Results 1 to 5 of 5
Reload Thread: 2006 Chevy 2500 HD Crew Cab 4 L7's
    JonnyMasters's Avatar
    JonnyMasters is offline Junior Member
    Jul 2012
    Abbeville SC
    I have a crew cab truck, with 4 Kicker Solo Baric L7 15's, running off a Audiopipe 3000.1D, in a huge ported box. I am going to rebuild the box and add a capacitor. I was wondering everyone's suggestions on boxes. I can fit just about anything because I took my seat out. It sounds really good now, but I just want more. I have considered a bandpass, but I know they are limited to certain ranges and I listen to a lot of different music. Should I just stick with ported? Since I'm adding a capacitor is worth the money to add another battery? Its a big truck so adding one isn't an issue. I just don't have money to waste.
    ~Thank you.
    Spldecendant's Avatar
    Spldecendant is offline CarAudio.com Elite
    Mar 2012
    Ny
    516
    163 Post(s)
    Re: 2006 Chevy 2500 HD Crew Cab 4 L7's
    Battries are better then capacitors and you should probley have a few and a bigger amp for those subs something 5,000w
    red13_69_84's Avatar
    red13_69_84 is offline Junior Member
    Mar 2013
    quad cities, il
    17
    8 Post(s)
    What size cap I suggest atleast a 20 farad can find a stinger one for about 250 I thibk and I agree with a battery they also make a decent large battery too or a kibetic I hear is good or can always buy a yellow top optima
    momofx's Avatar
    momofx is offline CarAudio.com Elite
    Oct 2012
    IL, USA
    572
    142 Post(s)
    Firstly, for those L7's to "perform" the way they were meant to, you will need :
    a. A better and bigger amp based on how you plan to wire up all 4 of them (1 ohm, 2 ohm, 0.5 ohm??).
    b. More batteries based on what kind of amp you get and your total current draw. Capacitors are a waste of time. Ask ANY of the big spl guys.
    c. Possibly upgrade your alternator and do the big 3 if you havent already.
    Ported would be fine for that kind of vehicle btw, as long at your box and port are tuned and built right. Its all in the install
    oxsign's Avatar
    oxsign is offline No Affiliation
    Jan 2006
    Sanford, FL
    5,852
    6 Post(s)
    263 Post(s)
    You do know this is in the "build thread" right? Lets get some pix up of what you already have.
  1. Replies: 3
    Last Post: 03-17-2013, 08:57 AM
  2. Minor 06 Chevy 2500 HD Crew Cab AV Build
    By Paul_Aris in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 04-15-2012, 10:05 AM
  3. Sub help for chevy 2500 hd
    By Jayh9797 in forum Subwoofers
    Last Post: 11-12-2011, 08:14 AM
  4. 2002 chevy 3500 hd extended cab suggestions
    By browningusa in forum Subwoofers
    Last Post: 12-29-2010, 03:23 AM
  5. Silverado HD crew cab ideas?
    By Patrick TX in forum General Discussion
    Last Post: 01-18-2004, 03:16 PM
