Results 1 to 8 of 8
Reload Thread: 2002 Honda Accord build log
    LaKirk's Avatar
    LaKirk is offline Junior Member
    Jun 2013
    Thomasville, GA
    1 Post(s)
    Replaced my two year old Pioneer Premier HU after the volume became shotty. Installed Alpine 138BT. Added Alpine MRP-F300 4 channel amp to existing 6.5 JL Audio door speakers and Memphis Audio 6x9s. Added an Infinity BassLink 10" powered sub.
    Very happy with all of the equipment. The Memphis Audio 6x9s are the most surprising. The BassLink is also very surprising.
    I have a few pics but none from the install. I have to rewire the amp power wire and run a new remote wire. I'm not happy at all with the cheap one that was attached to the RCA. (Honestly, I'm not sure that was supposed to be used to turn on the amp.)
    Two trouble areas for me were the doors. I ran new wires to the door speakers from the amps and had a hard time getting the wire through the rubber gromets. The next trouble area is routing the wires into the trunk form the back seat.
    Next project
    #1 . replace the batter connector, reroute the power wire, route wires better into trunk.
    #2 . Add tweeters to A pillar
    #3 . Maybe add component speakers to kick panels.
    your thoughts welcome.
    LaKirk's Avatar
    Jun 2013
    Thomasville, GA
    1 Post(s)
    Re: 2002 Honda Accord build log
    I completed a few tasks today. Mainly, I rerouted my power wire, relocated all speaker wires to left side, all power to the right. Routed wires behind the molding in the backseat and into the trunk. Looks nice. and all is hidden. Ran new remote wire. Took pics of a few trouble spots that I over came to share with everyone.
    Problem #1 . Prior to today's re-routing of wires, my amp did not switch into protect mode. Now, I'm switching into protect mode at low volumes. I adjusted the gain to mid-way. This improved it some, but I can't push the volume like before.
    LaKirk's Avatar
    Jun 2013
    Thomasville, GA
    1 Post(s)
    Faded speakers to the front. Amp switches to protect a little over halfway. Reaches 100% when switched to rear.
    I had an issue rerouting the passenger speaker wire. I will rewire that speaker and see if this clears the protect mode issue.
    LaKirk's Avatar
    Jun 2013
    Thomasville, GA
    1 Post(s)
    Fixed my protect mode problem. The passenger side speaker was turned just so that the speaker toched the door's frame. A half inch twist counter clockwise fixed this. Sound back to normal. I have a few pics to post as soon as I transfer them.
    LaKirk's Avatar
    Jun 2013
    Thomasville, GA
    1 Post(s)
    This would be a view of the backseat and trunk area as I re-routed the cables. You can see the BassLink mounted on a board the the trunk.
    Here is a view of the Apline MRP-F300.
    This last view is the view of the installation of the power wire to the battery. Updated image coming of the new hardware.
    LaKirk's Avatar
    Jun 2013
    Thomasville, GA
    1 Post(s)
    After installation of the new battery terminal clamp. I'm very happy with this clamp. Each wire installed seamlessly.
    Another view.
    Pic of the driver door after rewiring the speaker. this is the one requiring rotating to miss the metal door frame.
    Alpine 138BT installed
    Tbsh's Avatar
    Tbsh is offline Hai.
    Jan 2011
    Melbourne, Fl
    136
    23 Post(s)
    Looking good so far!
    03 Blazer
    Eclipse 8053, SSA Xcon 18, DC 2k, MurderMat & SHCA wiring.
    Sold to: havieri23, akheathen
    Bought from: 09Civic(x2), SounDrive, shiipseki
    LaKirk's Avatar
    Jun 2013
    Thomasville, GA
    1 Post(s)
    Thanks. Any ideas or pointers are appreciated.
  1. 2002 honda accord v6 EX how much can i....
    By michaellane in forum General Discussion
    Last Post: 04-21-2009, 03:54 PM
  2. 2002 Ford Explorer Build Log
    By kbkid in forum General Discussion
    Last Post: 08-31-2008, 01:11 PM
  3. 2002 Honda Accord & Metra Kit Fit Issues
    By hondaspeed in forum General Discussion
    Last Post: 07-26-2008, 09:33 AM
  4. donpisto's '01 Accord Build Log (Alpine, Zapco, TC Sounds)
    By donpisto in forum General Discussion
    Last Post: 07-18-2008, 04:01 PM
  5. 2002 Honda Accord: My Hertz Build!
    By lyttleviet in forum General Discussion
    Last Post: 09-02-2007, 03:15 PM
