Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 61 to 75 of 82
Reload Thread: KHA does an SPL build - 1996 Astro Van
  1. #61
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Re: KHA does an SPL build - 1996 Astro Van
    Bummer, didn't see the van so figured you weren't there. Gay purple minivan was mine.
    LONG *** ride home, rained hard the first hundred miles, but cleared up for the last 100....
  2. #62
    NIHL8ION's Avatar
    NIHL8ION is offline RUN ur car NOT ur mouth !
    Mar 2013
    IlliNOISE
    1,355
    22
    377 Post(s)
    Quote Originally Posted by mlstrass View Post
    lmao - I'd rock your "gay purple minivan" any day of the week
    - Cadence DCA2500.1 Running a Tantric HDD - 12" D2
    *Bought From: cx-7heaven, nutnbutcustm, naughtyca, agarabaghi, Skip01*Traded With: infamous_e46, basswiigee**Sold To: DeanG, R.S.D., livinloud!*
    Feedback Link: http://www.caraudio.com/forums/itrader.php?u=1028333
  3. 05-27-2013
    Acoustics Engineer
  4. #63
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    put a double din Kenwood in the van this weekend. it didn't fit, so custom mounts and some mods to the dash panel were required. i'd like to touch up the finished product but it was close enough for the evening.
    in progress with wiring
    finished
    next up - relocating amps... look at all this space
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  5. 05-28-2013
    Shaggy DOA
  6. 05-28-2013
    Acoustics Engineer
  7. 05-29-2013
    Shaggy DOA
  8. 05-29-2013
    Acoustics Engineer
  11. #64
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    pics from the truck box. built the box in under 6 hours over two days.
    amp location was temporary, about an hour of effort. i built a box for the caps.
    the end results will be amps on top of the box with a cover to flush them up with caps under the box. a small seat will be added behind the driver's seat.
    the box and cover will either be carpeted or painted blue to match the truck.
  12. #65
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    more progress late last night (10pm-5am)
    got the amps moved, mounting boards cut and painted, wires ran. the factory panels will fit over these and completely hide the gear. as stealth as it gets.
    the rockford 500x shown will be replaced with a Massive NX4. A total of 8 full range channels are available. Will likely run the front active with a 3-way (add a mid) then have speakers in the rear doors for outdoor parties and then a sound bar above the box for higher output. i'll have relays to switch configurations.
    phone pics at 5 am will be replaced with better pics. i will also likely use split loom on all wiring once we finalize.
    rear battery is fused. connections are made between the rear and front battery fuses. a total of 3 fuse blocks are used. (1) ANL for the Massive N4. (2) MAXI are dedicated to the Ultracap bank that will be installed on the available space shown below. and another (2) MAXI for the 4 channel amps.
    fuses will be accessible through removable rear cup holders and access. this is the Rocford that the NX4 will replace (location is sized for it)
  13. #66
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    before:
    after:
    connected the caps
    insulated with CCF
  14. #67
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    covering it up
    fuses are accessible
    through a removable controller
    panels in place
  15. Likes subzero liked this post
  16. #68
    subzero's Avatar
    subzero is offline CarAudio.com Veteran
    Sep 2008
    Phoenix, AZ
    41
    6,784
    30
    7 Post(s)
    454 Post(s)
    nice work!
  17. #69
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    i'll put some blue carpet in the middle pocket to hide the battery. some black fabric is there now to just reduce the visibility. turns out, i didn't need to cut out the pockets. i could have left them in place. i'll find a replacement panel in a salvage yard eventually. i did have to cut the middle pocket to clear the battery. carpet in the pocket will reduce rattles of anything in there anyway.
    once the box is moved behind the driver's seat and the rear bench is in place, the amps are basically inaccessible, but fuses are always accessible.
  18. #70
    Feb 2011
    hiawatha, ks
    33
    6 Post(s)
    very nice!
  19. #71
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    i will have to change this from an SPL build to an SQ build.
    we just ordered a pair of miniDSP's for 8 channels of processing. we will run 3-way active front.
    i think the next show will be SQL and not SPL.
  20. #72
    phemps's Avatar
    phemps is offline CarAudio.com Veteran
    May 2009
    PA
    2,023
    284 Post(s)
    Did you try the enclosure in horn formation?
    Refs: Rio, DbzArson, goodstuff, Worstenemy453
    Quote Originally Posted by Altec View Post
    Then obviously I am asking the wrong person, because you don't know how to hook up subs if they sounded like "****". Maybe learn your ohms and your diagrams before you call something ****. Learn to make boxes to specs and use the right wires and its called dynomat. Then maybe your car wouldn't of sounded like ****, yeah?
  21. #73
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    Quote Originally Posted by phemps View Post
    nah, nice concept but not going to achieve the final goal.
    we are moving the sub to behind the driver and then putting in framing for a removable wall to seal off behind the b-pillars. we will also get the rear bench seat back in for a total of 3 captain chairs and a bench.
  22. #74
    phemps's Avatar
    May 2009
    PA
    2,023
    284 Post(s)
    SQ wall
  23. #75
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    SQ wall
    with the miniDSP's i think i can pull it off.
    what we ordered tonight;
    (2) 2in-4out miniDSP kits with the DC power isolator and USB cables/mounts.
    (2) Vifa NE65W-04 2" midrange drivers. these will go in the factory tweeter locations (3" grill).
    (1) DRemote for the Massive N4 - a remote amp gain knob
    (1) remote for the Kenwood DDX-418 HU.
    speaker wire, tie-downs, etc. as needed.
    essentially, the van has 8 channels of amplification for speakers. we will use all 8 along with the mini-DSP's to do a 3-way active front stage and separately filtered rear. for $200 for both kits, it made much more sense than looking for an active crossover. Besides, the HU doesn't have time alignment and the van needs it.
    should be fun.
  1. 12 15's in a Astro Van door pod fiberglassing video build log
    By twistedchild420 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 07-19-2010, 02:16 PM
  2. Does/has anyone have/had an SPL amp?
    By Americanstrat21 in forum Amplifiers
    Last Post: 04-03-2008, 09:19 AM
  3. Thinking of building an SPL enclosure for my MT
    By Basshead808 in forum Enclosure Design & Construction Help
    Last Post: 07-09-2007, 03:30 AM
  4. Need a little help designing SQL box for 2 CVR 18's in an astro van
    By jamesfoster in forum Enclosure Design & Construction Help
    Last Post: 10-19-2006, 07:07 PM
  5. Thinking on building an SPL system
    By OnYrMrk in forum General Discussion
    Last Post: 09-14-2005, 01:49 AM
