Results 1 to 9 of 9
Reload Thread: 2013 Renault Megane build
    ScuL's Avatar
    ScuL is offline Junior Member
    Jul 2013
    Hampshire, United Kingdom
    Icon6 2013 Renault Megane build
    I'd like to contribute to the forum with something probably slightly more exotic towards the largely North American audience on this website.
    I'm the proud owner of a French (yes, French) Renault Megane and have been driving Renault for nearly a decade now. As far as I'm aware Renault hasn't been marketed or available in the US or Canada for at least 2 to 3 decades so I'm not surprised if you've never heard of them.
    Nevertheless the newest series are very decent quality build, very comfy ride and look pretty slick.
    The downside is the factory stereo systems are absolutely terrible.. so I decided to do something about that.
    I'm planning to update this thread with a report of our "build", already posted the thread previously but I suspect it was not approved due to it containing too many links & images. Let's see how we go!
    Here are some examples of late Renault models;
    Megane GT
    Megane RS
    Clio 4
    Laguna Coupe 2014
    ScuL's Avatar
    Jul 2013
    Re: 2013 Renault Megane build
    It's unlikely you'll ever see this vehicle in North America but there are quite a lot of them here in the United Kingdom where I'm currently based.
    I previously owned a 2009 version with a Diesel engine but got a really good deal on a brand new 2013 model which is why I traded the old one in.
    The 2013 model has got a built in TomTom sat-nav. The biggest problem is that the TomTom will cease to operate when changing the factory radio, so we decided to work around the problem by using the factory radio as a source and amplify the signals it produces.
    (I am aware an Italian stalk-module exists to prevent this from happening but it doesn't fully work as it should).
    I've put a lot of time and research into this and came to the conclusion that the American AudioControl LC7i offers the best solution.
    For this particular install we used the following components:
    Pioneer TS-A132Ci 300W (upgrade of the previous Pioneer TS-Q131C 180W)
    Pioneer TS-A1323i 300W (upgrade of the previous Pioneer TS-E1302i 180W)
    Sony-XM1S(amp for the sub - previously installed)
    Sony XM-GTR7040 (amp for the door speakers - new)
    Sony XS-LB12S (sub - previously installed)
    AudioControl LC7i (high-level converter)
    Firstly, the new vehicle (here with 30 miles on the clock)
    ScuL's Avatar
    Jul 2013
    System diagram:
    As you can see here, brown wires from every speaker feed towards the trunk, amplify it there and bring it back to the doors. The biggest nightmare we encountered was that we expected to be able to use the existing rubber wire sleeve to get to the door and back. What we couldn't see was the end of this cable ends in a big fat plug which is impossible to get new wires through.
    Because of this problem we were forced to drill holes in the door of a brand spanking new Megane
    To achieve this we not only had to remove the inside panels but also the safety belts. Luckily there's a hole in the car's chassis already which is filled with a plastic plug so we didn't have to drill in there.
    The next step was to remove the annoying door-cards (whoever invented the plastic door-clips deserves a smack in the face!)
    New speaker mounted
    At the front we also had to insert a compo-filter for the separation of frequencies between the door speaker and the tweeter in the dash.
    We dumped the filter in the tweeter hole and wired blue wires from the door to the filter and from the filter to the trunk.
    Unexpectedly we discovered that there are 2 electric wires for accessories under the floor close to the hood handle. Instead of being difficult and tapping power from under the hood we put together a custom plug that taps into these cables and brings the live cable to the trunk.
    The AudioControl LC7i has a feature that will generate a remote-out signal as soon as it detects audio on the speaker wires, because of this feature a remote signal from the factory radio or plug to the trunk in order to switch on the amps is NOT required!
    Nicely leading wires towards the trunk
    ScuL's Avatar
    Jul 2013
    Then the trunk, we tried to keep the install as tidy and minimal as possible in order to maximize luggage space.
    For this reason we mounted most of the components on the back of the woofer.
    (Wiring is not very tidy at this stage)
    LC7i and XM-1S
    XM-GTR7040 mounted on the back of the rear seat
    Total picture
    And finalized
    I'm a happy man now
    Aug 2013
    Dayton, Ohio
    43
    3 Post(s)
    good stuff!!
  6. Thanks ScuL thanked for this post
  7. #6
    tudor adrian's Avatar
    tudor adrian is offline Junior Member
    Jun 2014
    Italia
    2 Post(s)
    Hi, i have one question.
    I have a Megane III Coupe Dynamique and I would like to change all speakers.
    The twitters are easy to change, i know! but what about the front doors speakers and the speakers from the back seats? (it's a 3 doors car).
    Can these be changed with aftermarket 5 inch (13cm) speakers without removing the door panels?
    Would it work by just taking off the speakers caps?
    Please reply, it's prety important!
    Thank You in advance!
    Adrian
  8. #7
    ScuL's Avatar
    Jul 2013
    Quote Originally Posted by tudor adrian View Post
    Adrian
    I don't know the situation with the 3-door coupe as I have never seen one from the inside. I assume the front doors are the same as the 5-door and the rear I have no idea. But the fact is that in the 5-door version there ARE NO SPEAKER CAPS... You have to remove the entire door panel, there is no other way.
    This is not a light job, also you need a diamond (or other strong) drill to cut out the old speakers as they are welded to the chassis (don't even ask who came up with this idiotic idea)
  9. #8
    Jun 2014
    Italia
    2 Post(s)
    Icon12 Re: 2013 Renault Megane build
    Hello Scul,
    Thank You for the reply,
    Indeed, I agree, this is a realy idiotic idea to fix the speakers like they did.
    Megan Coupe's doors are longer than the 5 doors.
    I will take my car tomorrow to the Renault garage and ask them about the sound system.
    Do You think that they could fit 165 mm speakers without making any modifications to the doors estethics ?
    I've read some articles on the internet.
    i hope that they will make me a good price offer.
    Regards,
    Adrian
  10. #9
    kelvint's Avatar
    kelvint is offline Junior Member
    Jul 2014
    inwood wv
    i am installing the lc7i now and I am looking at the 12+ and out and ins please go in to more detail on what wires go where and where you are pulling the power from. I am also installing 4channel amp and amp for sub
  1. J31Rob's 2013 Build
    By J31Rob in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 09-07-2013, 11:32 AM
  2. 2013 Dodge Dart Limited build
    By johnthompson in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 08-21-2013, 08:42 PM
  3. Replies: 22
    Last Post: 12-11-2012, 02:39 AM
  4. 2013 Jetta TDI Build
    By raswank in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 10-30-2012, 11:37 AM
  5. Renault Megane II
    By laurent-r in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 09-06-2009, 06:25 PM
Tags for this Thread
