Page 1 of 2 1 2 LastLast
Results 1 to 15 of 26
Reload Thread: 12" Alpine Type R's cut out
    Noob@Bass's Avatar
    Noob@Bass is offline Junior Member
    Jun 2013
    North Dakota
    1 Post(s)
    Icon9 12" Alpine Type R's cut out
    I recently purchased two 12" Alpine Type R's (SWR-1222D) subs and an 1100 watt RMS amp (Alpine MRX-M110). I have them wired for a 2 ohm load i believe. I can only turn my amp gain to about 1/8 turn up and my subs will cut out at 18 volume. I know these subs can handle more than that and I don't know what to do. Maybe my wiring is for a 4 ohm load? Help
    jasonbillnelson's Avatar
    jasonbillnelson is offline LEAD, FOLLOW, OR GTFO!!!
    Oct 2012
    La Plata, MD
    31
    1,273
    1 Post(s)
    292 Post(s)
    Re: 12" Alpine Type R's cut out
    take a picture of how you have them wired. If you don't know exactly how you have them wired, you need to.
    That is how you should have those subs wired.
    TSgt. Jason Nelson
    Andrews AFB, MD USAF
    Dealt with audiobahn, sangthing, 93 saturn sl2, basswiigee, goodstuff, HomeGrown, 06gtmike, 95BlackGA
    HU: Clarion NX501 Nav Deck
    Amps: C2 Audio Recon 1.6, Sundown SAX50.4
    Speakers: Silver Flute 6.5" Mids / ID X28 1.25" Tweeters
    Subwoofer: 2 C2 Audio Team 1k 12"s
    Wire/Battery: SHCA 1/0 OFC--Shuriken BT-80 / BT-35
    Alternator: Mechman 320 amp
    Noob@Bass's Avatar
    Jun 2013
    North Dakota
    1 Post(s)
    I checked and that's exactly how they're wired. So I'm assuming I have them wired correctly. I was trying to set my gains and before I even hear distortion my subs cut out. That's on 3/4 volume and about 2/5 turn up on gain.
    Oct 2012
    La Plata, MD
    31
    1,273
    1 Post(s)
    292 Post(s)
    Do you have a DMM? Also what are your head unit settings at?
    TSgt. Jason Nelson
    Noob@Bass's Avatar
    Jun 2013
    North Dakota
    1 Post(s)
    What's dmm? AnD When I Set the Gains They're All Flat.
    Oct 2012
    La Plata, MD
    31
    1,273
    1 Post(s)
    292 Post(s)
    Digital Multi-Meter. Measures DC/AC voltage and Ohms.
    What head unit do you have?
    TSgt. Jason Nelson
    Noob@Bass's Avatar
    Jun 2013
    North Dakota
    1 Post(s)
    Jvc kd-r330
    Noob@Bass's Avatar
    Jun 2013
    North Dakota
    1 Post(s)
    the Volume Goes To 30
  9. #9
    Oct 2012
    La Plata, MD
    31
    1,273
    1 Post(s)
    292 Post(s)
    Does that have a seperate sub control? If so, what is its setting?
    TSgt. Jason Nelson
  10. #10
    Noob@Bass's Avatar
    Jun 2013
    North Dakota
    1 Post(s)
    IT Does Not have Seperate Sub settings.
  11. #11
    Oct 2012
    La Plata, MD
    31
    1,273
    1 Post(s)
    292 Post(s)
    Ok well I was thinking pre-out was low but 2.5 volts should be ok. And seperate sub setting helps with tuning. When your subs cut out does your amp turn off?
    TSgt. Jason Nelson
  12. #12
    Noob@Bass's Avatar
    Jun 2013
    North Dakota
    1 Post(s)
    No Just The Subs. TheY Come Back On And Cut Out Again.
  13. #13
    Bassman999's Avatar
    Bassman999 is offline BASS OBSESSION
    Jun 2008
    sacramento ca
    526
    114 Post(s)
    Sounds like either low imp protection, or thermal protection to me.
    Those alpines amps dont like lower imp that recommended.
    Sold to: Jonesy-- Traded with: Jonesy , 310w6, Ciaonzo-- Bought from : newtitan, Tat2bass
    System
    Pioneer 80PRS
    Autotek mm4000.1
    Zapco AG750
    Zapco AG360
    Silver Flute MB
    Dayton RS180
    Substage always changing
  14. #14
    Noob@Bass's Avatar
    Jun 2013
    North Dakota
    1 Post(s)
    So What Do You Guys Suggest I Do?
  15. #15
    goingdef's Avatar
    goingdef is offline CarAudio.com Veteran
    Jan 2008
    Norfolk VA
    37
    2,834
    1 Post(s)
    864 Post(s)
    Sounds like its possible there's a bad connection either your power or ground wire to the amp causing the amp to go protect due to being starved for power under heavy load. Check all connections be sure there's no paint on any metal surfaces and that all connections are tight.
    electrical: Optima yellow top X 2 big 3 in monster OFC 1/0g high output alt by maniac electrics
    HU: JVC AVX-77 touch screen
    Front stage: RE XXX 6.5" comps
    front stage amp: Rockford T600.2
    subs: 1 Sundown ZV4 12"
    sub amp: Rockford T2500.1BDCP
    Enclosure: ported (by JayDubb757 )
  1. Replies: 7
    Last Post: 02-08-2005, 01:46 PM
  2. Alpine 9813 - Mids/Tweets cut out
    By AWD T25 in forum General Discussion
    Last Post: 01-09-2004, 05:39 AM
