+ Reply to Thread
Page 4 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 46 to 60 of 93
Reload Thread: new whip, new build.
  1. #46
    itsblown's Avatar
    itsblown is offline why is there smoke?
    Sep 2011
    Toledo OH
    1,126
    15 Post(s)
    Re: new whip, new build.
    Quote Originally Posted by RangerDanger View Post
    goal is to break a 140.
    I hope that 140 comes easy, when will we see pics
  2. #47
    DbDesigns's Avatar
    DbDesigns is online now CarAudio.com Veteran
    Nov 2011
    mora minnesota
    4,311
    69 Post(s)
    Quote Originally Posted by itsblown View Post
    I have to send the baskets back to psi because they sent me the wrong ones. when they come ill build the woofers, then the box. box is being designed right now.
  3. #48
    SourDeez's Avatar
    SourDeez is offline CarAudio.com Veteran
    Apr 2007
    Fuqy u
    4,134
    62 Post(s)
    So you're actually gonna build this one right? And not just draw up a few hundred box plans?
    Headunit - Stock cassette player - Pioneer P9400
    Front Stage - Pyle 8 inch subs (1000 watt peak!!) - Polk DB6.5 (about to be CDT 6.5s)
    Rear stage - Deleted (stolen) - Deleted
    Sub stage - custom built 15 inch sony xplod (5k watt peak!!!) (huge box) - Two SA12's built by Corey
    Sub amp - Pyle 8000w peak!! (spl edition) - AQ2200
    Electircal - 35 amp alt from ford festiva upgrade, stolen battery, 28 gauge solder coil for my cable - Dual D34 Yellows, 1/0 trystar OFC, 135amp alt
  4. Likes itsblown liked this post
  5. #49
    DbDesigns's Avatar
    Nov 2011
    mora minnesota
    4,311
    69 Post(s)
    Quote Originally Posted by SourDeez View Post
    the ranger had quite a few builds through it??
  6. #50
    SourDeez's Avatar
    Apr 2007
    Fuqy u
    4,134
    62 Post(s)
    I think you're potentially lying
  7. #51
    blobb454's Avatar
    blobb454 is offline CarAudio.com Elite
    Nov 2012
    LANSING MI
    983
    6 Post(s)
    That'll be ******! Keep posting up for follow along.
    Quote Originally Posted by kpetree View Post
    I feel like you're a waste of your mothers stretch marks, better luck finding your gf next season. Fck off, post dump somewhere else.
  8. #52
    DbDesigns's Avatar
    Nov 2011
    mora minnesota
    4,311
    69 Post(s)
    little update... still doing a lot of planning. I decided to stick with the single 3500 for now, instead of buying a tenney alt Im just going to have dc recase my alt to fit the hoe, box will be stained with clear poly instead of paint, birch enclosure... blah blah blah. lots of work to do, I just need to finish up the entire planning process and start the build. stay tuned.
  9. #53
    cdc351jeferson's Avatar
    cdc351jeferson is offline Premium Member cdc351jeferson is a Supporting Member of the forum!
    Jul 2012
    austin tx
    1,582
    12 Post(s)
    do you have a shop or garage to work in or you gonna go all eskimo on it outside ? lol . looking forward to seeing some pics of the progress man .
    headunit : Sony xab-601bt
    fronts: infinity kappa 60.9's
    subs: 2x dc 12" xls
    box : 3cuft net 33hz ORIGINAL STARR MOUNTAIN SOUND NUTHUGGER
    sub amp: AQ3500.1
    others: Mechman 240amp alt, 3 xs3400batts , all 1/0 knukoncepts kollosus flex, stinger deadener
    REFS: Bradfordp2612 , Double 07 , NASTY08IMPALA
  10. Likes audiobaun liked this post
  11. #54
    DbDesigns's Avatar
    Nov 2011
    mora minnesota
    4,311
    69 Post(s)
    Quote Originally Posted by cdc351jeferson View Post
    I have a shop, but its not heated... lol gets pretty cold but Its better than outside.
  12. #55
    double 07's Avatar
    double 07 is online now Supporting Vendor double 07 is a Supporting Member of the forum!
    double 07 is a Supporting Vendor of the forum!
    Nov 2011
    Etowah, TN
    1,872
    13
    270 Post(s)
    I know a great box designer in OK if ya need one........Looking forward to the build....
    We are Starr Mountain Sound of Southeast TN ....Hand built enclosures shipped nationwide....Check us out on Facebook or ......www.starrmountainsound.com
    97 Chevy Blazer 4dr....4 AB XFL 12s.....2 DC 3.5ks strapped at 1 ohm.....152db legal with music......
  13. #56
    Jul 2012
    austin tx
    1,582
    12 Post(s)
    im from michigan . if you can block the wind thats half the battle bro !
    subs: 2x dc 12" xls
    sub amp: AQ3500.1
  14. #57
    DbDesigns's Avatar
    Nov 2011
    mora minnesota
    4,311
    69 Post(s)
    Quote Originally Posted by double 07 View Post
    I know a few good ones myself
    ---------- Post added at 10:46 PM ---------- Previous post was at 10:46 PM ----------
    true dat homie.
  15. #58
    DbDesigns's Avatar
    Nov 2011
    mora minnesota
    4,311
    69 Post(s)
  16. #59
    all's Avatar
    all
    all is offline Junior Member
    Mar 2013
    New York, NY
    great! keep posting!
  17. #60
    DbDesigns's Avatar
    Nov 2011
    mora minnesota
    4,311
    69 Post(s)
    thanks! more pics tomorrow.
+ Reply to Thread
  1. New whip.....new sub options
    By FineLinePimpin in forum Subwoofers
    Last Post: 03-26-2012, 03:58 PM
  2. New Whip, new system.
    By Ku-sama in forum General Discussion
    Last Post: 07-23-2007, 10:06 PM
  3. Anyone located in New Jersey that builds boxes?
    By ls1pimp in forum Enclosure Design & Construction Help
    Last Post: 07-18-2005, 11:56 PM
  4. New to box building, need help with Dimensions
    By S0CalS0L in forum Enclosure Design & Construction Help
    Last Post: 07-27-2004, 04:24 PM
