Page 3 of 3 FirstFirst 1 2 3
Results 31 to 38 of 38
Reload Thread: 96 Blazer-- 2 18's budget build
  1. #31
    PSturmer's Avatar
    PSturmer is offline CarAudio.com Elite
    Jun 2006
    Minnesota
    1,948
    24 Post(s)
    Re: 96 Blazer-- 2 18's budget build
    Quote Originally Posted by Silver-N-Black View Post
    Do you plan on glassing the box?
    Lots of bondo and sanding. The general shape it there. Jst the imperfections need to be hidden.
    4x 12" HDC3's
    1x Hifonics Maxximus (rated 10,[email protected])
    2x Powermaster D3100
    8x runs of 0 gauge
    1x stock alt
    155.2 dB legal (vehicle off and @50Hz) in a Ford exploder
  2. #32
    PSturmer's Avatar
    Jun 2006
    Minnesota
    1,948
    24 Post(s)
    Under the hood:
    4x 12" HDC3's
    8x runs of 0 gauge
    1x stock alt
  3. #33
    PSturmer's Avatar
    Jun 2006
    Minnesota
    1,948
    24 Post(s)
    Subs have broken in a bit. To my ear seems to be around 150dB. Stock alternator is keeping the voltage sufficiently high. Stays above 13v.
    4x 12" HDC3's
    8x runs of 0 gauge
    1x stock alt
  4. #34
    RangerDangerV2's Avatar
    RangerDangerV2 is offline CarAudio.com Veteran
    Nov 2011
    st cloud MN
    4,890
    2239 Post(s)
    Quote Originally Posted by PSturmer View Post
    what power?
    1999 Tahoe
    2 sa12s
    4th order
    145.18 @33z... with less than 500 watts!
  5. #35
    PSturmer's Avatar
    Jun 2006
    Minnesota
    1,948
    24 Post(s)
    Quote Originally Posted by RangerDangerV2 View Post
    what power?
    The are two SoundQubed 2200 watt amps (used to be AudioQue) wired at 1 ohm nominal each. The amps stay surprisingly cool as well.
    4x 12" HDC3's
    8x runs of 0 gauge
    1x stock alt
  6. #36
    PSturmer's Avatar
    Jun 2006
    Minnesota
    1,948
    24 Post(s)
    Taping up the ports:
    Primed:
    4x 12" HDC3's
    8x runs of 0 gauge
    1x stock alt
  7. #37
    PSturmer's Avatar
    Jun 2006
    Minnesota
    1,948
    24 Post(s)
    After 4 coats:
    Box turned out amazing. Tomorrow the equipment will be re-installed. One of the four ports is also temporarily plugged (from the inside). Using a towel to test this idea out, the sub lower frequency response was increased while the higher bass (about 45 Hz and up) still was well pronounced. On paper, plugging one port lowers the resonant frequency of the box about 5 Hz. Port performance has not been lost even with two ports plugged; the large 1.5" flares on the ports help out a lot.
    4x 12" HDC3's
    8x runs of 0 gauge
    1x stock alt
  8. #38
    PSturmer's Avatar
    Jun 2006
    Minnesota
    1,948
    24 Post(s)
    Some of the paint ended up coming off. With really high humidity and time constraints we had to paint without giving ample time to let the primer dry.
    Bass knob, volt meter, and some switches:
    Rear wiring:
    Very happy with the overall look of the system. Turned out better than I had imagined.
    Put together a small video. Didn't get much footage though.
    1999 blazer with 2 18's slammin - YouTube
    Subs seem to have more mechanical and thermal potential. Without clipping the amps the subs barely warm up, and when not playing anything under 30Hz they only exert about an inch. Perhaps a future upgrade will be to swap out these amps for two 3500's.
    4x 12" HDC3's
    8x runs of 0 gauge
    1x stock alt
  1. 2005 Blazer "Not So" Budget Build
    By Joebobclark in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 09-07-2008, 01:06 PM
  2. My Build Log for my Blazer 2 18's..
    By Blazin Bass in forum General Discussion
    Last Post: 12-02-2007, 03:01 PM
  3. blazer 4 18s question
    By btlking in forum Enclosure Design & Construction Help
    Last Post: 05-28-2007, 06:41 PM
  4. 18" Fi BTL build log *PICS*
    By SHiZNiLTi in forum Enclosure Design & Construction Help
    Last Post: 02-07-2007, 01:36 AM
  5. Budget build contest....
    By chefhow in forum General Discussion
    Last Post: 09-28-2006, 11:35 AM
