Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Reload Thread: 2005 Mercedes C55 AMG Audio Build
    bigaudiofanatic's Avatar
    bigaudiofanatic is offline Dynamic Mobile Audio
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Today I started a sweet sound quality build on a c55. I have been in contact with the owner for over a year now, he finally pulled the trigger on the build.
    The parts:
    Front Image Dynamics CXS 6.5's
    Rears Image Dynamics CTX65
    Speaker amp Soundstream REF 4.920
    Sub amp JL 1000/1 Slash
    Subs 2 JL 10's
    Wire Knu Konceptz 16, 12 gauge
    Power wire Kicker 0 gauge
    Dynamat
    Audiocontrol LC6i
    The build. I will say this, the Mercedes has one of the smallest trunks I have worked on with such massive amps. I am still figuring out the best way to mount them with the ability to still gain access to the spare tire.
    After pulling out the floor mat and removing the factory amp cover plate, I planned the layout.
    Template being traced out
    New floor base down. Sanded and routed
    The new floor goes all the way to the tab before the factory wiring starts.
    Amps in to give me ideas
    Subs in as well.
    [URL=http://s483.photobucket.com/user/bigaudiofanatic/media/2005%20Mercedes%20C55%20AMG/IMG_0605.jpg.html]
    I help people with car audio, computers, and much more.
    AIM me at reimermatt
    http://www.caraudio.com/forum/showth...wpost&t=370497
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Re: 2005 Mercedes C55 AMG Audio Build
    [/URL]
    Stock speakers coming out, I have to say I was kind of impressed at the quality of them.
    Stock tweeter removed
    Dynamat installed in the doors
    Starting to make the spacers
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Gluing the top spacer on before fiberglass and spray paint
    The new tweeters actually have a same size rin to match up with the tweeter bracket. Gluing them in before glass.
    Other spacer being glued
    First spacer being glassed
    Started running speaker wire.
    black05alti's Avatar
    black05alti is offline CarAudio.com Elite
    Apr 2013
    Florida
    729
    221 Post(s)
    looking good so far.. i've seen you around on the altima forums
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Quote Originally Posted by black05alti View Post
    Yep that would be me. Thanks for the complements.
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Today was more like a half day, with most of the morning being filled with rain.
    Finished the s front spacers with a coat of black paint.
    The tweeters were actually to deep for how I wanted to mount them. after thinking it over they were installed flush mounted. I was going to wrap the panel in speaker mesh but the tweeter protruded past the mounting bracket so that was out as well.
    Finished running speaker wire for both side, waiting on the order to come in to run them to the trunk.
    Woofers soldered and heat shrunk.
    Door panel back on
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Found out where to run the power wire
    Rear speakers are out, looks like another 2 brackets have to be made up.
    LightsOut's Avatar
    LightsOut is offline Junior Member
    Mar 2012
    Long Island, NY
    Looks good. Nice car!
  9. Thanks bigaudiofanatic thanked for this post
    Likes bigaudiofanatic liked this post
  10. #9
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Today went smoothly for the most part, had to run out and get a step up but big enough for 0 gauge.
    Started out installing the bass knob along side the existing v1 control.
    Ran the wire under the carpet
    Ran the power wire, perfect spot in the fire wall.
  11. #10
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Using stainless steel bolts that use the same #5 as the fuse holder. Nice little touch
    Just enough room
    Rear spacers glue setting
    While they dried I tackled the factory amp.
    Found the wired I need, mercedes always twists the speaker pairs together
    Soldered and wrapped
    Tinted the ends going into the audio control.
    Labeled as well, still need to disconnect the center speaker and attached the sub.
  12. #11
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Front tweeters soldered and heat shrunk
    Back together
    Glassing the spacers
  13. #12
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    All the interior panels are put back after today's work. All speaker wires are ran as well as rear speakers installed. Sadly the ID CTX's do not fit, so the customer and I decided to install a set of Infinity's until a good set can be found to replace them.
    Dynamat rear doors
    Solder and heat shrunk
    All wires ran to the trunk.
    LOC in it's new location, using factory bolts to secure it.
    Finally decided on the amp mounting locations. Will finish the the rack tomorrow, and tune!
  14. #13
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    nice. the only think i see missing is foam around the front of the new speakers so they seal against the panel - same as factory did. that seal is very important to prevent sound from getting between the panel and door and playing phasing tricks. it also allows the door panel to act as the speaker enclosure since the door's aren't sealed up. as-is, midbass response will suffer.
    i like the attention to detail with the wiring.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  15. #14
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Quote Originally Posted by keep_hope_alive View Post
    Thank you for that advice, I looked around my supplies and didn;t have any foam to go around the woofers. I will have to look into it for future installs and if I get called back from the customer.
  16. #15
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Today was D day, started off wrapping the amp rack and installing the amps. It took two people to haul the thing from the basement to the car but it fit like a glove. After wiring everything up and supplying power, the system came alive perfectly. Too about a half hour to get things tuned in but once things were set all sounded great. Customer comes tomorrow to pick it up, I hope he is as pleased as I am with the system. This was my first incounter with a soundstream amp and I will say I was impressed. Very solidly built.
    Audio Control hidden behind the factory door.
  1. 2005 acura rsx - car audio build
    By bigeasy7 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 03-02-2010, 12:05 AM
  2. Mercedes + RD Audio Build
    By TC2k15x2 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 03-14-2009, 10:04 PM
  3. mercedes c43 amg or c class installation??
    By expo5.0 in forum General Discussion
    Last Post: 01-03-2007, 03:46 AM
  4. is ID arc audios build house?
    By req in forum General Discussion
    Last Post: 04-03-2006, 05:07 PM
