Results 1 to 3 of 3
Reload Thread: 2006 Mastercraft X1 boat build w/ pics
    agarabaghi's Avatar
    agarabaghi is offline Senior VIP Member
    Apr 2011
    Orlando, FL
    480
    15 Post(s)
    Well we re did part of the system after the last box didnt hold up to the moisture. The previous box was ported with an XCON 10" on 2x apsm 1300 strapped together. It was loud for sure, but the port allowed too much moisture in and destroyed the box. I decided to go with a little less power and bit more cone area. Sundown SA12 subwoofer and 1 apsm 1300 @ 1ohm. The box is sealed this time, and i use truck bed liner and rubberized underbody spray. The outside was them primed with bathroom primer (says it worked in high moisture environments) and then painted with water proof spray paint, and finally carpeted.
    In boat speakers: (4) JL Audio M770 7" drivers
    Amp: Wetsounds Syn 6 (waterproofed arc audio amp basically)
    Subwoofer: (1) Sunday SA12
    Amp: Audiopipe Apsm-1300 1000 @ 1 ohm
    Towerspeakers: (2) Wetsound Rev8 - 8" midbass driver + 1 HCLD horn in each pod
    (1) Wetsound Pro480 - 2x 8" midbass driver + 1 HCLD horn
    Amp: Wetsound Syn 6 (channel 5 + 6 bridged) 600 x 1 @ 4ohms
    Audiopipe APMR-1504 bridged 230 x 2 @ 4 ohm
    THATpurpleKUSH's Avatar
    THATpurpleKUSH is offline Smoke weed everyday
    Sep 2009
    twenty past four
    4,599
    3 Post(s)
    1767 Post(s)
    Re: 2006 Mastercraft X1 boat build w/ pics
    Looks great, I always like your boat builds.
    If you choose to go ported again, make sure to cover the inside of the box with fiberglass resin so it's able to withstand the moisture.
    Dtrom's Avatar
    Dtrom is offline MAF
    Jul 2012
    3,996
    1190 Post(s)
    That really makes me want a boat!
    REFS alot
  1. Line Array Build Progress - **PICS**
    By brandontw in forum Home Audio/Video
    Last Post: 09-01-2006, 05:16 PM
  2. '99 Cobra 'Vert Single 10" ported box build-up *PICS*
    By VereChronicus in forum Subwoofers
    Last Post: 04-18-2006, 04:06 AM
  3. My sub enclosure/amp rack trunk build (30+ pics)
    By lubetek in forum Enclosure Design & Construction Help
    Last Post: 02-10-2006, 08:52 PM
  4. 95 Tahoe Door Panel Build Up. (Pics)
    By DOHCrazy in forum General Discussion
    Last Post: 01-12-2006, 12:22 AM
  5. BOX BUILD! worklog [pics]
    By maldecido33 in forum Enclosure Design & Construction Help
    Last Post: 10-30-2005, 05:50 PM
