+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Reload Thread: Space Problem F-150 extended cab FX2
  1. #16
    jasonbillnelson's Avatar
    jasonbillnelson is offline LEAD, FOLLOW, OR GTFO!!!
    Oct 2012
    Andrews AFB, MD
    26
    740
    Re: Space Problem F-150 extended cab FX2
    Well, If you don't want to spend anymore money you could try and take the rubber ring off the circumfrance of the sub. That should give you a little more clearance on the subwoofer from cone/surround to the floor. However If it was me, I'd get a different box made for me or alter the seat configuration. just my $0.02
    SSgt. Jason Nelson
    Andrews AFB, MD
    USAF
    ****Feedback from PBnation****http://www.pbnation.com/feedback.php?u=382280
    ****Feedback from eBay****search jasonbillnelson, 104 positive-0 negative
    Bought from sangthing, 93 saturn sl2, basswiigee
  2. #17
    MTXThunder9500's Avatar
    MTXThunder9500 is offline Fo Shizzle
    Nov 2005
    Fargo, ND
    29
    445
    LMI Welding Quality Metal Fabrication
    I used that in my pick up. 2006 f150 XLT. a little spendy but worked nicely. You could do this with spacers under the box to raise it up some.
    Refs:
    9512ds,showrides,Rc 415,path2spl,stratusrt01
  3. #18
    Redlineaudio's Avatar
    Redlineaudio is offline The Glass is to Big
    Apr 2008
    Spindale NC
    36
    1,107
    I did not read it all. But space the box up and space the seat up also.
    02 Quad Dak
    Cheap Flipout
    Phoenix Gold Ti2 6 1/2 front Memphis Pr 6 1/2 rear doors
    Phoenix Gold SL 10's Behind the rear seats
    Memphis Belle to power it all
  4. #19
    4bannger's Avatar
    4bannger is offline Member
    Nov 2012
    FLA
    89
    I had two rockford fosgate shallow mount 10's in my single cab truck. I made the boxes as small as possible. I believe they were about 4" deep. They hit pretty good in thoses little boxesz I would just suggest some small boxes
+ Reply to Thread
  1. 99 F-150 Extended Cab System Design Help
    By hotshot5231 in forum Wiring, Electrical and Installation Help
    Last Post: 07-10-2011, 10:30 AM
  2. 1999 Ford F-150 Extended Cab Build Log... My attempt at something decent!
    By SSS 18734 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 08-17-2009, 11:34 PM
  3. new box for my extended cab f-150
    By foreman400x in forum Enclosure Design & Construction Help
    Last Post: 02-16-2007, 06:52 PM
  4. Ford F-150 Extended cab
    By kx100kicks in forum Enclosure Design & Construction Help
    Last Post: 03-17-2003, 01:54 AM
  5. Sub orientation in an extended cab f-150?
    By Jdg784 in forum General Discussion
    Last Post: 02-02-2003, 09:25 PM
Tags for this Thread
