosconi AS 300.2 for the Illusion Audio C8's, a Mosconi AS 200.4 powering the Illusion Audio Carbon 12XL subwoofer, a Mosconi 6to8 for signal processing and for something special a Mosconi 6to8 was sourced to serve as a custom fuse block for the system.
    The subwoofer enclosure is mounted using 3 1/4-20 bolts screwed into nutserts.
    Straight Wire Sextet 6 core speaker wire was used for the subwoofer. The wires were separated and heat shrunk.
    All wires are secured using screw down zip ties at 6" intervals.
    Octave's Avatar
    Jun 2011
    Orlando, FL
    142
    3 Post(s)
    All speaker wire ends were heat shrunk.
    A BatCap Model 2000 was mounted to the subwoofer enclosure.
    A custom fuse block was made using an Audison fused distribution block. It was designed to fit within the foot print of a Mosconi 6to8 so that the shell of the 6to8 my be used as a cover.
    A relay was used for the turn on of the accent LEDs in the trunk. Techflex and heat shrink gave a nice clean look to the relay pack.
    The USB hook up for the 6to8 was ran up to the underside of the rear deck and zip tied to factory wiring. With the factory carpet back in place the wire is hidden. This allows for easy tuning.
    Octave's Avatar
    Jun 2011
    Orlando, FL
    142
    3 Post(s)
    When opening the trunk you are greeted with a completely stock appearing trunk thanks to a custom trunk mat.
    With the trunk mat removed the vinyl trim panel and removable grille can be seen.
    With the grille removed the true beauty under the skin can be seen. Factory matched vinyl to the interior was used to tie the trunk in with the interior of the car. The center piece design was inspired by the center console shifter area which further brings the interior to the back.
    Blue accent LEDs were used to give the center piece the effect of floating on light while illuminating the trunk.
    The center vinyl piece is held down with magnets, once removed gives access to 4 screws and when those screws are removed the whole center piece can be removed to give access to the 6to8 and the mock 6to8 fuse block. The whole process can be done within 30 seconds.
    Dim the lights and the trunk really lights up.
    Ok. How's it sound? Well usually I don't like to give an opinion till the speakers have gotten the chance to break in but......the car sounds incredible. The sound stage is wide past the pillars with depth at hood range and height on point. Tonally it's very enjoyable to listen to with the Audible Physics creating great detail and the Illusion midbasses providing unbelievable amounts of midbass and attack. Almost so that during tuning they were mimicking subs. Now the sub. The Illusion XL is a civilized beast with ungodly amounts of low end bass but with unbelievable control and transparency with the front stage. I truly look forward to this car once the speakers have fully broken in. It should be a treat to listen to.
  9. Likes cmack9.14 liked this post
  10. #9
    ShayneF's Avatar
    ShayneF is offline Member
    May 2012
    Australia
    53
    7 Post(s)
    Once again, a quality installation. Top job.
    Alpine CDA 117E
    Alpine MRD-M501
    Boston GT-4100
    Focal 5-3/8 splits
    Focal 6.5 splits
    Alpine 8" subs
  11. #10
    SounDrive's Avatar
    SounDrive is offline www.soundrive.audio SounDrive is a Supporting Member of the forum!
    SounDrive is a Supporting Vendor of the forum!
    Apr 2013
    Lebanon, TN
    3,072
    20 Post(s)
    1347 Post(s)
    Very nice. I may copy some of your work and use it in my Taurus.
    Owner, SounDrive Audio
    Visit our store at www.soundrive.audio
    Like us on Facebook at www.facebook.com/soundriveAudio
    PLEASE EMAIL ME FOR FASTER RESPONSES - [email protected]
    Dealer for: SounDrive Audio | Synergy Audio | Audio Legion | XS Power | Mechman | SPL-Lab | Taramps | Limitless Lithium | Wolfram Audio | Singer Alternators | Ampere Vibraflex
  12. #11
    cmack9.14's Avatar
    cmack9.14 is offline Junior Member
    Dec 2013
    NewCastle,DE
    WOW, I have a 2003 Tarus GL and your 02 looks great! I want to learn how to install as shops in my area expensive. Over the years I have collected a garage full of gear including a Denon DCT-100r (8) Illusion Audio, (6) 6.5 Illusion Audio component sets, Illusion Audio Compression Horns, (3) Zapco Z300, A pair of Zapco 30 band EQs, and (3) Audio Art 50 Hc. After seeing your car I may attempt to finally install some of this equipment. I really enjoy great SQ.
  13. #12
    calebkhill's Avatar
    calebkhill is offline CarAudio.com Elite
    Dec 2012
    Phenix City, Alabama
    1,103
    326 Post(s)
    Killer
    "When I listen to a stereo loudspeaker playback in my room and an auditory scene has formed in my mind, how would I know that what I hear is an accurate replica of an auditory scene that could be had at the recording venue? Or more generally, that this is an auditory scene that could have existed at all?"
  14. #13
    CJL's Avatar
    CJL
    CJL is offline CarAudio.com Veteran
    Mar 2006
    oZone
    3,844
    71 Post(s)
    one of the best installs ive seen on here.
    REFS:
    eatank,mikescanlon,BoominBeast,Pistonsfan70,90accordman,bizflawless,Mazdakid,Boyle465,LiquidClen,dman4486,
    KickerSoItBump, SPY,1000101,infamous_e46
    Bought-Sold-Traded
  15. #14
    d77543020's Avatar
    d77543020 is offline CarAudio.com Veteran
    Dec 2005
    stockton ca
    2,673
    429 Post(s)
    beautiful
  1. BNIB H-Audio/Audible Physics 2-way sets
    By azngotskills in forum Speaker Classifieds
    Last Post: 10-20-2011, 11:01 AM
  2. 2002 Ford taurus dash
    By omgi0wn in forum Head Units
    Last Post: 01-29-2010, 07:46 PM
  3. 2002 Ford Taurus Wiring issues
    By Erhardt12 in forum Wiring, Electrical and Installation Help
    Last Post: 03-07-2009, 01:10 AM
  4. 2002 Ford Taurus SE: How do I install aftermarket headunit
    By chandlerou in forum Wiring, Electrical and Installation Help
    Last Post: 01-16-2008, 07:03 PM
  5. Install an MP3 aux jack in a 2002 Ford Taurus w/ stock stereo
    By trevorpowell in forum Wiring, Electrical and Installation Help
    Last Post: 01-15-2008, 05:28 PM
