Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 46 to 60 of 82
Reload Thread: KHA does an SPL build - 1996 Astro Van
  1. #46
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    Re: KHA does an SPL build - 1996 Astro Van
    progress this weekend..
    box is assembled and sprayed inside and out with bedliner
    while that was drying, we worked on the doors. while this is SPL capable, it will be an SQ daily.
    factory
    used a Trunk kit of Stinker Roadkill Expert, 20 sf total, used about 8sf per door.
    also did bags of 0.5mil PVC encased fiberglass batt insulation for sound absorption.
    then covered the entire door with Stinger Overkill - this stuff was thick and heavy.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  2. #47
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    for the large holes, i had 3/4" UV treated birch that i wrapped in the factory closed cell foam sheeting. then screwed to the door, but located the wood on the inside. worked well.
    both doors looked like this
    foamed and sealed
  3. #48
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    JL C5 comps
  4. #49
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    a beauty panel will follow shortly.
    you may notice that we used a Grade 8 bolt to hold the seat belt clip to the box. this was extra insurance that the box wouldn't kill passengers. there are much larger Grade 8 bolts holding the box down to the floor, i can post this since no one would want to attempt to steal the box anyway and the time it takes to do so, you would be shot before you even got the sub out...
    she wangs hard.
  5. #50
    collin.k's Avatar
    collin.k is offline Member
    Apr 2010
    Vancouver, Canada
    149
    3 Post(s)
    well lets see then!
    2 12" premier champion series pro
    hfi 2000d
    big3
    kny 0ga all throughout
    atomic ma65cx
    kenwood 4 channel
    5 cubes @ 32 hz
  6. #51
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    Quote Originally Posted by collin.k View Post
    well lets see then!
    videos and a DB Drags will be this weekend. we'll see. my goals for actual comp include a second port and enough boards to build a horn in the back of the van.
  7. #52
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    what show and where this weekend?
  8. #53
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    Quote Originally Posted by mlstrass View Post
    Cordova, IL. This Friday, 11:30pm start. There is also a car show that is separate from the DB Drags event.
    Last night we were hunting some loud rattles and found the jack/ramps/etc. were not secured. Also found a rear heater unit that was leaking coolant. so we had to pull half of the carpet up, which meant moving the box. I figured for the event we would want the box closer to the mic anyway, so we moved it here (still bolted for safety) - crappy phone pics at 3am.
    passenger seat is reclined. the box is actually behind the B-pillars.
  9. #54
    red13_69_84's Avatar
    red13_69_84 is offline Junior Member
    Mar 2013
    quad cities, il
    17
    8 Post(s)
    Know I haven't hit you up in awhile been busy at work... still planning on fri at cordova? I've never been to one yet and wouldn't mind tagging along for it or meeting with you guys somw time this week if you want.
  10. #55
    mlstrass's Avatar
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Fug, now I might have to make the trip out for Midnight Mayhem just to meet you.....
  11. 05-22-2013
    Acoustics Engineer
  12. #56
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    i put the oscilloscope on the amps tonight. unloaded, I got 46VAC out of the Massive N4 before clipping with HU at full volume and sub level on full. if it could sustain that at 1 ohm then 2116 W would be on tap. I don't expect to see that with an actual load.
    the BA GT amp did ~35VAC when bridged, so around 300W bridged to the front comps.
    musically, it sounds good, just that everything is low without T/A and low tweeters.
    it's pretty loud, i have no idea what it will meter. i wanted to get a wall built but the other enclosure is eating up that time.
  13. #57
    Mar 2013
    quad cities, il
    17
    8 Post(s)
    I get off at 8 if you want help
  14. #58
    mlstrass's Avatar
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Going for sure, so I'll look for the van. Looks like there will be a few set ups with 18's there....
  15. #59
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    Quote Originally Posted by red13_69_84 View Post
    FYI - this is a cool guy.
  16. #60
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    So, i may be a liar. The van owner may be unavailable and if he doesn't go, i probably won't. if you want to hang out sometime, just come over. we can talk shop and play with systems. i'll RTA anything.
    we'll see...
  17. 05-24-2013
    Acoustics Engineer
  1. 12 15's in a Astro Van door pod fiberglassing video build log
    By twistedchild420 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 07-19-2010, 02:16 PM
  2. Does/has anyone have/had an SPL amp?
    By Americanstrat21 in forum Amplifiers
    Last Post: 04-03-2008, 09:19 AM
  3. Thinking of building an SPL enclosure for my MT
    By Basshead808 in forum Enclosure Design & Construction Help
    Last Post: 07-09-2007, 03:30 AM
  4. Need a little help designing SQL box for 2 CVR 18's in an astro van
    By jamesfoster in forum Enclosure Design & Construction Help
    Last Post: 10-19-2006, 07:07 PM
  5. Thinking on building an SPL system
    By OnYrMrk in forum General Discussion
    Last Post: 09-14-2005, 01:49 AM
