Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 34
Reload Thread: 93 chevy silverado small SQ build
    Synastr's Avatar
    Synastr is offline Member
    Sep 2013
    Crossville,TN
    86
    23 Post(s)
    Ok, so im about to tackle my truck design. I currentyl will be running two RE audio pro sr subs. 10" My box is going to be like a box under each side and fire the subs towards each other and place the amp in the middle. plexi on the front to see the subs. I figure if i angle the subs towards the front a tad bit I should get a real good sound from them. Im still unsure on porting the boxes or to keep it sealed. Sealed has always sounded great to me, but ill get a louder sound from ported. Either way it will be a unique build for sure. The rear florr hump is going to be removed becuase the truck has a body lift and nothing is under there to even hit. Itll make my box building easier. Ill get pictures once i get started on it. Still thinking ill have to do a seat raise of about 2 inches.
    Synastr's Avatar
    Sep 2013
    Crossville,TN
    86
    23 Post(s)
    Re: 93 chevy silverado small SQ build
    So changing ideas, going to throw both subs over on the passenger side under the seat firing forward. running the port toward the driver side, and doing the amp rack under the seat behind the driver. Using winsd with my subs, my port should be tuned around 28-29hz to have a nice flat response line. Port should measure out to be 3" by 12" according to there program. Im just waiting on a router to start so i can get some nice circles. Box is going to be roughly 1.9cft before any speakers or ports, so i figured it all up for a 1.8 cft box. Hopefully it gives me the pucnh i need.
    winkychevelle's Avatar
    winkychevelle is offline CarAudio.com Veteran
    Jun 2009
    Ponchatoula, La
    26
    3,512
    812 Post(s)
    Quote Originally Posted by Synastr View Post
    I would put the subs on drivers side port passenger side. 8f you have any port noise putting it opposite side of you will help and you want hear the plastic vibrating from the air coming out of the port and hitting the truck panels
    2014 Chevrolet Cruze Diesel
    2013 Chevrolet Silverado 3500HD 4x4
    Pioneer touch screen with front and rear cam
    Memphis viv component run active
    2 alpine pdr-m65
    1 alpine pdr-f50
    2 jl 13tw5-3 in subthump understeat box
    Synastr's Avatar
    Sep 2013
    Crossville,TN
    86
    23 Post(s)
    i thought about that, but most of the sound is going to come from the port, so i would believe it would be louder that way for the driver. ive noticed with a plain ported box thrown on the back seat, its loudest to my ears on the passenger side with port and sub facing forward. so in theory it would be the same under the seat. the box will be either side universal, ao i can always throw it under either side.
    Jun 2009
    Ponchatoula, La
    26
    3,512
    812 Post(s)
    If you port to the side rear corner the box will load off the rear door and amplify the subs out put kinda like subs facing the rear of a trunk car
    2 alpine pdr-m65
    1 alpine pdr-f50
    Synastr's Avatar
    Sep 2013
    Crossville,TN
    86
    23 Post(s)
    I dont have a 3rd door. I thought about that as well. I can move the port around since my terminal ring is 3in, and so is my port. so ill have it positioned on each side and swap around till i find my sound.
    Jun 2009
    Ponchatoula, La
    26
    3,512
    812 Post(s)
    That can work you need to have at least 2.5cubes of air space though of the box will be real peaky. Unless you are using dayton ho
    2 alpine pdr-m65
    1 alpine pdr-f50
    Synastr's Avatar
    Sep 2013
    Crossville,TN
    86
    23 Post(s)
    2.5?!? The subs recommend .65 compact or 1.0 optimum. 2.5 seems real large
  9. #9
    Jun 2009
    Ponchatoula, La
    26
    3,512
    812 Post(s)
    Thats for sealed ported is Like 1.25-1.75. The dayton ho can work in .7 but itd an odd woofer that happens to sound great
    2 alpine pdr-m65
    1 alpine pdr-f50
  10. #10
    cablguy184's Avatar
    cablguy184 is offline SQ "White Lightning"
    Oct 2010
    Rankin Co. Mississippi
    47
    498
    49 Post(s)
    I had my origional enclosure sealed and down firing with 2 10s ... sounded great, just needed something more for SQ competition ...
    Randal Johnson ... Comcast Xfinity ... 1997 Chevy Silverado 1500 Extended Cab ... 1949 Ford Custom Tudor Sedan
    Linear Power (TIPS) / Blues Car Audio ... Audio Technix ... Hyper Automotive LEDs and HIDs ... Mississippi Street Rod Association
  11. #11
    Synastr's Avatar
    Sep 2013
    Crossville,TN
    86
    23 Post(s)
    No, the .65 to 1.0 is for ported. Sealed is .3 to .5 I believe I'm going to get around 2-2.1 Cft before subs and port. So I think I'll be happy. I'm not going for spl level.
  12. #12
    Jun 2009
    Ponchatoula, La
    26
    3,512
    812 Post(s)
    Good luck but dont say I didnt tell you better when it flops
    2 alpine pdr-m65
    1 alpine pdr-f50
  13. #13
    Synastr's Avatar
    Sep 2013
    Crossville,TN
    86
    23 Post(s)
    I'm taking all advice. I just wish I knew whether to stay around recommended or go a bit bigger. I tried winisd with 2.5 Cft and it showed a higher peak at my port hz but wasn't as flat of response. I'm not sure. I've always built an ran sealed boxes.
  14. #14
    Jun 2009
    Ponchatoula, La
    26
    3,512
    812 Post(s)
    I can put money the if you build it bigger and keep tuning low it will sound better.
    Winisd is for houses not cars. Good for finding out port legths but not for modeling subs in a car
    2 alpine pdr-m65
    1 alpine pdr-f50
  15. #15
    Synastr's Avatar
    Sep 2013
    Crossville,TN
    86
    23 Post(s)
    Ok, well I have it tuned to 28-29 hz. I believe I can get right at 2.8'cft feet in the Area Im building by measuring it. But it's a big box. Here's another question. Is a bigger box going to give the sub more power handling? Or smaller box? The subs are rated to 320rms but I want to be able to safely run them at 400-420 each.
  1. Cablguy's 1997 Chevy Silverado 1500 Extended Cab ... SQ
    By cablguy184 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 01-26-2012, 08:56 AM
  2. Want to do a small SQ build in my car. Tell me what you think.
    By Bassin Buick in forum General Discussion
    Last Post: 12-16-2010, 03:11 PM
  3. Small SQ Build/Install....Eclipse, CDT, IDQ...Pics
    By btdickey99 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 01-11-2009, 02:21 PM
  4. Small SQ Build/Install....Pics
    Last Post: 11-19-2008, 09:16 AM
  5. Latest pics of my 87 chevy silverado build
    By 8thGenSI in forum General Discussion
    Last Post: 05-24-2008, 01:09 PM
