Page 3 of 3 FirstFirst 1 2 3
Results 31 to 41 of 41
Reload Thread: JBL GTO 10 in ¼ Wave T-Line
  1. #31
    Nutdawg651's Avatar
    Nutdawg651 is offline CarAudio.com Elite
    May 2013
    1,418
    1 Post(s)
    481 Post(s)
    Re: JBL GTO 10 in ¼ Wave T-Line
    My bad I was saying 30 batts
  2. #32
    supra1987's Avatar
    supra1987 is offline Senior VIP Member
    Oct 2013
    rhode island
    234
    69 Post(s)
    I would like to know the dimensions of the 10 inch subwoofer t-line that you have built and also how much larger would it have to be with two 10's? Very nice by the way.
  3. #33
    nismos14's Avatar
    nismos14 is offline CarAudio.com Veteran
    Dec 2006
    Jersey
    36
    14,586
    273 Post(s)
    price and dimensions?
    Car audio IS an addiction.
    C.A.A.A Member #1
    (Car Audio Addicts Anonymous)
    Refs http://www.caraudio.com/forums/buyer-seller-feedback/278560-nismos14-feedback-refs-thread.html
  4. #34
    bbeljefe's Avatar
    bbeljefe is offline CarAudio.com Elite
    Jul 2013
    Shreveport, LA
    1,800
    2 Post(s)
    679 Post(s)
    Quote Originally Posted by supra1987 View Post
    The enclosure is 49" wide, 14" tall and 12" deep. The line is ~9.41' long and the line area is approx 63in², if I remember correctly. For two drivers, the line area would have to double but the length would stay the same.
    This line is tuned to 30 Hz but for drivers with a higher Fs, you could build a shorter one. To give you an idea, a 35 Hz line would only have to be 8' long.
    And thanks for the kind words.
    Owner, Audio Anarchy, LLC
    2915 Youree Drive, Shreveport, LA
    318-780-6149
    https://www.facebook.com/AudioAnarchyLLC
  5. #35
    bbeljefe's Avatar
    Jul 2013
    Shreveport, LA
    1,800
    2 Post(s)
    679 Post(s)
    Quote Originally Posted by nismos14 View Post
    Dimensions are above. Price as it is now is $350.00.
    Here's a picture of the current color scheme on the box... it is sprayed with Herculiner.
    Sub not included. ;-)
    318-780-6149
  6. #36
    T3mpest's Avatar
    T3mpest is offline CarAudio.com Veteran
    Mar 2005
    Illinois
    3,054
    1 Post(s)
    372 Post(s)
    Have you tried experimenting with a tapered T-line or using a thin layer of acoustic batting along the walls? Both are used to stop resonances and further enhance the smooth flat sound that T-Lines are known for. Also you build beautiful boxes, really nice work!
    Quote Originally Posted by sdmtnbiker420 View Post
    JL is for ballers. Theres a reason all the biggest rappers sing about JL, Zapco, Alpine..... and not Lightning audio or Pyle. It's all about the BALLER FACTOR.
  7. #37
    bbeljefe's Avatar
    Jul 2013
    Shreveport, LA
    1,800
    2 Post(s)
    679 Post(s)
    Quote Originally Posted by T3mpest View Post
    I actually played with lining and stuffing in this box but to be honest, I don't think it's worth it in a car audio install unless it's a full blown SQ build. I can definitely see it helping in a home setup though. As for tapers, no I haven't... technically.
    On my latest build in my truck I was having hell designing a below the window t-line for two 15s and I wound up doing two things that could have hurt. First, I choked the line by about 8% less than Sd and second, I mounted the subs along the line rather than side by side at the very end. Also, in order to make the thing fit like I needed it to, I tuned it to ~29 on drivers that are supposed to have an Fs of 34.5, iirc. As it turns out, I ran the DATS on them after about two months of play and both of them reported ~30-31 Hz Fs so it worked out for the best. That box is stupid loud for two subs and I when I play rock or sq stuff I get a smooth as hell blend between the mids and the subs.
    And thanks for the kind words. :-)
    318-780-6149
  8. #38
    Dimwit's Avatar
    Dimwit is offline DEAF AS **** (DAF)
    Nov 2013
    Central Valley or Los Angeles CA
    110
    35 Post(s)
    Quote Originally Posted by Milk Mayne View Post
    Do you know about any differences in sound when it comes to designing around a 1/2 or whole wave? Obviously it would be improbable in a vehicle, but for a theatre setup now...if there would be any point. Envisioning such a thing makes me think back to those entire room horn designs I used to read about in the '90s.
    EDIT: BTW, nice box. Makes me wish I would've kept the SUV since I didn't even really know about T-lines until recently. I can't believe you're planning to build one designed around two X 15's! That's gonna be NASTY!
    To answer your question a bit further you wouldn't want to do a half wavelength T line since that would cause you to have full cancelation at your tuning frequency and consequently its resonant frequencies (at least if my understanding of how T lines work is right). With a Whole wavelength T line you would essentially have full reinforcement at your tuning frequency and its resonant frequencies.
  9. #39
    cablguy184's Avatar
    cablguy184 is offline SQ "White Lightning"
    Oct 2010
    Rankin Co. Mississippi
    47
    498
    49 Post(s)
    Why do you have your enclosure just "Laying" on your back seat ??? SOO much pressure lost ...
    Randal Johnson ... Comcast Xfinity ... 1997 Chevy Silverado 1500 Extended Cab ... 1949 Ford Custom Tudor Sedan
    Linear Power (TIPS) / Blues Car Audio ... Audio Technix ... Hyper Automotive LEDs and HIDs ... Mississippi Street Rod Association
  10. #40
    Jeffdachef's Avatar
    Jeffdachef is offline Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,329
    220 Post(s)
    7369 Post(s)
    Quote Originally Posted by cablguy184 View Post
    it still hits decently, thats what makes it impressive, it'll hit a lot harder if it had something to load off of.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  11. #41
    cablguy184's Avatar
    Oct 2010
    47
    498
    49 Post(s)
    Quote Originally Posted by jeffdachef View Post
    to each his own I guess ... just thought I'd ask ...
    Nice looking enclosures BTW ...
  1. WTB: JBL GTO 10's
    By nismos14 in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 10-02-2008, 04:12 PM
  2. JBl 10 in In a ported?
    By Jim Boom in forum Subwoofers
    Last Post: 08-29-2003, 03:37 PM
  3. JBL GT1041 10 Inch 275 GTO Car Audio Sub Woofer
    By mtxkid6000 in forum Subwoofers
    Last Post: 10-10-2002, 08:03 PM
