Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 48
Reload Thread: Vdub sql
  1. #31
    ciaonzo's Avatar
    ciaonzo is offline TheContinental
    Feb 2009
    WI
    43
    10,996
    20 Post(s)
    1156 Post(s)
    Re: Vdub sql
    Quote Originally Posted by DDtC View Post
    Scott Bulwalda- Hybrid audios owner
    Ah... Why am I not surprised. I guess fourth order is technically sealed with balls as well, lol. Good frequency range, too. One octave.
    Thanks!
    Saying "clipping doesn't kill speakers" is a half-truth at best. Technically no, clipping itself does not hurt the speaker. But in clipping your amp, you can easily create a situation that WILL kill the speaker. Was the squared waveform the DIRECT cause of the failure? No. In the end, the answer is, always has been, and can only be... heat kills speakers. BUT, clipping increases heat generation, sometimes by a drastic amount. So to start a thread simply to state that clipping does not hurt speakers is, again, a half-truth at best.
  2. #32
    Bassballer150's Avatar
    Bassballer150 is offline Member
    May 2011
    Salem Oregon
    135
    18 Post(s)
    Re: Vdub sql
    Quote Originally Posted by ciaonzo View Post
    Well, SQL is a misnomer like that other popular one, substage. I hate both of those 'words' and I refuse to acknowledge them, but I'm lovin' that little DD full range amplifier. I'd like to try one of those at some point.
    It's important to think of vented enclosures and PR enclosures as practically synonymous, but certainly interchangeable. You can achieve identical frequency response plots with both in the pass band, the only exception is the 28dB rolloff with PR compared to 24dB with vented. Other than that, they do exactly the same thing. Each has it's own advantages. PR is a little touchier and a horrid transient response is guaranteed if done wrong. Vented is much more forgiving if tuning is off target.
    To say that you can't have a sound quality setup with a vent is incorrect, you can. You just need to preserve certain things like frequency extension and low group delay within the important thresholds. Another point of interest is the response from 20-80hz. Even if I have an absolutely perfect frequency response profile from 5 to 500hz as measured in an anechoic space, the second I introduce it into the vehicle's interior, that is out the window. The vehicle's acoustics will dominate no matter what. This is why it is ABSOLUTELY essential to have equalization capabilities.
    I'm at work so gotta go for now.
    Thanks for clearing that up , this is definitely not a pure sq setup but hopefully it does what I want and that's play anything I throw at it and be able to enjoy my music which is why I got into CA in the first place
  3. #33
    May 2011
    Salem Oregon
    135
    18 Post(s)
    Re: Vdub sql
    Xcon 15" D2
  4. #34
    ciaonzo's Avatar
    Feb 2009
    WI
    43
    10,996
    20 Post(s)
    1156 Post(s)
    Re: Vdub sql
    Quote Originally Posted by Bassballer150 View Post
    I'm sure it will sound great, man. The Pioneer head should allow you to work around any obstacle you may encounter. Sorry for the clutter in your build thread.
  5. #35
    May 2011
    Salem Oregon
    135
    18 Post(s)
    Re: Vdub sql
  6. #36
    Hybrids-M3's Avatar
    Hybrids-M3 is offline Member
    Feb 2009
    Clanton, Alabama
    38
    7 Post(s)
    Re: Vdub sql
    Link? Name? MECA? Throw me a bone, here.
    Here you go, man. https://www.facebook.com/photo.php?f...type=3&theater
    The enclosure was designed by Pete at http://pwkdesigns.com/
  7. #37
    ciaonzo's Avatar
    Feb 2009
    WI
    43
    10,996
    20 Post(s)
    1156 Post(s)
    Re: Vdub sql
    Quote Originally Posted by Hybrids-M3 View Post
    Beautiful work, thank you for the link. I love the approach you took with the kick panels.
    I'm noticing now that the enclosure is actaully a 6th order, which is even more impressive with regard to group delay and transient response. I'm sure between the one octave sub-40hz passband and T/A, it's not an issue. Again, very nice.
  8. #38
    Hybrids-M3's Avatar
    Feb 2009
    Clanton, Alabama
    38
    7 Post(s)
    Re: Vdub sql
    I'm not Scott, but he would say thank you!
  9. #39
    ciaonzo's Avatar
    Feb 2009
    WI
    43
    10,996
    20 Post(s)
    1156 Post(s)
    Re: Vdub sql
    Quote Originally Posted by RLDriver View Post
    tweeters used to almost ALWAYS go in the kicks with the mids. it seems to have evolved recentlyto the dash. I like them in the kicks, personally, but maybe I just haven't heard the right setup to change my mind!
    There's good reason for that, especially for anyone still using the passive crossover that was supplied with the components. Back in the day there wasn't much T/A so the best way to equalize path-lengths was to mount drivers in the kicks. Aside from that, it's crucial to keep the mid and tweet as close together as possible to preserve phase coherency and a good/even power response. Splitting the mids and tweets apart by more than a full wavelength at the set crossover frequency introduces phase anomalies and comb filtering issues. People tend to think that you can solve this by simply inverting the polarity on the tweets, but that throws the design of the partnership between the components and the passive crossover right out the window as the polarity was already taken into consideration based on the slopes involved.
    With T/A and steep filters, splitting drivers is not as big of an issue but there's still penalties involved when compared to setups acting more like a point source, coax and full range.
  10. #40
    BAPEKC's Avatar
    BAPEKC is offline 2LT
    Feb 2012
    NYC
    209
    66 Post(s)
    Re: Vdub sql
    i have a mk4 also...what you doin for power? alt? batts?
  11. #41
    May 2011
    Salem Oregon
    135
    18 Post(s)
    Re: Vdub sql
    Quote Originally Posted by BAPEKC View Post
    still looking at my options as far as alt goes, but will be running d3100 under the hood and 1or2 bt120 in the back
  12. #42
    ciaonzo's Avatar
    Feb 2009
    WI
    43
    10,996
    20 Post(s)
    1156 Post(s)
    Re: Vdub sql
    Let me let you in on a secret.. Most of these kids shouldnt run active. they dont know how to properly do it. Properly set up passives>>>>poorly set up active. You know this though
    Amen, brutha.
  13. #43
    Ronny's Avatar
    Ronny is offline CarAudio.com Elite
    Jan 2010
    Grand Forks, ND
    727
    92 Post(s)
    Re: Vdub sql
    Quote Originally Posted by jockhater2 View Post
    Your welcome. I don't really have much experience. It's just what I have heard.
    How come you chose to crimp the 0-rings instead of solder them?
    A proper crimping, as in utilizing the needed pressure and material(s), do to the terminal and cable, what is called cold-fuse them together. Although, for the size cables and terminals we use, the amount of pressure needed is indeed immense :p A cold fusing of say OFC cabling and an OFC terminal, actually fuses them as ONE continuous piece of cable. Sure, CCA cabling for instance with an aluminum or copper terminal can cold fuse as well; total resistivity of the piece will still be low, but a tiny bit higher than using the same material for it. Yes you can fuse different metals together, but that is a process that requires a cave and LOTS of explosives lol. Anyhow, I don't want to clog this thread up much more because it is a nice build thread ; but for a given piece, proper crimping has less total resistivity than a soldered piece from say one terminal's end to the other terminal's end. However, for most of the world, the difference is not too big of a concern.
  14. Likes ciaonzo liked this post
  15. #44
    May 2011
    Salem Oregon
    135
    18 Post(s)
    Re: Vdub sql
    pulled out the carpet to wash and finished up adding at to the floor
  16. #45
    May 2011
    Salem Oregon
    135
    18 Post(s)
    Re: Vdub sql
    picked up a new interior off craigslist not bad for 50bucks way better then the dirty tan seats i had
  1. Sql
    By FAM4LIFE in forum Subwoofers
    Last Post: 01-18-2003, 08:04 AM
  2. SQL- A SQ system with balls.
    By TheGrimReaperKD in forum Subwoofers
    Last Post: 01-13-2003, 10:13 PM
  3. Sql setup with dd 3512
    By Sspider in forum Subwoofers
    Last Post: 10-03-2002, 01:50 PM
  4. Whats better for sql
    By turbo in forum Subwoofers
    Last Post: 09-15-2002, 10:44 AM
  5. Sql V.s Spl
    By beatha in forum General Discussion
    Last Post: 09-14-2002, 10:13 PM
